Re: Pictures fuel pressure regulators
[Re: Al_Alguire]
#2313579
05/30/17 02:47 PM
05/30/17 02:47 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I have 3 mounted up front...one for the carb, one for the nitrous, the other return to set the head pressure.
[Re: Thumperdart]
#2313686
05/30/17 05:46 PM
05/30/17 05:46 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I made a little cluster for my cowl to see vacuum and fuel pressure another great way to see pv opening/closing points also......... So you mounted yours on your cowl ? Course the only ones I would put in the car are the ones that use a type of antifreeze I believe that goes from the gauge dampner into the car. Ron
[Re: 383man]
#2313708
05/30/17 06:19 PM
05/30/17 06:19 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
After the carb so carb always sees cool fuel
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: scottb]
#2313725
05/30/17 06:48 PM
05/30/17 06:48 PM
Posts: 2,363 PA
70HemiGTX
PA
Mine on my Dart. It looks like the rear fuel line is laying on the header, but it isn't. There is about 4 or 5" between them.
[Re: 1mean340]
#2313728
05/30/17 06:53 PM
05/30/17 06:53 PM
Triple Threat
Renton Washington
You can kind of see it on the passenger side firewall back there. I needed a pretty big open space to mount it as I have a Y block attached it (dual feed to the FITECH throttle body, deadheaded at the throttle body and have the return out the bottom of the regulator). FYI, PER NHRA rules, you can't mount the regulator on the firewall. If you ever plan to race it, you'll want to move that.
[Re: 383man]
#2313789
05/30/17 08:40 PM
05/30/17 08:40 PM
Thumperdart
State of confusion
I made a little cluster for my cowl to see vacuum and fuel pressure another great way to see pv opening/closing points also......... So you mounted yours on your cowl ? Course the only ones I would put in the car are the ones that use a type of antifreeze I believe that goes from the gauge dampner into the car. Ron Can't send pics here but on FB you can see it and yes, I bolted that puppy straight on my cowl area which is blocked off anyhow..........
[Re: Thumperdart]
#2314000
05/31/17 01:38 AM
05/31/17 01:38 AM
383man
Balt. Md
I made a little cluster for my cowl to see vacuum and fuel pressure another great way to see pv opening/closing points also......... So you mounted yours on your cowl ? Course the only ones I would put in the car are the ones that use a type of antifreeze I believe that goes from the gauge dampner into the car. Ron Can't send pics here but on FB you can see it and yes, I bolted that puppy straight on my cowl area which is blocked off anyhow.......... I will check it out on FB. Thanks , Ron
