Please show off your W7 W8 W9 valley pans
#2291781
04/21/17 09:16 PM
04/21/17 09:16 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Re: Please show off your W7 W8 W9 valley pans
[Re: RAY1969CARS]
#2291822
04/21/17 10:50 PM
04/21/17 10:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Sorry I dont have any pics but I made 2 of them.. a sheet metal one and a billet one EDIT You might see it here.. this is the sheet metal one
[Re: MR_P_BODY]
#2296386
04/30/17 06:12 AM
04/30/17 06:12 AM
Posts: 87 Michigan
Silver68RT
Sorry I dont have any pics but I made 2 of them.. a sheet metal one and a billet one EDIT You might see it here.. this is the sheet metal one Who makes those valve covers? I'd like to get a set for my W9's. I see that Milodon makes a fabricated tall/wide valve cover that would work, but I like the cast one you've got better.
[Re: Silver68RT]
#2296440
04/30/17 11:41 AM
04/30/17 11:41 AM
MR_P_BODY
Sorry I dont have any pics but I made 2 of them.. a sheet metal one and a billet one EDIT You might see it here.. this is the sheet metal one Who makes those valve covers? I'd like to get a set for my W9's. I see that Milodon makes a fabricated tall/wide valve cover that would work, but I like the cast one you've got better. Those covers are the Mopar cast reverse lip ones.. I milled the logo and the ribs off to make them smooth and to loose a little weight ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2296568
04/30/17 03:08 PM
04/30/17 03:08 PM
Posts: 87 Michigan
Silver68RT
Sorry I dont have any pics but I made 2 of them.. a sheet metal one and a billet one EDIT You might see it here.. this is the sheet metal one Who makes those valve covers? I'd like to get a set for my W9's. I see that Milodon makes a fabricated tall/wide valve cover that would work, but I like the cast one you've got better. Those covers are the Mopar cast reverse lip ones.. I milled the logo and the ribs off to make them smooth and to loose a little weight Nice job, they look great.
[Re: Silver68RT]
#2296809
04/30/17 10:19 PM
04/30/17 10:19 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Looks like those aren't available anymore. Guess I'll have to go with some fabricated ones. W9 take there own valve cover. Yes a stock one will bolt on but doesn't match up to pan rail. Need to order ones made for w9.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: MR_P_BODY]
#2296860
04/30/17 11:12 PM
04/30/17 11:12 PM
1967dartgt
Hilltown Pa
I've run W9 covers on w2,w5 and the w9s with no issues(all reverse lip ones) Well there are specific valve covers and gaskets made for w9 heads. There not the same as a factory cover or gasket.
[Re: 1967dartgt]
#2297010
05/01/17 10:33 AM
05/01/17 10:33 AM
Posts: 87 Michigan
Silver68RT
I've run W9 covers on w2,w5 and the w9s with no issues(all reverse lip ones) Well there are specific valve covers and gaskets made for w9 heads. There not the same as a factory cover or gasket. I thought it was just that you had to run a wide style valve cover / reverse lip, and then trim the lip and the gasket to clear the valve springs. Do you have a link to the W9 specific ones? I couldn't come up with anything on eBay, Jeg's, Summit, Mancini Racing...
[Re: Silver68RT]
#2297043
05/01/17 11:58 AM
05/01/17 11:58 AM
MR_P_BODY
I've run W9 covers on w2,w5 and the w9s with no issues(all reverse lip ones) Well there are specific valve covers and gaskets made for w9 heads. There not the same as a factory cover or gasket. I thought it was just that you had to run a wide style valve cover / reverse lip, and then trim the lip and the gasket to clear the valve springs. Do you have a link to the W9 specific ones? I couldn't come up with anything on eBay, Jeg's, Summit, Mancini Racing... Your correct.. a minor radius near the springs and cut the gaskets the same... took me about 20 minutes ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Silver68RT]
#2297166
05/01/17 02:43 PM
05/01/17 02:43 PM
MR_P_BODY
I ordered some Milodon fabricated ones. I don't have valves or valve springs yet, and the valve seats aren't machined. Did you have someone port your heads and all that, or did you do them yourself? I had 2 sets of W-9s.. the first set was done by Chapman and the other set by Shady Dell.. both were very close on flow.. and they both set them up ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Silver68RT]
#2297987
05/02/17 11:22 PM
05/02/17 11:22 PM
1967dartgt
Hilltown Pa
I've run W9 covers on w2,w5 and the w9s with no issues(all reverse lip ones) Well there are specific valve covers and gaskets made for w9 heads. There not the same as a factory cover or gasket. I thought it was just that you had to run a wide style valve cover / reverse lip, and then trim the lip and the gasket to clear the valve springs. Do you have a link to the W9 specific ones? I couldn't come up with anything on eBay, Jeg's, Summit, Mancini Racing... Here is the correct gasket for a w9 ![](http://i1274.photobucket.com/albums/y434/1967dart/48F2D81C-5B21-4D8F-818D-9EC4B4B98F8F_zpshqs5dfyd.jpg)
