Re: 727 Low Band Fails Again!
[Re: 359Inline6]
#2318522
06/09/17 03:33 PM
06/09/17 03:33 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
While installing the rear band, when going to 72 inch/lbs and then back off 2 turns as the books say, I noticed that the drum could not be rotated by hand. I mean that thing was firmly gripped. I took the adjuster out 3 turns (3 turns total not an additional 3 turns) and the drum moves again.
Maybe I was just adjusting the band too tight? Read my first reply (reply #7) to this thread complete with a link to proper adjustments.
[Re: 359Inline6]
#2320867
06/13/17 11:36 PM
06/13/17 11:36 PM
Posts: 14 WA
359Inline6
WA
Hmm guess the 3 turns out was not it. Just lost reverse yet again. 3 days after rebuild and did not even have time to check line pressures. Quickest yet, what a pain. Maybe it was the missing #7 check ball. Looks like its transmission swap time.
[Re: 359Inline6]
#2321073
06/14/17 01:37 PM
06/14/17 01:37 PM
Posts: 20,651 in a cattle trailer down by th...
Guitar Jones
I would get another valve body. However can't you get the instructions from TransGo and go through it making sure everything is correct?
I built transmissions at a Dodge dealer for over 3 decades and never used the factory band adjustment procedure. I would seat the band making sure everything is straight then back off the adjustment screw until I had about 3/8" clearance between the rod and lever with the lever pried down with a screw driver. The old trans guy at the dealership taught me that and I've never had a problem with it.
[Re: 359Inline6]
#2321140
06/14/17 03:51 PM
06/14/17 03:51 PM
John_Kunkel
Rio Linda, CA
Maybe it was the missing #7 check ball. Looks like its transmission swap time. Not sure what you're referring to as the #7 check ball but, if it's the one in the transfer plate that feeds the rear servo, removing it is hard on the servo and band components. Without the control orifice 300 psi slams the servo in Reverse
[Re: 359Inline6]
#2321780
06/15/17 08:20 PM
06/15/17 08:20 PM
John_Kunkel
Rio Linda, CA
John_Kunkel , have you seen that check ball be left out before with similar results? I bet you are right on the check ball causing this.
From my experience, removing the check ball results in broken pieces i.e. band, anchor links, servo piston etc. even a case split at the band lever pin. IMHO, the two check balls in the later transfer plate (rear clutch and rear servo) are the best change Ma Mopar ever made to the TF; removing them makes no logical sense yet the major kit makers have you remove them.
