Re: Mopar Big Block Purple Cam 509 $
[Re: ZIPPY]
#2291571
04/21/17 02:17 PM
04/21/17 02:17 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
When I bought my 509 16ish yrs ago I think it was $118 for cam and lifter kit. And it was more expensive than Comp and a few others then too. I bought it because I guess I fell for the "built by Mopar for a Mopar" advertising they had back then.
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
[Re: Texas383]
#2291577
04/21/17 02:24 PM
04/21/17 02:24 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you're not wanting to mess with pushrod length the lifters would be the 822's.
[Re: Texas383]
#2291965
04/22/17 03:38 AM
04/22/17 03:38 AM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Maybe it's one of those things where people think it's better and will buy it if it's overpriced, where before no one would touch it for $189.00.
68 Roadrunner. 383 4-spd. Beat up.
[Re: Texas383]
#2292048
04/22/17 12:44 PM
04/22/17 12:44 PM
fast68plymouth
So. Burlington, Vt.
I just figured they decided they didn't want to sell them anymore.
Cuz for $450+ they're going to sell waaaaaaaay fewer of them.
Would make for a fun(?) dyno shootout. The $450+ hyd cam vs a couple of similar grinds that are 1/2 price(or less).
Some possible candidates:
Comp PP292H Comp 296H-8 Isky Mega-Cam 292-108 Howard's 722251-09 Lunati Street Master 295-108
[Re: Texas383]
#2292631
04/23/17 11:47 AM
04/23/17 11:47 AM
Posts: 15,487 Florida
scratchnfotraction
Is that texas383 yellow?
I would call Hughes Engines and get something from them. Just MHO.
read to many failures on comp cams.
love my 440 whiplash cam. I am sure they got something as close or better for your 383.
102*/108* 230*/245* @ .050 .518/.518-1.5 ratio
stock PR/rockers/retainers
[Re: Texas383]
#2293220
04/24/17 02:04 PM
04/24/17 02:04 PM
Texas383
Marshall TX
... can I safely assume if I buy the cam/lifter kit in any of the cams recommended that I can use stock length push rods?
I pulled the lifters and cam yesterday. WOW!!! 8 of the 16 lobes were ground way down and the lifters ranged from severely cupped to having the lobe worn way down into the lifter as if it never rotated at all. The other 8 oddly looked as if there was none to extremely little wear on them. All the lobes and lifter with crazy amounts of wear were in the middle of the cam with both ends looking new still.
What the heck would cause that!?!? The cam was in for 16 yrs with 10-20K miles on it since I don't drive it daily. I'm not sure when this happened with the cam. The last time I drove it had great power then made rattling/knocking noise lost power and died.
[Re: Texas383]
#2293235
04/24/17 02:25 PM
04/24/17 02:25 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
What the heck would cause that!?!? The cam was in for 16 yrs with 10-20K miles on it since I don't drive it daily. I'm not sure when this happened with the cam. The last time I drove it had great power then made rattling/knocking noise lost power and died. Uh oh...I think this just went from a cam discussion to a pull the engine and clean and freshen discussion... ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: dogdays]
#2293263
04/24/17 03:18 PM
04/24/17 03:18 PM
Texas383
Marshall TX
It did sit for a long time.... between moving to a new house and having transmission failure.
Hopefully the new cam will not have to sit and the car will be driven more often as it will be more of a semi daily driver now that I've moved
