Re: Stupid ? Is it even possible to put the z bar on wrong?
[Re: toplescuda]
#2302954
05/11/17 06:34 PM
05/11/17 06:34 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Well unless someone has one can measure to compare to mine. It's just a crap shot if I have a part that's not right
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2303100
05/11/17 11:11 PM
05/11/17 11:11 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
1) on its own no. Bout half way up. But you can take and pull up by hand pretty easy. It's not in a bind. 2)....... 3)nothen really feels like it's not really connected 4) after it gets past the over center it goes towards floor and rest (on its own) bout same heigth as gas pedal. You can shove the pedal rest way to floor and at that point feels like a normal clutch setup
[Re: toplescuda]
#2303294
05/12/17 12:16 PM
05/12/17 12:16 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
I had exactly the same problem. What is causing this is the difference between a Diaphragm and Borg and Beck style pressure plate and associated throw out bearing.
If you're running a Borg and Beck you'll need a longer adjusting rod for proper clutch movement. Right now the bearing isn't contacting the pressure plate until the clutch pedal is near the floor simply because the pressure plate engagement rods aren't in the same location as a diaphragm pressure plate would be. Lengthening the adjusting rod will allow you to move the resting location of the bearing closer to the pressure plate levers so clutch disengagement will happen closer to the top of clutch pedal movement.
When I swapped to the Borg and Beck style I set up the clutch rods exactly how they were before the swap. I used pics I took before disassembly to verify everything was replaced exactly. After noticing the problem with the clutch pedal I removed the return spring on the throw out fork and I could move the fork rearward quite a bit before the bearing contacted the pressure plate and from that I could see the solution is a longer adjusting rod.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: Centerline]
#2303301
05/12/17 12:34 PM
05/12/17 12:34 PM
RapidRobert
^^^^ Ding ding ding we (may) have a winna. It does make sense since nothing in the pics appears out of order/& the descrip sounds copacetic & that there is a "travel" issue somewhere.
[Re: toplescuda]
#2303451
05/12/17 05:48 PM
05/12/17 05:48 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Ok. Thank you. IL have to try to make a rod set up for it
[Re: toplescuda]
#2303766
05/13/17 10:44 AM
05/13/17 10:44 AM
Posts: 1,565 tennessee
pushbutton
tennessee
Ok. Thank you. IL have to try to make a rod set up for it Hope you get the problem solved. Keep us posted.
[Re: toplescuda]
#2304125
05/14/17 12:26 AM
05/14/17 12:26 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Iv came up with a rod that someone made longer. So I get a chance il put it on and see how it acts
[Re: toplescuda]
#2304169
05/14/17 02:17 AM
05/14/17 02:17 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
I use the Mopar stock A body SB V8 clutch rods in all of my B body cars, their a lot longer stock
[Re: toplescuda]
#2306533
05/18/17 06:57 AM
05/18/17 06:57 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Ok I finally got to mess with it again... I had a old rod that someone welded up. But it was 2 inches to long I cut it. Re welded it Made huge differance. If I can take the slack out of the rod to pedal il be good.. So i have a question. Can I adjust the lower rod pushing the throw out bearing against the pressure plate fingers/arms to take the slack out of the top rod or should the bearing not touch while pedal at rest?
[Re: toplescuda]
#2306653
05/18/17 12:47 PM
05/18/17 12:47 PM
Centerline
Texas Hill Country
Agreed. The bearing should NOT touch the forks during rest. Quickest way to wear out the bearing. There also needs to be a little slack in the system. My preliminary setting is to have the bearing touch the forks after about an inch or two of pedal travel. Once the car is in running condition you can adjust from there to have the clutch start to engage at a point where it "feels" right.... usually when the pedal is a little less than half way up from the floor.
[Re: toplescuda]
#2306842
05/18/17 04:38 PM
05/18/17 04:38 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
It's not touching right now. I can pull the pedal up up bout a inch and it will break over with the over center spring. That's why I was asking The pedal now is up off the floor like it should be
[Re: toplescuda]
#2306849
05/18/17 04:53 PM
05/18/17 04:53 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Do U have the properreturn spring on the fork down below... Note the OE spring has certain tension specs that many universal springs don't have.. On my 70RR I had a similar problem replaced the subject spring with the rite one all is well.. Just my $0.02...
[Re: toplescuda]
#2306869
05/18/17 05:25 PM
05/18/17 05:25 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Yes the correct spring is on the pedal
[Re: toplescuda]
#2306872
05/18/17 05:29 PM
05/18/17 05:29 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
If I shoved the clutch in and released it. The pedal would look normal I guiess. But I can grab it with my hand and pull a inch or so and feel the pedal go over center
