Surge Tank?? #2299516
05/05/17 01:28 PM
05/05/17 01:28 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
I'm planning to incorporate a surge tank into my fuel system when I convert to mechanical fuel injection. I'm doing this to do minimum change to my car with this conversion. I have a 1 gal tank fed thru 2 holley float bowls. I plan to go large on the needle/seats. This will be fed via a rear tank, Aeromotive A1000 pump via -10 fuel line to a regulator and -8 lines to the bowls. From the tank I will gravity feed to the Hilborn pump via a -12 line .
I have never used a surge tank and was wondering if there are things I should look out for and if my setup sounds like it would work OK.
Thanks, Max
Re: Surge Tank?? [Re: Blucuda413] #2300138
05/06/17 03:06 PM
05/06/17 03:06 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think if using holley float bowls, the top of the surge tank may need to be vented for air to escape?
is there a return line from the Hilborn Injection? would it go to that fuel tank or surge tank?
Re: Surge Tank?? [Re: Blucuda413] #2300299
05/06/17 08:10 PM
05/06/17 08:10 PM
Alexandria, LA
Alexandria, LA
You're correct the tank currently has 3 bungs on it. One for vent, one for return from Hilborn pump and I don't know yet if I will need to use the third one. I will run the hilborn pump return into the surge tank. My regulator has a return to the rear tank. I could reroute the -8 return from the regulator into the surge tank. May need to do that to keep it from running low. .
Re: Surge Tank?? [Re: Blucuda413] #2301031
05/08/17 08:02 AM
05/08/17 08:02 AM
australia
charger410 Offline
charger410  Offline
australia
Quick sketch of what I did. The 2 level switches are wired to latched relays that control the electric fuel pump in the rear. There's also a baffle around the 3 incoming fuel bungs.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
