Re: 2007 Ram 1500. A/C cold on right side, warm on drivers side
[Re: J_BODY]
#2324999
06/21/17 11:42 PM
06/21/17 11:42 PM
Posts: 1,565 tennessee
pushbutton
tennessee
cold on driver, warm on passenger is usually low charge. The opposite (warm L, cool R) is broken air door more common on the dual zone systems. Bingo
[Re: stumpy]
#2329896
07/01/17 08:03 PM
07/01/17 08:03 PM
Posts: 8,251 fredericksburg,va
cudaman1969
fredericksburg,va
Schrader valve is the charging port and it's core. Tire valve stem is a schrader valve of sort. Thank you, though it was a big gizmo. My 06 was just recharged and it cools on driver side and hot on pass, so I guess it's low charged. Back to the shop.
[Re: 383man]
#2330428
07/02/17 11:11 PM
07/02/17 11:11 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
cold on driver, warm on passenger is usually low charge. The opposite (warm L, cool R) is broken air door more common on the dual zone systems. Yes that right as I remember when some were low on freon doing what J-body said. I believe there may be a TSB about the air door problem as I remember fixing a few of them. I left the dealer in 2011 so its been a while since I worked on any. Ron After what we both said I surely would have had the freon checked in the system first. Heck the dealer I worked at we got like 1.5 to suck all the freon out which tells how much is in it. Then it also included us adding dye and looking for leaks after we filled the system with the proper amount of freon. The cust price was about $139. for that. If we found no leaks then we had the cust come back in a week or two and we checked to see if we could see any dye and find the slow leak. To replace the shrader valve takes about 20 seconds after the freon is pulled out. Cant say we did not tell you as after what J-body and I said I would have had the system charge checked. I just hope the schrader valve is not your only leak. Ron
[Re: 383man]
#2343955
07/26/17 10:38 PM
07/26/17 10:38 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I surely would have had the freon checked in the system first. Heck the dealer I worked at we got like 1.5 to suck all the freon out which tells how much is in it. Then it also included us adding dye and looking for leaks after we filled the system with the proper amount of freon. The cust price was about $139. for that. If we found no leaks then we had the cust come back in a week or two and we checked to see if we could see any dye and find the slow leak. To replace the shrader valve takes about 20 seconds after the freon is pulled out. Cant say we did not tell you as after what J-body and I said I would have had the system charge checked. I just hope the schrader valve is not your only leak. Ron 5 weeks and counting, the A/C is still working great.
[Re: Kern Dog]
#2352453
08/11/17 04:23 PM
08/11/17 04:23 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I always tell my family and customers, that on all the newer cars, I advise everyone to turn the BLOWER FAN SPEED to OFF- BEFORE moving any other nobs on your heater- a/c system.
When you have the fan blowing, and you select either hotter or colder, or any other position for your airflow. You slam the doors into their next position. Eventually , they are going to brake, ESPECIALLY if the fan is on HIGH SPEED!! If you turn the fan off 1st, it makes it so much easier on the doors and actuators!!!!!!!
You never use to brake these doors on your old cars, that were controlled by cables, instead of the newer electric actuated doors.
Brilliant engineering!!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
