Re: 383 piston selection [Re: 70Cuda383] #2312320
05/28/17 11:24 AM
05/28/17 11:24 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Mancini Racing Or 440 Source 432/438 Stroker Kit ???
Anyone of these kits better then the other , never have dealt with 440 Source but have bought plenty of items from Mancini Racing
Anways
Just want a reliable option for a street driven numbers matching 383 Block that is already .030 over and my machine shop wants the pistons in hand before anything
Edelbrock E Street Heads 75cc
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 383 piston selection [Re: 70Cuda383] #2312527
05/28/17 06:57 PM
05/28/17 06:57 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I keep an eye on eBay for the old TRW 2293's. Can usually get a set for under $200. I've run them in 3 motors now. Even dropped a valve into one. Just swapped it out and kept on truckin'
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 383 piston selection [Re: 70Cuda383] #2312548
05/28/17 07:25 PM
05/28/17 07:25 PM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
Anyone have back to back flow numbers on stealth vs eddy E street on the same bench? Are they that much better? The straight plug of the stealth is appealing because I know it'll work with his headers. I don't know that angled plugs will clear
**Photobucket sucks**
Re: 383 piston selection [Re: 70Cuda383] #2313518
05/30/17 12:54 PM
05/30/17 12:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
What headers does he have?
Rich H.
Esse Quam Videri
Re: 383 piston selection [Re: ZIPPY] #2313638
05/30/17 04:38 PM
05/30/17 04:38 PM
dogdays Offline
dogdays  Offline
Rod Length / Stroke ratio IS the parameter that determines dwell time at TDC and rates of deceleration and acceleration of the piston around that point.
R.
Re: 383 piston selection [Re: 70Cuda383] #2313643
05/30/17 04:41 PM
05/30/17 04:41 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
you're working to build compression and the 75cc chamber of the edelbrock e street head is going to help with that.
