Page 3 of 11 1 2 3 4 5 10 11
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2260099
02/26/17 08:47 PM
02/26/17 08:47 PM
west palm beach, florida
modelmakerinc Offline OP
Some of you guys may be wondering why it has no roof, well the crappy cardboard headliners with some heat and humidity like to invert themselves and be useless, so I used the roof upside down to create a perfect mold to reshape the headliner.
Some water and heat in the bed of my truck with a topper got it most of the way back, a few platforms and some weight plus my wife's iron got it the rest of the way.
From there, I repaired the cracks, patched the holes where the shoulder belts were, fixed the damaged edges. Then fiberglassed the entire part to make a hardend shell that won't warp with the elements.
I will cover it with a modern type of headliner material when I am finishing the interior.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2260104
02/26/17 08:54 PM
02/26/17 08:54 PM
Las Vegas Nevada, USA
Tony21 Offline
Tony21  Offline
Nice build!
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2262359
03/02/17 09:54 PM
03/02/17 09:54 PM
Superfreak
Superfreak
Looking pretty slick there Henry. I didn't realize you had this thread going, looking great.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2263370
03/04/17 05:47 PM
03/04/17 05:47 PM
Yeah, Thanks. My 67 Coronet is on the back burner cause I was mislead in the purchase of these cars. Once I was in, I had to take it to the finish.
Been working alot but took this last week to work on the drivers quarter panel. Did all the rust repair and patches, filled,and blocked it, layed down metal etch primer then two med wet coats of high build.
Going to spin the car around and get the passenger side done next.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2263625
03/05/17 11:57 AM
03/05/17 11:57 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Great seeing this car saved. It's going to be a fun ride for sure.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2263694
03/05/17 01:42 PM
03/05/17 01:42 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I wish these cars didn't have to be Smogged in CA. Keep up the good work. up
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2267461
03/11/17 02:46 PM
03/11/17 02:46 PM
Started on tightening up the rear bumper, these things from the factory have a filler panel that warps and breaks plus stick out a good 2 inches on either side, the front is far worse.
I used the trim holes to weld temp brackets to 1/4-20 bolts for placement of the bumper, I will make a new mounting setup next with some built in adjustability
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2268237
03/12/17 07:41 PM
03/12/17 07:41 PM
Found this great pic of just how large and bulky the bumpers are and look, not to mention they are 140 plus lbs with the self absorbing crap and the inner bumper structure
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2278567
03/29/17 09:51 PM
03/29/17 09:51 PM
Chicago IL
SpeedBanana Offline
SpeedBanana  Offline
Chicago IL
This is looking great! Could you post more pics of the bumper mods when you get a chance? I would like to do something similar but so far have only been thinking about it. Thanks!
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2278600
03/29/17 10:32 PM
03/29/17 10:32 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Excellent to see you fiximg that car. There is a 76 Aspen RT up the road. It's rusty. But you give me faith. Keep up the good work.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2278932
03/30/17 02:20 PM
03/30/17 02:20 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
If you can find a fiberglass bumper, you can mount it up tight like this.....
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2279160
03/30/17 09:26 PM
03/30/17 09:26 PM
Thanks, here are some progress pics of the bumper and brackets. I cut through the absorbing tube to use the factory attaching plates, from there I bent my own brackets. I welded the stock carriage bolts to the backside of the bumper, they made it easy to fill the large square bolt holes.
Tucked it up and in and rebuilt the ends, I did it all with strategic cutting and piecing the the bits I cut off, only fabbed two pieces per side from 1/8 plate.
No fancy tools either, a cutoff disk, 2 lb hammer, bench vise and a welder.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2279166
03/30/17 09:34 PM
03/30/17 09:34 PM
More pics
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2279168
03/30/17 09:37 PM
03/30/17 09:37 PM
I will grind them smooth and shoot with DP90. A little body work and they should look alright high and tight. Really updates the look.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2279205
03/30/17 10:24 PM
03/30/17 10:24 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Keep em coming. Nice work
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2279760
03/31/17 06:02 PM
03/31/17 06:02 PM
Last pics, bumper is roughed in it needs some filler, prime and color.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2280125
04/01/17 02:50 AM
04/01/17 02:50 AM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
Very nice. up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2280149
04/01/17 06:39 AM
04/01/17 06:39 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
bad ass work
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2296213
04/29/17 07:34 PM
04/29/17 07:34 PM
milwaukie oregon
1970 charger Offline
milwaukie oregon
Any updates? Awesome work
Re: 76 Volare, yes a volare. [Re: 1970 charger] #2296293
04/29/17 10:21 PM
04/29/17 10:21 PM
Thank guys, Actually been working a bunch and a few family things have not let me do much. However, I did get the go wing mocked up and the support brackets modified to fit the F body deck lid.
This is a factory b body wing and brackets that a friend of mine picked up at a local swap meet, got it for 175. I am really happy with it.
