Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6
[Re: ghinmi]
#2580778
11/20/18 09:20 PM
11/20/18 09:20 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
What pistons/rods and how much compression/boost now? New clutch and 9s next? ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: ghinmi]
#2580890
11/21/18 01:06 AM
11/21/18 01:06 AM
Posts: 112 Michigan
ghinmi
It's got the MMX drop in piston/rod package. I actually didn't even figure the compression, just slammed them in and sent it. Quick and dirty. It didn't really need them but I just felt more comfortable having them for Drag Week because I'd be so far from home with no backup plan.
I actually put another Hellcat clutch in it a couple days ago. Not sure that it's got enough steam to go 9s but it keeps getting faster so who knows? Definitely didn't expect the 66mm to make as much power as it already has.
It's just a shade under 4000 lbs usually. Was 3960 right after the 10.38 pass.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: ghinmi]
#2581232
11/21/18 07:38 PM
11/21/18 07:38 PM
Silver70
Rust Belt, SW PA
It's just a shade under 4000 lbs usually. Was 3960 right after the 10.38 pass. How much boost are you running now? I'm building a similar combo, little bigger turbo and lighter vehicle... it may end up being quicker than I realize based on what yours run.
[Re: Just-a-dart]
#2581308
11/21/18 10:53 PM
11/21/18 10:53 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
How cool is that!!! Nice ride!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: ghinmi]
#2581333
11/21/18 11:32 PM
11/21/18 11:32 PM
Posts: 2,260 IL
furious70
IL
How much boost/power did you end up making with the stock engine?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: ghinmi]
#2581638
11/22/18 06:44 PM
11/22/18 06:44 PM
Posts: 112 Michigan
ghinmi
The quick pass was on 16 psi. It'll make more but goes slower, all out of turbo. With some fuel pulled out of it I think I can squeak some more boost out of it. And add some timing too. It's a very, very conservative tune.
On the stock stuff it had been 10.50s @ way less mph and a ton better sixty. I forget the mph, sub 130 though. I want to say it was at 10ish psi. It was picking up big power with timing increases but I was afraid of the stock stuff.
[Re: ghinmi]
#2596351
12/24/18 04:41 PM
12/24/18 04:41 PM
Posts: 2,260 IL
furious70
IL
I've got a 76mm T6 that I was going to build an EZ headed 400 from parts I have for my Coronet, but thinking more and more about the 5.7. I'm interested in just taking an OEM pull out and starting rather than building one, don't need crazy power (yet). Just a step up from my Fury's very docile turbo setup.
[Re: ghinmi]
#2597319
12/26/18 10:15 PM
12/26/18 10:15 PM
Posts: 2,260 IL
furious70
IL
What engine management are you using?
[Re: ghinmi]
#2597515
12/27/18 12:14 PM
12/27/18 12:14 PM
Posts: 112 Michigan
ghinmi
It's on holley HP efi. I went with the cable drive throttle body so that I didn't need the Dominator. Kind of wishing I would have sprung for the extra money now for the extra inputs and outputs.
[Re: MuuMuu101]
#2598009
12/28/18 03:37 PM
12/28/18 03:37 PM
Posts: 112 Michigan
ghinmi
Thanks! For autocross and street I've got 17x11 C4 Corvette ZR1 wheels. Cheap and effective. And 275/40zr17 Continental ExtremeContact Sports. It's a tradeoff, I could go a bunch bigger but nobody makes a good 17" tire in wide sizes and the 18" stuff gets expensive. It's working pretty good for the budget wheels/tires though.
