Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294584
04/26/17 05:40 PM
04/26/17 05:40 PM
California USA
LowDeck451 Offline
LowDeck451  Offline
California USA
Originally Posted By CRT
I will have one for a lock up and one for a non lock up.
Probably a dumb question; Can you run a non lockup converter if you have a lockup trans (longer input shaft snout)?
Nevermind, my duh! Awesome product though!
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294586
04/26/17 05:47 PM
04/26/17 05:47 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Now need something for the NAG1
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2296096
04/29/17 02:12 PM
04/29/17 02:12 PM
Guitar Jones Offline
Originally Posted By Guitar Jones
I'm going to think long and hard about this for my diesel truck. I've been tossing the idea around for quite some time. Just need to figure out a shifter for it.
Any aftermarket shifter will work.
Just thinking about the shift gate so it doesn't go from 1st to 3rd or 4th. For instance my quarter stick will go straight to 3rd from the neutral position when the trigger is squeezed.
Also another question, will the lockup version still use a solenoid for the lockup or how will that be handled?
