Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: J_BODY] #2324999
06/21/17 11:42 PM
06/21/17 11:42 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Originally Posted By J_BODY
cold on driver, warm on passenger is usually low charge. The opposite (warm L, cool R) is broken air door more common on the dual zone systems.
Bingo
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2325009
06/22/17 12:01 AM
06/22/17 12:01 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Uh, yeah but mine WAS warm on the left... the drivers side.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2325547
06/23/17 01:15 AM
06/23/17 01:15 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Not trying to rain on your parade but I was told more then once about the leaky schrader valve when the real source of the leak wasn`t found.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2325553
06/23/17 01:26 AM
06/23/17 01:26 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
If nothing else, for a low price, I have some cool air for awhile.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2329791
07/01/17 04:17 PM
07/01/17 04:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Where is this schrader valve located, inside or outside the cab? What does it look like?
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2329798
07/01/17 04:34 PM
07/01/17 04:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Schrader valve is the charging port and it's core. Tire valve stem is a schrader valve of sort.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: stumpy] #2329896
07/01/17 08:03 PM
07/01/17 08:03 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thank you, though it was a big gizmo. My 06 was just recharged and it cools on driver side and hot on pass, so I guess it's low charged. Back to the shop.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2330041
07/02/17 01:27 AM
07/02/17 01:27 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
01 on up we saw a lot of leaks out of the front compressor seal. Hard to detect as it leaks as a vapor and often very slow. After a couple of recharges you can often take brake clean and spray the front of the compressor and you'll often find it drips out in the bright green hue (blacklight/yellow specs) indicating you might have found your issue. Slow leaks on hvac suck!!
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: 383man] #2330428
07/02/17 11:11 PM
07/02/17 11:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes that right as I remember when some were low on freon doing what J-body said. I believe there may be a TSB about the air door problem as I remember fixing a few of them. I left the dealer in 2011 so its been a while since I worked on any. Ron
After what we both said I surely would have had the freon checked in the system first. Heck the dealer I worked at we got like 1.5 to suck all the freon out which tells how much is in it. Then it also included us adding dye and looking for leaks after we filled the system with the proper amount of freon. The cust price was about $139. for that. If we found no leaks then we had the cust come back in a week or two and we checked to see if we could see any dye and find the slow leak. To replace the shrader valve takes about 20 seconds after the freon is pulled out. Cant say we did not tell you as after what J-body and I said I would have had the system charge checked. I just hope the schrader valve is not your only leak. Ron
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2331183
07/04/17 05:14 AM
07/04/17 05:14 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The work order showed that they did an evac, tested with the dye, found the leak at the valve then recharged.
Almost 2 weeks now, the A/C still blows cold like it should. If it fails, I will be honest with everyone about it. I was ready to spend the approx $1500 that the independent shop would have charged, IF it was necessary. I was also considering doing the job myself. I would have had the system evacuated and recharged at the shop but at home I would have pulled the dash and air box to replace the doors inside.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2332157
07/05/17 09:39 PM
07/05/17 09:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
It takes no brains to just replace parts instead of diagnosing the problem. It doesn't matter what you go in for, it's what is done nowadays. I hear these horror stories almost everyday from the mechanic next door. He stays very busy because he knows how to figure out what's wrong. He told me the Dodge dealership just went to $152 an hour and got rid of the old guys.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2332762
07/06/17 09:59 PM
07/06/17 09:59 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
That is terrible. LOOK at the fancy styling and decor of these new car dealerships. It is the SERVICE department and parts department that carries the weight of the store. Vehicle sales are icing on the cake.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: 383man] #2343955
07/26/17 10:38 PM
07/26/17 10:38 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
5 weeks and counting, the A/C is still working great.
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2352453
08/11/17 04:23 PM
08/11/17 04:23 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I always tell my family and customers, that on all the newer cars, I advise everyone to turn the BLOWER FAN SPEED to OFF- BEFORE moving any other nobs on your heater- a/c system.
When you have the fan blowing, and you select either hotter or colder, or any other position for your airflow. You slam the doors into their next position. Eventually , they are going to brake, ESPECIALLY if the fan is on HIGH SPEED!! If you turn the fan off 1st, it makes it so much easier on the doors and actuators!!!!!!!
You never use to brake these doors on your old cars, that were controlled by cables, instead of the newer electric actuated doors.
Brilliant engineering!!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side [Re: Kern Dog] #2352644
08/11/17 11:17 PM
08/11/17 11:17 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thank you for that advice. I appreciate the heads up. thumbs
