Re: Pictures fuel pressure regulators [Re: scottb] #2313556
05/30/17 02:10 PM
05/30/17 02:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: Pictures fuel pressure regulators [Re: Al_Alguire] #2313579
05/30/17 02:47 PM
05/30/17 02:47 PM
an8sec70cuda Offline
I have 3 mounted up front...one for the carb, one for the nitrous, the other return to set the head pressure.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Pictures fuel pressure regulators [Re: Thumperdart] #2313686
05/30/17 05:46 PM
05/30/17 05:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By Thumperdart
I made a little cluster for my cowl to see vacuum and fuel pressure another great way to see pv opening/closing points also......... beer
So you mounted yours on your cowl ? Course the only ones I would put in the car are the ones that use a type of antifreeze I believe that goes from the gauge dampner into the car. Ron
Re: Pictures fuel pressure regulators [Re: 383man] #2313708
05/30/17 06:19 PM
05/30/17 06:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
After the carb so carb always sees cool fuel
Re: Pictures fuel pressure regulators [Re: 1mean340] #2313713
05/30/17 06:26 PM
05/30/17 06:26 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Originally Posted By 1mean340
You can kind of see it on the passenger side firewall back there. I needed a pretty big open space to mount it as I have a Y block attached it (dual feed to the FITECH throttle body, deadheaded at the throttle body and have the return out the bottom of the regulator).
How do you like that fitech set up..
Re: Pictures fuel pressure regulators [Re: scottb] #2313725
05/30/17 06:48 PM
05/30/17 06:48 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Mine on my Dart. It looks like the rear fuel line is laying on the header, but it isn't. There is about 4 or 5" between them.
Re: Pictures fuel pressure regulators [Re: 1mean340] #2313728
05/30/17 06:53 PM
05/30/17 06:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
FYI, PER NHRA rules, you can't mount the regulator on the firewall. If you ever plan to race it, you'll want to move that.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Pictures fuel pressure regulators [Re: scottb] #2313781
05/30/17 08:27 PM
05/30/17 08:27 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Nice win Dustin!
Re: Pictures fuel pressure regulators [Re: 383man] #2313789
05/30/17 08:40 PM
05/30/17 08:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can't send pics here but on FB you can see it and yes, I bolted that puppy straight on my cowl area which is blocked off anyhow..........
Re: Pictures fuel pressure regulators [Re: Thumperdart] #2314000
05/31/17 01:38 AM
05/31/17 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I will check it out on FB. Thanks , Ron
Re: Pictures fuel pressure regulators [Re: scottb] #2314192
05/31/17 03:09 PM
05/31/17 03:09 PM
Is this for a race car or street car?
If a race car always mount it in front of the carb., carbs so gravity doesn't limit the flow to the front fuel bowls under WOT acceleration up work
Re: Pictures fuel pressure regulators [Re: scottb] #2315123
06/02/17 02:17 PM
06/02/17 02:17 PM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
Earthmover, not running yet so couldn't say. Should be ready soon, just waiting on a few parts so I can finish welding the intercooler piping up and need to wire it all.
Triple threat, nearest track is 3 hours away so the car sees the track maybe twice a year and it's always for rentals that my friends do where there is no tech inspection. I try to follow NHRA rules anyway just for safety whenever possible, but this was one of those things I didn't see being a major safety issue over other 'legal' ways of mounting it.
