Re: 741 case
[Re: JohnRR]
#2294788
04/27/17 12:39 AM
04/27/17 12:39 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
So its possible they would have had an A31 car without a sure grip or is that the giveaway that the pumpkin has been changed ? Pumpkin changed, A31 B body would have had a 489 case, A31 includes SUREGRIP so no it is not possible to have one unless the factory installed the wrong chuck in the housing. What is the date stamped on the ring gear , an A100 I think could be had with a 3.91 with no sure grip and a 741 case. I have a 3.91 SG 741 in my stash that I took out of an A100 van. Kevin
Re: 741 case
[Re: Cab_Burge]
#2295058
04/27/17 03:24 PM
04/27/17 03:24 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
I traded the original owner for that car, I didn't buy it new. He had been a dealership mechanic but he was a flake also, he insisted that the rear end was the original one that came in the car, he had no reason to lie about that I didn't say it had any I.D. numbers on it, only that it was a 741 case with a clutch type posi and 3.91 gears in it I'm not exactly sure when Mopar started installing the 489 cases and the other Eaton type posi, I know it was sometime in the 1969 production year Did you ever pull the chunk and check the dates ? What is the casting date of the 741 ?
Re: 741 case
[Re: Twostick]
#2295060
04/27/17 03:26 PM
04/27/17 03:26 PM
JohnRR
So its possible they would have had an A31 car without a sure grip or is that the giveaway that the pumpkin has been changed ? Pumpkin changed, A31 B body would have had a 489 case, A31 includes SUREGRIP so no it is not possible to have one unless the factory installed the wrong chuck in the housing. What is the date stamped on the ring gear , an A100 I think could be had with a 3.91 with no sure grip and a 741 case. I have a 3.91 SG 741 in my stash that I took out of an A100 van. Kevin Yes and ??? Did you read what I posted ??? ... fully ??? ... I said ... An A100 I THINK could be had with a 3.91 with no sure grip and a 741 case. I am pretty sure an A100 had a suregrip as an OPTION too ...;)
Re: 741 case
[Re: JohnRR]
#2295615
04/28/17 02:01 PM
04/28/17 02:01 PM
Twostick
Still wishing...
Still wishing...
So its possible they would have had an A31 car without a sure grip or is that the giveaway that the pumpkin has been changed ? Pumpkin changed, A31 B body would have had a 489 case, A31 includes SUREGRIP so no it is not possible to have one unless the factory installed the wrong chuck in the housing. What is the date stamped on the ring gear , an A100 I think could be had with a 3.91 with no sure grip and a 741 case. I have a 3.91 SG 741 in my stash that I took out of an A100 van. Kevin Yes and ??? Did you read what I posted ??? ... fully ??? ... I said ... An A100 I THINK could be had with a 3.91 with no sure grip and a 741 case. I am pretty sure an A100 had a suregrip as an OPTION too ...;) My apologies. The OP had questioned in an earlier post if a 3.91 SG was even available in a 741. the 3:91 sure grip wasn't produced in the 741 ? When you replied to him on another post about " thinking" an open 3.91/741 was available in an A100, I read that to mean specifically/only in an A100 and only as a non SG which in hindsight is not what you said. I replied to confirm that a 3.91SG was in fact available in a 741 case and was also, as such, available in an A100. Kevin
Re: 741 case
[Re: mro]
#2295812
04/28/17 10:26 PM
04/28/17 10:26 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
so I'm the OP and still confused. Trying to figure out if the rear was original to the car - or a possibility. With the 3.91 included in the A31 package is it safe to assume it was a SG. Whatever is in there now is in a 741 case and not a SG. What is the most likely case for a spring special A31 3.91 gear ?
68 Satellite Wagon and a few other ones
Re: 741 case
[Re: Twostick]
#2296441
04/30/17 11:43 AM
04/30/17 11:43 AM
JohnRR
My apologies. The OP had questioned in an earlier post if a 3.91 SG was even available in a 741. the 3:91 sure grip wasn't produced in the 741 ? When you replied to him on another post about " thinking" an open 3.91/741 was available in an A100, I read that to mean specifically/only in an A100 and only as a non SG which in hindsight is not what you said. I replied to confirm that a 3.91SG was in fact available in a 741 case and was also, as such, available in an A100. Kevin You are correct in that the 3.91 was put in 741 case and had a sure grip , pretty sure I have the remnants of one in my pile of chucks in the basement. But your assumption is also correct as I think the trucks/vans were the only vehicles available with a 3.91 without a sure grip , that option wasn't available in a performance car , or a passenger car either as far as I know ...
Re: 741 case
[Re: mro]
#2296442
04/30/17 11:47 AM
04/30/17 11:47 AM
JohnRR
so I'm the OP and still confused. Trying to figure out if the rear was original to the car - or a possibility. With the 3.91 included in the A31 package is it safe to assume it was a SG. Whatever is in there now is in a 741 case and not a SG. What is the most likely case for a spring special A31 3.91 gear ? As Dr. Diff said... 3.91 with sure grip, in a 489 case, in an A31 B body, not a 741 and certainly not OPEN with 3.91's. What is in the car right now was not installed by the factory when the car was built.
Re: 741 case
[Re: mro]
#2296517
04/30/17 02:08 PM
04/30/17 02:08 PM
Posts: 200 Colorado
Bob J
Colorado
Back in the 70's and 80's you would look for these centers in the junk yards or swap meets. They were a low cost way to get the gears and sure grip if you were on a budget. And guess what they would live in cars with 500 hp and street tires most of the time. But you didn't tell your buddies that it was a 741 case but you now had good gears. So a bunch of them were swapped into to cars.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
Re: 741 case
[Re: Cab_Burge]
#2329159
06/30/17 02:59 PM
06/30/17 02:59 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
My 1969 GTS Dart H code 4 speed car(SPD in 9-68) has the original 741 case 3.91 gears clutch type posi in it still Never say never Agree, My 68 GTS has a 741 with a 3.91 SG
Abe Lincoln
