Re: 850 holley from sq jet,boost to frnt pv n/a
[Re: Clanton]
#2297941
05/02/17 10:02 PM
05/02/17 10:02 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I forget,is getting vacuum from the dist port ok on the metering plate or in carb base is better? That can be a debate in itself. Carb base vacuum may pull in all the vac timing at idle, witch you don't want. But with your big cam maybe it wont. The meter plate will pull vacuum in at a higher rpm. Try both see what you like best. The metering plate port is the one your really supposed to use. But, if you don't do much street driving/cruising, you really don't need it at all.
[Re: Clanton]
#2297988
05/02/17 11:24 PM
05/02/17 11:24 PM
Thumperdart
State of confusion
If you're reading vac then the base and is your timing locked.......
[Re: Clanton]
#2298511
05/03/17 09:28 PM
05/03/17 09:28 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
yes the timing is locked at 32 for now and I will need to drill,tap for the vac so that will come later or maybe not with all the rain I am getting.I ended up sq jetting it again checking for leaks and test the backfire I had.87pri 88 sec no pv's it revs fine and power brakes well so I will test drive it like that when I get the chance[rain].jetting with a pv may take a 82 in the pri side.I would have tested that jetting but I was running out of time. ps:the point of driving it sqjetted is to check the trans shift,fluid,brakes and other things.
