Re: Gen3 Mopar Performance Intake [Re: cbusters] #2342279
07/24/17 02:56 AM
07/24/17 02:56 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Oil fill and pcv/breather.
Mopar to the bone!!!
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2342461
07/24/17 03:19 PM
07/24/17 03:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Breather and pcv.
(Oil fill is the big cap, already covered.)
Rich H.
Esse Quam Videri
Re: Gen3 Mopar Performance Intake [Re: ZIPPY] #2342502
07/24/17 04:18 PM
07/24/17 04:18 PM
cbusters Offline OP
cbusters  Offline OP
Originally Posted By ZIPPY
Breather and pcv.
So the PCV valve screws into the threaded opening under the filler cap? Is that a standard 5.7 item that will transfer over to the MP intake? Or something I will have to hunt down or make?
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2342613
07/24/17 07:09 PM
07/24/17 07:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Can't recall if the pcv valve goes in the side or in the front by the cap. It's only been 12 years...
I am pretty sure it is not a 5.7 pcv valve, it is from some other application, 5.7 does not use a hose, crate engine did.
I might still have the crate engine I sheet on cd someplace. Would take awhile to find it, though. (everything is boxed up).
Rich H.
Esse Quam Videri
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2342627
07/24/17 07:37 PM
07/24/17 07:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
look at an 05 Magnum with the 5.7 for the PCV valve
Don't be the exception.
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2342932
07/25/17 08:27 AM
07/25/17 08:27 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Google MOPAR 53032531AE
For the PCV
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343006
07/25/17 12:31 PM
07/25/17 12:31 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The stock 5.7 pcvs are a quarter turn thing with no hose attached.
They won't work with this intake.
The old crate intake intake uses a pcv from some other application that screws in the front near the oil cap, and a hose runs to it from there.
The valve looks like one from a 2.0 or 2.4.
Run a breather hose to a breather tank, or a small k&N type breather or whatever you've got, off the fitting in the side of the intake.
Rich H.
Esse Quam Videri
Re: Gen3 Mopar Performance Intake [Re: ZIPPY] #2343030
07/25/17 01:20 PM
07/25/17 01:20 PM
southern Idaho
moparcyco Offline
moparcyco  Offline
southern Idaho
I have the efi version been searching the same issues. pcv that will thread into small port below oil fill is napa number 2-9627 fits 2.4.
Re: Gen3 Mopar Performance Intake [Re: moparcyco] #2343048
07/25/17 01:59 PM
07/25/17 01:59 PM
southern Idaho
moparcyco Offline
moparcyco  Offline
southern Idaho
Also could you just machine that breather hole for npt threads and just run a breather right from the intake?
Re: Gen3 Mopar Performance Intake [Re: moparcyco] #2343180
07/25/17 05:47 PM
07/25/17 05:47 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sometimes it's great to be reminded your memory isn't as shot as you thought it was (thanks) smile
I knew it looked like a 2.0 or 2.4 pcv but couldn't remember what it was actually from.
Rich H.
Esse Quam Videri
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343194
07/25/17 06:16 PM
07/25/17 06:16 PM
cbusters Offline OP
cbusters  Offline OP
Run the NAPA PCV valve screwed into the front of the intake with a hose to one of the fitting son the back of the intake and then a breather hose from the air cleaner to a valve cover?
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343221
07/25/17 07:15 PM
07/25/17 07:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Run a breather off the port labeled "intake breather port" in the picture above.
Re: Gen3 Mopar Performance Intake [Re: ZIPPY] #2343250
07/25/17 08:36 PM
07/25/17 08:36 PM
cbusters Offline OP
cbusters  Offline OP
Is that nipple what is missing in this picture?
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343475
07/26/17 02:00 AM
07/26/17 02:00 AM
southern Idaho
moparcyco Offline
moparcyco  Offline
southern Idaho
Is that nipple piece still available from Chrysler? Tried searching and calling dealer both came up with nada. measuring the hole looks like it would be easy to machine to 1/4 npt threads which would be much easier to source. Just pisses me off that you have to spend a $1000 dollars for this and can't get parts or have to make stuff work.
Also not to thread hijack in the pic above can you still get the map sensor that works with this manifold? I need a 4 bar cause I have boost. Thanks
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343500
07/26/17 02:59 AM
07/26/17 02:59 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Honestly I think it was kind of cheesy, it was just a bubble flared chunk of steel tubing pressed in the hole. If I remember right it was only sold with the crate motor.
You're probably better off creating something different/better.
If I can scrounge up any more instructions that refer to this, I will look for the sensor and let ya know. I remember absolutely nothing about that from my 8+ run working there, but unfortunately never worked hands on with this intake during that time period.
I agree the price is crazy, always has been, the fellow managing the program was somewhat rushed and the casting/machining work ended up going to high dollar prototype shops instead of mp's normal intake foundry out in CA, the one with the "BB" casting mark (buddy bar). He brought the product to market quickly that way, but after he left mp seemed to be no marketing interest in resourcing/managing it. So there it sits, kind of stuck.
Rich H.
Esse Quam Videri
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343523
07/26/17 08:00 AM
07/26/17 08:00 AM
cbusters Offline OP
cbusters  Offline OP
Is this where the MAP sensor goes?
Re: Gen3 Mopar Performance Intake [Re: moparcyco] #2343525
07/26/17 08:08 AM
07/26/17 08:08 AM
cbusters Offline OP
cbusters  Offline OP
Since this is the breather port that goes to the air cleaner, I understand that these engines have a tendency to pump oil out of these ports. I am going to run this to an Air Grabber and really don't want to ruin an oval air filter with oil stains. There were oil catch cans for the Gen III's that people upgraded to in the early days, is this where it was "spliced" into? This might effect how I try to fix the missing fitting issue.
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343767
07/26/17 05:04 PM
07/26/17 05:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
No need to get a special late model catch can, something like this will work
https://www.summitracing.com/parts/aaf-a...h4aAtUhEALw_wcB
Yes I believe that's the sensor location. No I can't remember anything about the sensor itself
Re: Gen3 Mopar Performance Intake [Re: cbusters] #2343783
07/26/17 05:47 PM
07/26/17 05:47 PM
cbusters Offline OP
cbusters  Offline OP
First off, I appreciate all the help. I am working toward an OEM type of engine graft and whatever I do has to be hidden. I have access to machines at a tubing repop company and they think they can make me a stainless knock in nipple for the open "port" in the rear. I can even make a line that comes up higher and routes under the air cleaner base to hide something that will separate the oil and air so I can have my breather hose coming off the Air Grabber base. I will start searching for a separator. Something small, I think.
