Re: Adjusting brake drums to eliminate pull [Re: jcastle1] #2321384
06/14/17 11:27 PM
06/14/17 11:27 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
FYI, if anyone is curious about weight of complete 11 inch brake conversion kit
VS complete stock drum brakes-
Stock size disc kit unboxed weighs 98.5 lbs including calipers, pads,
Rotors, hoses, backing plates, spindles, brackets, bearings, and all
Hardware.
I will weigh the complete drum setup after removal and post results
This is the stage 1 kit from Dr. Diff
Re: Adjusting brake drums to eliminate pull [Re: jcastle1] #2321386
06/14/17 11:29 PM
06/14/17 11:29 PM
thank you, weight savings is always important.
Re: Adjusting brake drums to eliminate pull [Re: jcastle1] #2321387
06/14/17 11:29 PM
06/14/17 11:29 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
BTW- I am offering up the old stock drum setup complete in the free section,
for any purists, or if you just need parts. Just pay the actual shipping
John
Re: Adjusting brake drums to eliminate pull [Re: jcastle1] #2323230
06/18/17 06:44 PM
06/18/17 06:44 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Well, yesterday I finished the disc brake upgrade. The only hicccup was having to remove the welded on sway bar tabs on the lower control arms to allow front hanging of the calipers.
Total weight of factory front drum brakes: 96.6 lbs.
Total weight of disc brake upgrade: 98.5 lbs.
Re: Adjusting brake drums to eliminate pull [Re: jcastle1] #2323235
06/18/17 06:52 PM
06/18/17 06:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Where's the face palm smiley?
Don't be the exception.
