Re: 1971 Roadrunner with factory Carter AVS
[Re: ScottSmith_Harms]
#2306379
05/17/17 11:12 PM
05/17/17 11:12 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
What engine? Do you have the broadcast sheet? The application is a 71 Plymouth Road Runner with a 383 automatic. He's looking for proof that they may have come with an AVS
#2306410
05/18/17 12:19 AM
05/18/17 12:19 AM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
No AVS, which Holley it had would depend on several things, N96 or not, etc. your next question will be do you have something to back that up?? lol
#2306554
05/18/17 08:57 AM
05/18/17 08:57 AM
Posts: 3,337 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
What engine? Do you have the broadcast sheet? Per the OP in another post, broadcast sheets are only for statistical purposes and not at all related to what was actually installed on the vehicle ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif)
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: Butterscotch71]
#2306628
05/18/17 12:24 PM
05/18/17 12:24 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
What engine? Do you have the broadcast sheet? Per the OP in another post, broadcast sheets are only for statistical purposes and not at all related to what was actually installed on the vehicle Statistacal yes but I never said it was unrated to equipment installed on vehicle. Now your putting words in my mouth.
#2306714
05/18/17 01:50 PM
05/18/17 01:50 PM
L.R Helbling
Ottawa, Ontario
What engine? Do you have the broadcast sheet? There is no broadcast sheet that came with the car. On closer inspection, it looks like something was attached to the exhaust manifold on the left side. This by itself, is not proof of anything because I don't know if these manifolds are original to the car, but there is a small broken stud on what looks to be a mount for something. Could this be old evidence of a hot air stove?
[Re: L.R Helbling]
#2306730
05/18/17 02:19 PM
05/18/17 02:19 PM
Butterscotch71
Lost Title
Lost Title
What engine? Do you have the broadcast sheet? Per the OP in another post, broadcast sheets are only for statistical purposes and not at all related to what was actually installed on the vehicle Statistacal yes but I never said it was unrated to equipment installed on vehicle. Now your putting words in my mouth. from the other thread... "Can't help you, chum if you don't believe what I'm telling you. Holley R4668 carbs were put on Roadrunners with heated air intakes like I mentioned in a previous post. Mine never came with that option so I got the Carter AVS. Typical numbers found on broadcast sheets are fine for statistical purposes but they do not describe the rules for putting which carb on which car. FSM does."
[Re: flypaper]
#2306752
05/18/17 02:43 PM
05/18/17 02:43 PM
Posts: 16,164 Mesa, Arizona
dart4forte
Mesa, Arizona
My 71 RR had the N96 option. Car use to belong to 340shorty who has passed on. He was the original owner. According to him the car came with a Holley. The car was a 383, auto on the column.
Abe Lincoln
[Re: Pacnorthcuda]
#2307026
05/18/17 10:01 PM
05/18/17 10:01 PM
flypaper
I hate Texas
I hate Texas
jersey shore
L.R.H.
You need to find a BS sheet showing an AVS installation on said car.
Got it now? ahh Captian Obvious tried to tell him that before but he threw him overboard and he continued to paddle on his own! ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: L.R Helbling]
#2307040
05/18/17 10:19 PM
05/18/17 10:19 PM
Posts: 765 Shoreline, Washington
72roadrunnergtx
"general rules that describe what carb goes into what engine/tranny combo are found in the FSM"
The factory service manuals do not define “rules” as what engine/trans combo is used in what body line. As already posted in the wing nut thread, the FSM only provides information about processes and specifications necessary to service and maintain the various vehicle components, arranged by component groupings, or systems, and covering the FSM’s brand (Dodge or Chrysler/Plymouth FSM) full body line. The factory parts catalogs sole function is to accurately define factory replacement part numbers based on the original part applications. In this case, once the correct carline code is understood and applied, the ’71 parts catalog clearly shows the 6125S was used on a 383 variant used for C-bodies only and all B&E body 383HP applications having Holleys originally. Any third-party documentation that counters this, or fails to show any Holleys, is just wrong.
