Re: Prepping a surface rust (desert) panel for primer? [Re: NV69B7RR] #2425284
12/29/17 12:06 PM
12/29/17 12:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Originally Posted By Stanton
And if you blast it ... you will still have pits of rust that were too small for the blast media. Blasting is NOT a solution to rust unless you're refurbing a bridge. Get rid of the majority however you choose BUT the surface absolutely has to have a final treatment with a liquid that will either remove or convert the minute rust pits.
you seem to know lots about blasting sheet metal. whats your experience in blasting cars other than what you read on the internet?
My experience "blasting" is not important, what is important is my experience in rust removal and I'd say I have a fair bit of that! So you're a professional blaster? Great! Would you make the statement that blasting will remove every minute particle of rust? Didn't think so.
Re: Prepping a surface rust (desert) panel for primer? [Re: Stanton] #2426817
12/31/17 11:19 PM
12/31/17 11:19 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
One of my friends uses towels and vinegar. Seems to work for him. shruggy
Re: Prepping a surface rust (desert) panel for primer? [Re: dvw] #2426882
01/01/18 01:07 AM
01/01/18 01:07 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted By dvw
I used Metal Prep and Scotch-Brite. Some of the deep pits I used a pic. Even if there is any small amount of rust left it will be converted and inert. 5 years no issues.
Doug
Me too. Was taught that a long time ago.
What I use - from Google:
The shop I frequent uses Cromax products (formerly DuPont). 5717S etching solution and 5718S neutralizer. The 5717S is a concentrate that is diluted in water and scrubbed via Scotchbrite and rinsed off. The 5718S is then applied full strength and rinsed off.
