Re: Carter BBD carburetor kit
[Re: NachoRT74]
#2297760
05/02/17 02:57 PM
05/02/17 02:57 PM
Posts: 6,116 Valencia, España
NachoRT74
Valencia, España
need to figure out yet the check ball retainer... since is not fixed anywhere, just floating around ( and is not on ANY diagram but included on kit )
[Re: NachoRT74]
#2298072
05/03/17 01:34 AM
05/03/17 01:34 AM
RapidRobert
I cant remember what went into mine but I don/t think there were any floating free parts.
[Re: NachoRT74]
#2298077
05/03/17 01:41 AM
05/03/17 01:41 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
need to figure out yet the check ball retainer... since is not fixed anywhere, just floating around ( and is not on ANY diagram but included on kit ) No retainer,it just lays under the accelerator pump.
[Re: 62maxwgn]
#2298091
05/03/17 02:03 AM
05/03/17 02:03 AM
RapidRobert
I ain't thinking there was anything under the AP plunger ex for maybe a check ball.
[Re: NachoRT74]
#2298176
05/03/17 11:00 AM
05/03/17 11:00 AM
NachoRT74
Valencia, España
Well, I just dropped it there and so far so good, is not disturbing the acc pump
[Re: NachoRT74]
#2298785
05/04/17 11:34 AM
05/04/17 11:34 AM
RapidRobert
Well, I just dropped it there and so far so good, is not disturbing the acc pump if it never develops a hesitation from no squirt then I'd say you're good.
[Re: NachoRT74]
#2299166
05/04/17 09:24 PM
05/04/17 09:24 PM
NachoRT74
Valencia, España
I'm also wondering WHY if my TQ provides a ported vacuum tee for the dist, then the BBD provides an unported vacuum tee for the dist.
I was wrong, the BBD provision on the side is also ported!
[Re: NachoRT74]
#2299169
05/04/17 09:28 PM
05/04/17 09:28 PM
RapidRobert
Actually that side port MAY be some kind of EGR signal & not be a full on ported signal. (you're still off the hook!).
[Re: NachoRT74]
#2299173
05/04/17 09:33 PM
05/04/17 09:33 PM
NachoRT74
Valencia, España
On diagramas it appears to be the dist port, which dunno why I thought it was unported... whaaaatever, the deal is it is working as it must be LOL
[Re: NachoRT74]
#2299191
05/04/17 10:13 PM
05/04/17 10:13 PM
RapidRobert
it is giving you enough vac to run the can?
[Re: NachoRT74]
#2299192
05/04/17 10:15 PM
05/04/17 10:15 PM
NachoRT74
Valencia, España
Yes, I could see the advance at balancing damper with my timming lamp
[Re: NachoRT74]
#2299242
05/04/17 11:17 PM
05/04/17 11:17 PM
RapidRobert
If off idle the vac is comparable to vac at a manifold port then I'd say you're good.
[Re: NachoRT74]
#2315527
06/03/17 11:58 AM
06/03/17 11:58 AM
NachoRT74
Valencia, España
carb began to fail once again... it seems maybe leaking. Is hard to keep engine running. Spark plugs shows like rich mixture. But I couldn't find any leak anywhere when cleaning and installing the new kit. I filled the bowl with thiner which is able to gho through any kind of crack easier than the gasoline and couldn't find any leak.
where to check?
[Re: NachoRT74]
#2315532
06/03/17 12:18 PM
06/03/17 12:18 PM
RapidRobert
it's leaking from the needle/seat assy. I have one that is doing the same thing & I went thru it meticulously. I'm gonna take the needle/seat assy out & spray it.
