Re: Is this fuel system adequate?
[Re: Dave Hall]
#2318136
06/08/17 05:00 PM
06/08/17 05:00 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I don't remember how much pressure that fuel pump makes but I would want the fuel regulator in line in front of the carb. and the second fuel filter to be 10 microns mounted between the regulator and carb. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I have used one of the Mallory 140 pumps with the regulator that Mallory sold with it and it was marginal on a smaller 440 bracket motor under 600 HP Maybe a better, bigger pump is needed now instead of finding out later it isn't good enough Thanks for the input Cab. Since I have the pump already, I'll probably give it a try and, if it's inadequate, I'll sell it and swap to a bigger pump. Thanks again. If you're running 1/2" why would you put that piece of 3/8" between the filter and the pump? Are you referring to the piece of -8 to supply the pump? Should I step that up to -10? The regulator needs to be in front of the carb and -6 is fine to the carb. -6 would also be fine for the return. That system will be fine for the street but a 10 sec. car will probably zero the gauge going down the track.
Thanks for the input. So, placing the regulator in front of the carb would be better. I've always thought after the carb is best since it keeps fresh (cooler) fuel feeding the carburetor, especially in a street car. When at the track, does it not regulate pressure as well in that configuration? Thanks again.
[Re: mopowers]
#2318139
06/08/17 05:09 PM
06/08/17 05:09 PM
Posts: 2,094 central texas
krautrock
central texas
looks like the way you have it drawn, the regulator will only regulate pressure in the return line, carb will see full pump pressure...
EDIT: oh nvm, did some quick reading, seems the pressure is constant in the whole fuel system no matter where the regulator is.
[Re: mopowers]
#2318141
06/08/17 05:15 PM
06/08/17 05:15 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
That drawing should work perfectly. Sizes and placement of the regulator are fine assuming using the correct regulator. Much more flow to the carb with this set up. You would possibly be better off with -10 between the filter and pump.
[Re: mopowers]
#2318156
06/08/17 05:59 PM
06/08/17 05:59 PM
Posts: 17,923 S.E. Michigan
ZIPPY
S.E. Michigan
I don't think that's going to work, you're going to have full fuel pump pressure at the carburetor that way. The regulator needs to be moved.
Rich H.
Esse Quam Videri
[Re: mopowers]
#2318169
06/08/17 06:29 PM
06/08/17 06:29 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Looks good to me, I would use #10 between filter and pump. I ran a very similar set up for many years, went 9.60s with it in a 3400 lb car. People don't understand that it is designed to keep 7 lbs of pressure in front of regulator.(or whatever you set it to) It won't see high pressure like they think. It was the most steady pressure system I ever had on my car.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2318172
06/08/17 06:38 PM
06/08/17 06:38 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
Looks good to me, I would use #10 between filter and pump. I ran a very similar set up for many years, went 9.60s with it in a 3400 lb car. People don't understand that it is designed to keep 7 lbs of pressure in front of regulator.(or whatever you set it to) It won't see high pressure like they think. It was the most steady pressure system I ever had on my car. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
[Re: mopowers]
#2318175
06/08/17 07:06 PM
06/08/17 07:06 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
you have the regulator in the correct place for a return system !!!
I have & do run this set up like your picture.
[Re: mopowers]
#2318187
06/08/17 07:34 PM
06/08/17 07:34 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
With the way you have it drawn in the pic is the way you should do it, just change the short line between the filter and fuel pump, make it bigger. The pressure is going to be the same from the regulator back to the pump.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: mopowers]
#2318190
06/08/17 07:37 PM
06/08/17 07:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The system looks fine... the #8 before the pump I might change to a #10... make sure the filter will flow the amount needed.. other than those little things your fine.. on the section of #8 I just like to have the first restriction at/or near the carb... as for the pump.. rule of thumb is .5 pounds per HP and your safe ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Dave Hall]
#2318205
06/08/17 08:35 PM
06/08/17 08:35 PM
Posts: 8,190 Plymouth, MI
Blusmbl
Plymouth, MI
If you're running 1/2" why would you put that piece of 3/8" between the filter and the pump? The regulator needs to be in front of the carb and -6 is fine to the carb. -6 would also be fine for the return. That system will be fine for the street but a 10 sec. car will probably zero the gauge going down the track. I thought -8 was the AN equivalent to 1/2" OD tube. Wouldn't hurt to go bigger it is probably fine.
[Re: Blusmbl]
#2318216
06/08/17 08:57 PM
06/08/17 08:57 PM
MR_P_BODY
If you're running 1/2" why would you put that piece of 3/8" between the filter and the pump? The regulator needs to be in front of the carb and -6 is fine to the carb. -6 would also be fine for the return. That system will be fine for the street but a 10 sec. car will probably zero the gauge going down the track. I thought -8 was the AN equivalent to 1/2" OD tube. Wouldn't hurt to go bigger it is probably fine. #8 is equal to 1/2"... 3/8" is a #6 ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: an8sec70cuda]
#2318257
06/08/17 10:27 PM
06/08/17 10:27 PM
dartman366
Mt. Vernon, Ohio
Looks good to me, I would use #10 between filter and pump. I ran a very similar set up for many years, went 9.60s with it in a 3400 lb car. People don't understand that it is designed to keep 7 lbs of pressure in front of regulator.(or whatever you set it to) It won't see high pressure like they think. It was the most steady pressure system I ever had on my car. absolutly agree, I switched to that system several years ago and has worked flawless every since, just change that smaller line between the filter and pump and you will be golden. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: mopowers]
#2318394
06/09/17 10:48 AM
06/09/17 10:48 AM
Challenger 1
Cincinnati, Ohio
I'm beginning to piece together the fuel system for my street/strip 66 Dart. It'll eventually have a 600-650hp stroked big block.
After thinking about it some, the pump and filter would be near the fuel cell on the frame rail, running to the carb via 1/2" aluminum hard line, then to a bypass regulator and finally returning to the cell via another 1/2" aluminum hard line.
Would this fuel system be adequate? I already have many of the pieces. Is there anything you would change (parts, or hose/line sizing)?
Thanks! My ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I would use a 100 micron strainer in the outlet fitting in your fuel cell and do away with the 100 micron housing because you want a smooth flow of gas to the pump. A filter housing on the inlet side of the pump is not a good idea because it interrupts smooth gas flow to the pump and can cause cavatation. If you do use it keep it away from the pump so the gas has time to smooth out before getting to the pump. It really is a bad idea, a separate pre filter. Just more places for the fuel to heat up and weighs more too. Use at least all #10 to the pump with #12 being better on the suction side. Minimize any restrictions(smooth fittings and try not to use 90s. Or at least tube 90s) on the inlet side and the fuel pump must be lower than the fuel cell. Can't suck up hill or even level can cause cavatation. Pressure regulator is in the right place and you only need #6 coming out of the pump. It is a disadvantage to have it oversize because it makes the pump work harder pushing it forward under hard acceleration. It weighs more and then there is slower fuel flow which allows it to heat up more. This is one kind of 100 micron discharge fitting for your fuel cell, way better than a external filter and housing. Less to heat up like I said. LINK A fuel pump in the fuel cell is the best way to go.
[Re: A39Coronet]
#2318404
06/09/17 11:18 AM
06/09/17 11:18 AM
Challenger 1
Cincinnati, Ohio
I favor fuel systems that don't run a return from the regulator all the way back down the length of the car. My Magnafuel pump has the return right at the pump, and no return from the engine compartment. I'm not a fan of running two lengths of hose that distance; waste of money on line, and just another thing that could leak/dry rot/get hit and send you home early. Obviously depends on what parts you already have in your possession. By returning fuel right in front of the pump you run the risk of introducing bubbles and turbulence into the inlet of the fuel pump and can cause cavatation during hot weather. Steel line should be used front to back and not hose.
[Re: Challenger 1]
#2318412
06/09/17 11:38 AM
06/09/17 11:38 AM
MR_P_BODY
I'll use a return system any day.. when I was testing hot fuel in Cali.(Death Valley and Baker grade) I seen fuel temps in the low 300* range.. that fuel at the injectors was sitting there boiling.. it took a fair amount of time to get that hot fuel out of there.. with a return it would be out of there in short order...I dont mind paying more for a good system.. even if it weighs more ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: mopowers]
#2318417
06/09/17 11:45 AM
06/09/17 11:45 AM
MR_P_BODY
Thanks for all the input guys. I appreciate it. The main reason for the -8 line between the filter and pump was just for packaging purposes. -8 seems to bend a lot easier and the fittings are smaller, so I could pump the pump and filter closer together. Plus, since the threads on both the pump and filter are pretty small (3/8 npt), I didn't realize the -8 would causes much of a restriction. I'll go with -10 though as you folks suggested and separate the filter and pump a little more to make it doable.
Thanks again. Make sure you use idolators on that pump.. it really helps with the noise ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2318423
06/09/17 12:03 PM
06/09/17 12:03 PM
mopowers
Sac, CA
Thanks again. Make sure you use idolators on that pump.. it really helps with the noise I am for sure. Thanks.
[Re: MR_P_BODY]
#2318430
06/09/17 12:25 PM
06/09/17 12:25 PM
Posts: 1,115 Usa
A39Coronet
Usa
I favor fuel systems that don't run a return from the regulator all the way back down the length of the car. My Magnafuel pump has the return right at the pump, and no return from the engine compartment. I'm not a fan of running two lengths of hose that distance; waste of money on line, and just another thing that could leak/dry rot/get hit and send you home early. Obviously depends on what parts you already have in your possession. By returning fuel right in front of the pump you run the risk of introducing bubbles and turbulence into the inlet of the fuel pump and can cause cavatation during hot weather. Steel line should be used front to back and not hose. It returns it right after the pump into the tank (should have specified). With the return on the opposite end of the tank, and the feeds coming out of the bottom, no chance of aeration or turbulence other than normal occurrence with the car moving. I'll use a return system any day.. when I was testing hot fuel in Cali.(Death Valley and Baker grade) I seen fuel temps in the low 300* range.. that fuel at the injectors was sitting there boiling.. it took a fair amount of time to get that hot fuel out of there.. with a return it would be out of there in short order...I dont mind paying more for a good system.. even if it weighs more In PA, and pretty much anywhere outside of the hottest place on Earth, I never have to worry about 300 degree fuel temps. Theres also a safety aspect of not running two full lengths of fuel line. I understand theres more than one way down a racetrack, I'm just saying why I favor this style. Theres a reason bigger Aeromotive and Magnafuel race pumps utilize this feature.
[Re: A39Coronet]
#2318442
06/09/17 12:44 PM
06/09/17 12:44 PM
MR_P_BODY
Your correct.. there is more than 1 way to do these things and people can do what ever way they wish ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: A39Coronet]
#2318452
06/09/17 01:13 PM
06/09/17 01:13 PM
Thumperdart
State of confusion
I favor fuel systems that don't run a return from the regulator all the way back down the length of the car. My Magnafuel pump has the return right at the pump, and no return from the engine compartment. I'm not a fan of running two lengths of hose that distance; waste of money on line, and just another thing that could leak/dry rot/get hit and send you home early. Obviously depends on what parts you already have in your possession. By returning fuel right in front of the pump you run the risk of introducing bubbles and turbulence into the inlet of the fuel pump and can cause cavatation during hot weather. Steel line should be used front to back and not hose. It returns it right after the pump into the tank (should have specified). With the return on the opposite end of the tank, and the feeds coming out of the bottom, no chance of aeration or turbulence other than normal occurrence with the car moving. I'll use a return system any day.. when I was testing hot fuel in Cali.(Death Valley and Baker grade) I seen fuel temps in the low 300* range.. that fuel at the injectors was sitting there boiling.. it took a fair amount of time to get that hot fuel out of there.. with a return it would be out of there in short order...I dont mind paying more for a good system.. even if it weighs more In PA, and pretty much anywhere outside of the hottest place on Earth, I never have to worry about 300 degree fuel temps. Theres also a safety aspect of not running two full lengths of fuel line. I understand theres more than one way down a racetrack, I'm just saying why I favor this style. Theres a reason bigger Aeromotive and Magnafuel race pumps utilize this feature. This is how I ran mine..........300 Magnafuel returned directly after the pump into the cell w/a 100 micron pre-filter before and nothing after but may end up w/a 40 after........... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) #10 to the regulator and 8's into the carb..........
[Re: mopowers]
#2318527
06/09/17 03:47 PM
06/09/17 03:47 PM
ZIPPY
S.E. Michigan
Glad I stopped back by, thanks for the lesson, and guess I have some reading to do on this topic.
I have a Mallory Comp 250 pump with a Comp 500 filter + return regulator, and truthfuly probably didn't put all that much thought into it, I just followed the manufacturer's instruction sheet and did it the way they told me to. I really like the return system, and always thought the Gerotor pump was a more robust design than the vane type. Whenever somebody says they've got a Mallory pump on a street car my ears perk up.
Rich H.
Esse Quam Videri
[Re: Clanton]
#2319524
06/11/17 07:21 PM
06/11/17 07:21 PM
mopowers
Sac, CA
Did you think about getting a 250 pump at all?You can test the flow with a ball valve after the regulator into a can and check your psi,flow[just a fyi] I did consider a 250 pump. At the time, Mallory recommended their 140 for the goals I had at the time (600hp stroked big block). If it comes up short, I'll step up to the 250.
[Re: mopowers]
#2319547
06/11/17 09:00 PM
06/11/17 09:00 PM
Challenger 1
Cincinnati, Ohio
Did you think about getting a 250 pump at all?You can test the flow with a ball valve after the regulator into a can and check your psi,flow[just a fyi] I did consider a 250 pump. At the time, Mallory recommended their 140 for the goals I had at the time (600hp stroked big block). If it comes up short, I'll step up to the 250. It won't be properly plumbed, the 140 is plenty.
