Re: Hemi stoker guys step inside:
[Re: hudsonhornet7x]
#2297137
05/01/17 02:05 PM
05/01/17 02:05 PM
Posts: 43,359 Bend,OR USA
Cab_Burge
Thanks for the replies. Even though I found a deal on the pistons it seems like I should be looking at bigger cubes. Have you thought of using a shorter rod length with the longer stroke to use those pistons? ![work work](/ubbthreads/images/graemlins/custom/work.gif) I have made the mistake of buying a part and then building a motor around that part ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) That is not the smartest way to start on a new motor build unless your absolutely sure you want to build that new motor that way ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#2297139
05/01/17 02:08 PM
05/01/17 02:08 PM
Posts: 1,545 USA
hudsonhornet7x
USA
Thanks for the replies. Even though I found a deal on the pistons it seems like I should be looking at bigger cubes. Have you thought of using a shorter rod length with the longer stroke to use those pistons? ![work work](/ubbthreads/images/graemlins/custom/work.gif) I have made the mistake of buying a part and then building a motor around that part ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) That is not the smartest way to start on a new motor build unless your absolutely sure you want to build that new motor that way I have thought about it, but don't know how good that would be.
Re: Coal stoker guys step inside:
[Re: 68 HEMI GTS]
#2297299
05/01/17 06:14 PM
05/01/17 06:14 PM
dogdays
So Hudson, what is the compression height of your pistons? How about pin size?
R.
[Re: dogdays]
#2297401
05/01/17 09:22 PM
05/01/17 09:22 PM
Posts: 1,545 USA
hudsonhornet7x
USA
R. Here is a pic. Haven't bought them yet.
