Re: 850 holley from sq jet,boost to frnt pv n/a
[Re: Clanton]
#2296871
04/30/17 11:33 PM
04/30/17 11:33 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I still have the pv plug in the sec circuit and 88 jets but the pri has 76 and the 2.5pv,32 squirter,orange pump cam 1# hole and just checking things out in the garage it was lean n backfire in the intake/carb.I only have a 4.5 and a 6.5 pv to work with beside the 2.5 but my carb jets are from 76 to 90 and I think factory was 80 with pv's in the pri.The timing is at 32 to start 93 octane. ps the carb is an 4150 with choke horn no plate in it,factory air bleeds non adj.
[Re: Clanton]
#2296922
05/01/17 12:50 AM
05/01/17 12:50 AM
Thumperdart
State of confusion
Idle has no impact on the p/v unless it's loose or ruptured.......steady state cruise and a couple inches below that will get ya close then pvcr sizing and secondary jetting accordingly.............What list number or size is it...........
[Re: Clanton]
#2297055
05/01/17 12:07 PM
05/01/17 12:07 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd start with a brand new 6.5pv, and 78/88 jets and adjust from there. This is assuming you're using a 4781/850 carb.
[Re: fast68plymouth]
#2297105
05/01/17 01:30 PM
05/01/17 01:30 PM
Clanton
northern,Ohio,USA
I'd start with a brand new 6.5pv, and 78/88 jets and adjust from there. This is assuming you're using a 4781/850 carb. Yes it is a 4781,The 6.5 has been sitting in a tray for 15yrs from when I got the carbs and seems to be ok when put vacuum on it in my mouth.I wont be driving in the rain today but will check the carb over again.Thank you for your help.
[Re: Clanton]
#2297116
05/01/17 01:42 PM
05/01/17 01:42 PM
fast68plymouth
So. Burlington, Vt.
If the rubber diaphragm gets stiff it changes the point at which it opens/closes.
They don't have to leak to not work properly.
[Re: Clanton]
#2297130
05/01/17 01:53 PM
05/01/17 01:53 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Holley made many 4781 from the original with no power valve in the secondary to the 4781-9 I think with power valves in both metering blocks, I think my 4781-2 didn't have a power valve in the secondary ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) My 4781-6 came with one size smaller jet in the rear than the primary jets where What is your - list number ?
[Re: Clanton]
#2297150
05/01/17 02:30 PM
05/01/17 02:30 PM
Thumperdart
State of confusion
Get QF 4 window p/v...............
[Re: Clanton]
#2297219
05/01/17 03:59 PM
05/01/17 03:59 PM
Cab_Burge
Is this carb. on a intake now and not on top of the blower?
