Re: 588 dyno results
[Re: KOS]
#2303465
05/12/17 06:24 PM
05/12/17 06:24 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
Get the vacuum issue solved, wont ad much for power but engine well be happier. Put a larger carb on it, larger throttle blade and it will like that too. What fuel are you using? The BSFC's look pretty good, which explains the lower timing. IMO depending on fuel the AFR's are on the lean side especially up top. Still plenty there for sure. IMO carb spacer likely wont yield a ton as the intake on a B1 is pretty bug but a reversion plate and small tapered spacer may show some decent gains. Was still making power when the pull stopped as well.
Out little 572 made 1000 and seems to run a representative number to date, with plenty left. Good luck with it!!!
[Re: cesar perez]
#2303732
05/13/17 09:16 AM
05/13/17 09:16 AM
KOS
who did your heads and what flow numbers >? some local guy ported them.....no flow #s but they measure 385cc with the RB plates.
