Re: Wonder how Musclepalooza went 2day for the Mopar gang? [Re: fullmetaljacket] #2313303
05/29/17 11:43 PM
05/29/17 11:43 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Ratings are for sustained high speed driving. Drag cars are only going fast for a quarter mile. That is not long enough for heat to build up in the Tire. If you drove them a hundred fifty miles an hour for 20 or 30 minutes, you might have an issue. Tires fail from heat build-up, not from centrifical force at 140 miles an hour. Back in the 60s and 70s, guys drove 150 Plus on these tires down the street quite regularly. In 1976 a school friend of mine went 152 in his GTX with polyglas tires and got the ticket to prove it.
Fast racing is a grassroots amateur event. You will find the same typical safety equipment compliance and violations in fast cars as you do at any event made up of amateur racers. Some racers are by the book and safety conscious and do everything they can. Other racers are either oblivious to safety issues or will only do what the tracks enforce to save money or save weight. Does every car have an SFI approved clutch and flywheel? I doubt it. Is there more than 12 inches of rubber hose on some cars? Of course. Electric fuel pumps without a safety shut off? Probably. Are there cars running High elevens on a factory lap belt? Yes.
From what I have seen, most of the cars that have made it into the tens are legal or pretty close to it. There have only been a dozen or less passes in the nines, but obviously that is an issue that needs to be addressed by the owners. it would not surprise me if Dave comes back with a cage and a window net at some point.
Re: Wonder how Musclepalooza went 2day for the Mopar gang? [Re: fullmetaljacket] #2313353
05/30/17 01:09 AM
05/30/17 01:09 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted By fullmetaljacket
I'm sure Dave Dudek went in the single digits again or broke his own record.
I know some others (GM's) are knocking on his door.
I called ya,,,drove up by myself on Sunday. The DA was 3000ft eek
https://www.youtube.com/watch?v=SSMm6RG_owg
https://www.youtube.com/watch?v=XoTwAmY3zy8
They busted Freddys shoes for going 30's
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Wonder how Musclepalooza went 2day for the Mopar gang? [Re: hemi-itis] #2313952
05/31/17 12:36 AM
05/31/17 12:36 AM
fullmetaljacket Offline OP
Freddy went 11.30's?
Re: Wonder how Musclepalooza went 2day for the Mopar gang? [Re: fullmetaljacket] #2314023
05/31/17 02:35 AM
05/31/17 02:35 AM
hemi-itis Offline
hemi-itis  Offline
Yes at 3000 Da!!!Last pass he dumped at the line slowing to like a .50 to keep tech off his back.
https://www.youtube.com/watch?v=8gUGqJWez00
Re: Wonder how Musclepalooza went 2day for the Mopar gang? [Re: fullmetaljacket] #2314024
05/31/17 02:40 AM
05/31/17 02:40 AM
hemi-itis Offline
hemi-itis  Offline
Re: Wonder how Musclepalooza went 2day for the Mopar gang? [Re: fullmetaljacket] #2314025
05/31/17 02:44 AM
05/31/17 02:44 AM
hemi-itis Offline
hemi-itis  Offline
