Re: Will Doug Headers fit as good as TTI,s? [Re: SomeCarGuy] #2305399
05/16/17 09:45 AM
05/16/17 09:45 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Originally Posted By SomeCarGuy
Aren't there two Dougs? Doug Thorley Headers and Dougs. Heard years ago he got a divorce so there were/are two companies.
Yes
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2305645
05/16/17 06:46 PM
05/16/17 06:46 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Don't see many discussions on Headers on here where people add in the Hedman Husler headers, Ive had a set for about 15 years that have been very good ones. They are made for RB engine with Indy raised exhaust ports. Very good race header that would work on thye street to.
Re: Will Doug Headers fit as good as TTI,s? [Re: max_maniac] #2307416
05/19/17 03:13 PM
05/19/17 03:13 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Yes
Ive been pretty busy but I've been doing a lot of research lately and I'm surprised how many people have rust issues with their TTI,s also and I like how the Dougs are stitched up at the flanges but the TTI,s are beautiful but now I'm starting to lean towards the Dougs.
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307476
05/19/17 04:51 PM
05/19/17 04:51 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
The only problem with the Doug's headers for your build is that they're only available in a 2" primary. That is too big for a mild 440. I saw this first hand when we dyno'd my old 446 and the 2in headers cost 20ftlbs of torque across the entire test range vs the 17/8's. Horsepower remained the same for both sets of headers.
This was on a street/strip pump gas 446 making 535hp/540tq.....probably close to what the OP's engine will be making. The conclusion was obvious ; the larger tube cost some low end grunt.
At the time I had purchased a set of 2in TTI's but knew that I would be going stroker in the future but just wanted to see a fact based comparison between both sizes in the name of information/data gathering.
My 2in TTI's were ordered "bare" and I had them ceramic coated locally and they've held up fine for several years. Some dulling on the primary tubes near the port exit but zero rust issues.
I would stongly consider going with the 17/8 primary TTI's and have them coated locally so if there are any warranty issues with the coating it won't be a big hassle.
Charger's are heavy beasts....I know because mine weighs 4150 race ready. No way would I give up 20 ftlbs of torque that I didn't have to. This is basicly free power for just making the right choice with a header primary size...
Ron
Re: Will Doug Headers fit as good as TTI,s? [Re: firefighter3931] #2307503
05/19/17 05:31 PM
05/19/17 05:31 PM
eastern,Ky
eastern,Ky
Ron
I hope and pray my build does better than that. I figured I was close enough in power to run the 2". 10:7.1 Compression on Zero deck, square decked,TF 240 heads, MP dual plane intake, comp XR 286 HR Cam, (236/242@50 544 lift) Mancini 1.6 Roller Rockers, 850 or 950 Carb. I'm not no pro builder like you guys but I was guessing at least 550+ HP. I'll buy the TTI,s if I have to. Thanks Ron
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307511
05/19/17 05:38 PM
05/19/17 05:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
A stock stroke 440 based build with a dual plane manifold and a cam that's 236/242 @.050 isn't going to have a powerband high enough to be able to exploit a 2" header....... IMO.
Re: Will Doug Headers fit as good as TTI,s? [Re: fast68plymouth] #2307514
05/19/17 05:43 PM
05/19/17 05:43 PM
eastern,Ky
eastern,Ky
OK thanks! TTI,s it is then. Thanks again guys!
Re: Will Doug Headers fit as good as TTI,s? [Re: fast68plymouth] #2307539
05/19/17 06:34 PM
05/19/17 06:34 PM
Ontario,Canada
Ontario,Canada
Good info.....Dwayne would know because he built my 446 and conducted all of the dyno testing noted above. wrench
70Charger...The cam in my 446 was also quite a bit bigger (duration) than the 236* cam that will be used in your build. Mine also had a low rise single plane (Street Dominator) which tends to pull better up top vs a dual plane RPM...at least it did on my motor.
All that being said....the best choice based on hard data would be the 17/8. Just do it and rest easy. apimp
Ron
Re: Will Doug Headers fit as good as TTI,s? [Re: firefighter3931] #2307550
05/19/17 06:47 PM
05/19/17 06:47 PM
eastern,Ky
eastern,Ky
Ron
Im doing it Ron lol Thanks buddy!
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307584
05/19/17 07:44 PM
05/19/17 07:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
Ron's 446 was subjected to over 90 dyno pulls, and we tested 3 sets of headers, 4 or 5 intake manifolds, several carbs, spacers, timing, and two camshafts.
Sure, the "biggest" of everything made the most hp....... But the low end TQ was waaay down compared to some of the more common street set-ups we tried.
Re: Will Doug Headers fit as good as TTI,s? [Re: fast68plymouth] #2307603
05/19/17 08:14 PM
05/19/17 08:14 PM
eastern,Ky
eastern,Ky
Wow! What heads?
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307606
05/19/17 08:15 PM
05/19/17 08:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
Stage 1 RPM heads.
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307615
05/19/17 08:31 PM
05/19/17 08:31 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
while we are on the topic of kinda hot street motors like this, are the larger port heads like the 240 trick flows going to hurt the lower rpm torque much (say vs. a stage 1 rpm head) ??
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307626
05/19/17 08:44 PM
05/19/17 08:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
That falls into that "it depends" catagory.
As for the OP's quest for 550hp......
#1..... The dyno X factor. Numbers can vary greatly between dynos..... So unless you're dyno testing at a facility where you know how the numbers/performance work out...... Don't get too worked up about "the number".
Use the dyno to test a few easy items.... Carbs, spacers, fuel, timing, etc....... Get the rings seated, make sure the oil pressure is stable, no funky noises........try and get the tune dialed in.
My feeling on what that motor will make for power could easily be decided by whether or not the valvetrain is stable enough to allow it to reach it's natural peak rpm, or if the lifters give up before the peak is achieved. It's one of the unknowns with a new combo, especially with hyd lifters.
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307628
05/19/17 08:52 PM
05/19/17 08:52 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I love my Doug's D452 headers,they fit perfect and still look good after over 5 years. My engine is a 493 with a mild solid flat cam and Indy EZ heads that probably flow like your TF heads do. Plug boots clear and never burn and the only place they were close was the flange on my steel bell and the grease fitting on the pitman arm.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Will Doug Headers fit as good as TTI,s? [Re: fast68plymouth] #2307661
05/19/17 10:12 PM
05/19/17 10:12 PM
Ontario,Canada
Ontario,Canada
Yep, that motor was well "broken in" before it was installed in the car. That was a fantastic learning experience for me and it certainly expanded the knowledge base.
FWIW, that combo ran great on the street and did very well at the track for a 10.25:1 compression, stock stroke, pump gas build. OH ya, it was very basic ; stock forged crank, LY rods, Heavy 6-pack pistons. Nuthin fancy except the quality machine work, PRH prepped E-heads, PRH custom solid cam and attention to detail. cool Best ever ET was 11.68@116.5 which is amazing given that this was/is a 4150lb street car. I remember running against a few 500in street stroker builds in lighter cars and putting them on the trailer. up
Ron
Re: Will Doug Headers fit as good as TTI,s? [Re: firefighter3931] #2307674
05/19/17 10:36 PM
05/19/17 10:36 PM
eastern,Ky
eastern,Ky
Those are some good numbers for sure. The pistons I'm using are Racetec and they weigh 670 grams attached to ly rods and ARP rod bolts, steel crank turned and I did go hydraulic roller cam as recommended here for the 1.6 Rockers because I wanted to stay hydraulic. I hope this build works out good for me. I'm still undecided on which and what size Carb. The motor will build what it will build in hp. I just want a good street car. Figured it would have 550+ hp but if it don't that's fine to.
Re: Will Doug Headers fit as good as TTI,s? [Re: 70RT Charger] #2307793
05/20/17 08:45 AM
05/20/17 08:45 AM
Ontario,Canada
Ontario,Canada
Those pistons are significantly lighter than mine....should spin up real nice. With that cam it will be done at 6000 so there's no point in over revving it past that point, especially with the hyd lifters which don't like high rpm anyway. wink
The TF240's are better than a stage1 RPM head, no doubt. The choke point is going to be the RPM intake manifold. Overall it's a well matched combo with the dual plane and that cam....they will play well together. I'd look at a quickfuel 850 DP'er to top it off.
That is a nice cam....a friend ran that same grind in a similarly built 440 in his 71 roadrunner. Nice lope at idle and strong throttle response. Fried the tires at will. He was running 3.55 gears and a 3k stall. cool
Ron
Re: Will Doug Headers fit as good as TTI,s? [Re: firefighter3931] #2307801
05/20/17 09:08 AM
05/20/17 09:08 AM
eastern,Ky
eastern,Ky
Ron
Ok thanks for the advice Ron. I can't wait to get it together. With my 3.91 gears and T-56 magnum it should be fun to drive.
