Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303832
05/13/17 01:59 PM
05/13/17 01:59 PM
Dirty Dena, Maryland
dodge turbo Offline OP
Mr Jbody awesome!
Thanks for the replies
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2304203
05/14/17 09:22 AM
05/14/17 09:22 AM
A727Tflite Online content
A727Tflite  Online Content
If that is your shift lever peeking in the picture - just to the left of your thumb - that bracket is way off. The hole should be more in line with the vertical support - not close to the cooler line fitting. Just like the bottom most picture.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2304325
05/14/17 02:16 PM
05/14/17 02:16 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It looks like that you have room to move the cable hole toward the driver side. This would give you a straighter shot to the lever as well. All of these shifter brackets are not one size fits all and sometimes need tweaking. Whatever you do be careful to keep the same fore and aft distance from the bracket to the lever or you will wind up with a ratio nitemare.
