Re: Crank not deep enough for converter nose
[Re: Clanton]
#2311498
05/26/17 12:59 PM
05/26/17 12:59 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
You can see how abused this is.I can get a framing square from tab to tab and mic the depth from the edge of the square.Is this the correct way? a rough measurement shows a .256 nose past the mounting tabs so add what warn off the nose .004 maybe so .260. Correction the measurement is .200 ,I used a metal ruler this time that was 1' and I got a better measurement.Sorry!
[Re: Clanton]
#2311534
05/26/17 02:21 PM
05/26/17 02:21 PM
Clanton
northern,Ohio,USA
The flex plate offset lets the TC in .318 1 last measurement is the vert bolt pad from the front of the trans is .520 as installed.
[Re: Clanton]
#2311938
05/27/17 10:45 AM
05/27/17 10:45 AM
Clanton
northern,Ohio,USA
While all that measuring ,drawing is good I still want to check physically and I have no help so I may have to put the block on the floor and put the crank in and flexplate and hold the vert to the crank to see what it measures with feelers. ps:I just fitted the crank,vert together and no problems fits nice up to the flexplate.so much for that!it does bottom in the pilot hole so I think it could use some room like .010 off the nose of the vert.
[Re: Clanton]
#2312805
05/29/17 09:18 AM
05/29/17 09:18 AM
Clanton
northern,Ohio,USA
Just .129 too long on the nose. +/- The 1 mistake I made in my drawing is the flex plate should be back .100 from the crank flange where I measured from the bolt surface.This also moves back the nose of the vert measurement.
[Re: Clanton]
#2313162
05/29/17 07:24 PM
05/29/17 07:24 PM
dartman366
Mt. Vernon, Ohio
If you used the hardened pump gear it go's in one way with the bulk of the drive tang length toward the tranny not toward the engine.
[Re: dartman366]
#2313185
05/29/17 08:13 PM
05/29/17 08:13 PM
Clanton
northern,Ohio,USA
If you used the hardened pump gear it go's in one way with the bulk of the drive tang length toward the tranny not toward the engine. Thank, you for the info!Now to get it fixed.
[Re: Clanton]
#2313200
05/29/17 08:56 PM
05/29/17 08:56 PM
dartman366
Mt. Vernon, Ohio
If you used the hardened pump gear it go's in one way with the bulk of the drive tang length toward the tranny not toward the engine. Thank, you for the info!Now to get it fixed. I failed to tell you that the side that go's toward the engine will have a fairly large champher to help the hub engage the gear also.
[Re: dartman366]
#2313237
05/29/17 09:39 PM
05/29/17 09:39 PM
Clanton
northern,Ohio,USA
If you used the hardened pump gear it go's in one way with the bulk of the drive tang length toward the tranny not toward the engine. Thank, you for the info!Now to get it fixed. I failed to tell you that the side that go's toward the engine will have a fairly large champher to help the hub engage the gear also. Ya I can't see that either and will try to locate it with a hanger i have with a hook on the end.I am catching a chamfer and did my best to measure more to the center and got .700 with the TC slot at .660 from the wear on it in the center. PS:I know you are tired of hearing from me,sorry I called TCI and they gave me what comes to 5.688 and when I measure my output shaft in the trans to the pump bottom I get 5.685 and that leaves no pump to drive hub room in which they want .125 to .187. If you can help ok thank you.
[Re: PorkyPig]
#2314048
05/31/17 08:14 AM
05/31/17 08:14 AM
Clanton
northern,Ohio,USA
Are there any standard dimensions for the depth of the crank pilot hole and the length of the converter snout? The std dimension is .188 that I can tell and my nose is about .210 measuring from the tab on the vert to the nose of it with a straight edge and dial caliper.I figure I could answer a couple question in this topic.
[Re: Clanton]
#2314255
05/31/17 05:55 PM
05/31/17 05:55 PM
Clanton
northern,Ohio,USA
Thank you John Cope for some tech help !The pump tab is .209 to .193 below the top of the gear so from the pump bottom to the top of the tab is .547 ish and close to the wear on my drive hub on the vert so this will help a lot in getting things cut correct.
