Headers vs stock exhaust manifolds. Opinions? #2317333
06/06/17 09:47 PM
06/06/17 09:47 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I have been running a set of TTI headers on my 383 for about 15 years now and aside from being ceramic re-coated twice they are still in great shape. The mechanic who is doing my engine install really wants me to switch back to stock HP manifolds for all the reason we know, they burn the wires, they get in the way of lots of stuff and generally take up too much room. He found some stock HP manifolds on Year One for about $650 (I had no idea they were being reproduced)and was asking me if i wanted to put them on in place of the headers. He feels that the stock HP manifolds will flow almost as good as the long tube headers. He is doing some massaging on the tubes to give more clearance for the wires and switching some of the 90 degrees plug ends to straight boots so help as well.
I am going to stay with the existing TTI headers myself, but thought i would get some input on this from you all if they stock manifolds are worth the extra hassle for any HP gains?
Stu
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317340
06/06/17 09:58 PM
06/06/17 09:58 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I switched from Hooker Super Comp to HP exhaust manifolds.I see very little difference at low rpms. When I get on it you can feel a difference up top, not much but its there. Depends on your build. Im running the MP .528 mechanical which is ideal with manifolds. To me the ease of starter removal, no burnt wires and no maintenance out weighs the Headers headaches. $650 is too much for repo manifolds. You can get originals for
$400 or less.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317347
06/06/17 10:04 PM
06/06/17 10:04 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
There are a lot of good reasons to run manifolds, but to say they flow "almost as good" as your TTIs is simply not true.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Headers vs stock exhaust manifolds. Opinions? [Re: wingman] #2317352
06/06/17 10:09 PM
06/06/17 10:09 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I would use what you have. They fit the modified theme anyway.
Sheldon
Re: Headers vs stock exhaust manifolds. Opinions? [Re: wingman] #2317354
06/06/17 10:10 PM
06/06/17 10:10 PM
That was my impression as well that they flow way better then stock, so much so it's worth the small hassles.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: wingman] #2317356
06/06/17 10:12 PM
06/06/17 10:12 PM
dogdays Offline
dogdays  Offline
Plus, he's got it wrong that flow is the main issue. Separation of the exhaust pulses is the more important function of headers. That's why, in a well designed test, headers increase torque below the torque peak as well as above. A well designed tunnel ram has the same advantages, just on the other side of the flow path.
Some of the four cylinders in the last half of last century used a cast iron manifold that went from 4 to 2 and then it was tubes until the collecter. The 4-2-1 header. This is really successful in a 4-banger or a V8 with a 180 degree "flat" crank. It's also the reason that circle track headers often have a tube or two swapping between the banks.
R.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317479
06/07/17 02:23 AM
06/07/17 02:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have over 10,000 miles on my TTI 2" pipes. I have never burned a plug wire and have not burned out or worn out a starter. If you build it right, the plug wires, starter and everything else will not be a problem.
It cracks me up these guys that tout the advantages of stock exhaust manifolds.
I see guys at car shows blab about how the engine needs backpressure to run right.
If you never go past 1/3 throttle or over 2800 rpms, the manifolds are probably just fine.
The only advantage I see with manifolds is fitment. They fall short in every other category.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: Kern Dog] #2317505
06/07/17 05:28 AM
06/07/17 05:28 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Since it is not a daily driver, don't have to worry about rust out, re using the existing headers is probably what I would recommend.
I would put a new quality starter on it while it is apart tho.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317512
06/07/17 07:12 AM
06/07/17 07:12 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
I was watching a you tube vid the other day, they had a reasonably built hemi on the dyno, they swapped the headers for a set of exhaust manifolds, now bearing in mind that hemi exhaust manifolds are pretty exceptional pieces in themselves, the hemi dropped 65 HP, food for thought !
Re: Headers vs stock exhaust manifolds. Opinions? [Re: wingman] #2317513
06/07/17 07:28 AM
06/07/17 07:28 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The mechanic is wrong.
I went from manifolds to Dougs headers on my small block and picked up 70+ hp.
Car went from a best of 14.2 to 13.0
"I think its got a hemi"
Re: Headers vs stock exhaust manifolds. Opinions? [Re: wingman] #2317521
06/07/17 08:50 AM
06/07/17 08:50 AM
crlush Offline
crlush  Offline
iagree
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317530
06/07/17 09:24 AM
06/07/17 09:24 AM
MA
steve70 Offline
steve70  Offline
MA
I had a great local shop build a 340 stroker motor for me but I wanted stock carb and manifolds as it's going in an OE restoration. He broke the engine in using his favorite Holley carb and headers. After break-in the final numbers were 397 HP-465 TQ. After he swapped over to stock exhaust manifolds and thermoquad the final numbers were 395HP-443 TQ
1970 Challenger T/A 4 speed
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317563
06/07/17 11:27 AM
06/07/17 11:27 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What cam and heads are you running? That will really dictate how much those headers are benefiting you. If your cam and heads are pretty tame, the headers may not be better enough to really justify them. I mean, you have them already so I wouldn't change them because coated TTI headers aren't exactly the same as the summit cheapo junkies, so yeah.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: DaytonaTurbo] #2317573
06/07/17 11:38 AM
06/07/17 11:38 AM
Yea, i am keeping the TTIs but was just wondering about how much the gain in HP is worth the hassles of headers after we started discussing it.
In fact thinking back I can't remember a car i owned that didn't have headers on it except for a daily driver.
Stu
Re: Headers vs stock exhaust manifolds. Opinions? [Re: crlush] #2317591
06/07/17 12:11 PM
06/07/17 12:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
iagree
Might be a few exceptions!! work
Re: Headers vs stock exhaust manifolds. Opinions? [Re: steve70] #2317617
06/07/17 01:12 PM
06/07/17 01:12 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
I am willing to bet that you were using stock heads on this build and the reason your hp didn't change is because your heads are the biggest cork in engine. if you swapped heads to Edelbrocks or something similar and the redo the test you would see a very large difference between headers and manifolds. Stroker motors can push a lot of air at a lower RPM but you quickly find the limit of flow in the heads.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317625
06/07/17 01:23 PM
06/07/17 01:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
On a mild 383 with a fairly small cam, the difference is probably only like 20hp.
I've dyno tested several stroker FAST builds, and I can tell you the volumetric efficiency of those motors is really quite low, especially for the level of effort involved with the builds.
I'd say that most of the ones I tested would have easily made 100hp more with headers, and maybe a cam swap........ But probably 50-70hp from the headers alone.
How much difference you'd see depends on what you're testing.
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317643
06/07/17 02:20 PM
06/07/17 02:20 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I'm just going to go weep in the corner!! Stupid rules!!!! A conserative 50 hp! "The sound of someone softly weeping"
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Headers vs stock exhaust manifolds. Opinions? [Re: FurryStump] #2317651
06/07/17 02:38 PM
06/07/17 02:38 PM
RUNCHARGER Offline
RUNCHARGER  Offline
On a stock 383 with a good exhaust system I would guess 20HP gain with the headers as well. I have swapped headers onto stock engines and not felt much gain. On a built 440 with street ported heads and camshaft you would see more of a gain. IMHO.
Sheldon
Re: Headers vs stock exhaust manifolds. Opinions? [Re: MidPenMopar] #2317662
06/07/17 02:57 PM
06/07/17 02:57 PM
IMGTX Offline
IMGTX  Offline
Headers all the way.
There is something about the sound of headers that is just right for a musclecar. Stock Cast iron manifolds don't cut it and sound kinda boring and anemic.
