Page 4 of 5 1 2 3 4 5
Re: Project Zoom Me [Re: Cab_Burge] #2300635
05/07/17 12:23 PM
05/07/17 12:23 PM
Parts unknown
590 Challenger Offline OP
Parts unknown
Originally Posted By Cab_Burge
I have a friend who has ruled the west coast 10.5 PSCA class, he defines the amount of boost as the amount of resistance to airflow work His old Pro Charged motor ran with 35 lbs. of boost as well as with twin 88MM turbo, he swore his SB Ford heads flowed 430 + CFM at .700 lift work
He ran 6.87 at 195 MPH 5 years ago on those tires with that motor shruggy
My local competition is pretty tough, I spoke to one guy here at Milan, he says he is running 75 lbs of boost on his 481X, sounds insane to me. He just ran a 4.02 @196 down south the other month. Most boosted cars on radials around here run 40-45 LBS
Re: Project Zoom Me [Re: 590 Challenger] #2304235
05/14/17 11:20 AM
05/14/17 11:20 AM
Parts unknown
Parts unknown
I got it out, Having trouble with the engine cutting out, starts breaking up about 4,900, will not rev past 5,200. Short shifted at 4800 (instead of 6900) broke up on the top end for best pass of the day of 5.24 129MPH. So much more left in it
Re: Project Zoom Me [Re: 590 Challenger] #2304241
05/14/17 11:37 AM
05/14/17 11:37 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Just plain Bad Ass! Good luck finding the problem. It's early in the season. up
[image][/image]
Re: Project Zoom Me [Re: 590 Challenger] #2304318
05/14/17 02:04 PM
05/14/17 02:04 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Glad that you got it out. Sounds like your Grid is pulling timing or a rev limit is being activated somehow?
Re: Project Zoom Me [Re: 590 Challenger] #2304322
05/14/17 02:07 PM
05/14/17 02:07 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Car looks amazing!
Re: Project Zoom Me [Re: 590 Challenger] #2304365
05/14/17 03:30 PM
05/14/17 03:30 PM
Try closing up the spark plug gap down to .010 to .015 to get rid of the high speed miss thumbs
I've got a weird miss I'm chasing on my bracket car on E85, I wll conquer it hammer thumbs
Re: Project Zoom Me [Re: 590 Challenger] #2304485
05/14/17 08:09 PM
05/14/17 08:09 PM
Parts unknown
Parts unknown
Thanks Guys! I'm still pumped.
I changed the rev limiter twice had no effect.
Spark plug gap is at .025, with the ProMag 44 and alcohol I have been told that is where it needs to be......??? Do you run mags at 10-15 gap? is anyone running that combo tighter?
Re: Project Zoom Me [Re: 590 Challenger] #2304542
05/14/17 10:21 PM
05/14/17 10:21 PM
That guy I mentioned had his Pro Mag 44 amp plugs gap at .015 and then .010 when they turned the boost up on the BAE aluminum all billet motor shruggy They had to replace the coil wire a lot more often with that big amp mag also along with the spark plug wires more often than twice a year work
Re: Project Zoom Me [Re: 590 Challenger] #2304571
05/14/17 10:49 PM
05/14/17 10:49 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree
Heard that from my BAE buddys!
Re: Project Zoom Me [Re: 590 Challenger] #2304617
05/14/17 11:59 PM
05/14/17 11:59 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Did you have to make any tuning changes for the header change? I wonder if it leaned out some with the new Zoomies? Looks killer!
68 Barracuda Formula S 340
Re: Project Zoom Me [Re: 590 Challenger] #2304738
05/15/17 09:14 AM
05/15/17 09:14 AM
Parts unknown
Parts unknown
I had no fuel mixture change after adding the zoomies but the plugs don't look like they are getting too much heat. Next time out I will tighten up the spark gap and see what happens
Re: Project Zoom Me [Re: 590 Challenger] #2306338
05/17/17 10:04 PM
05/17/17 10:04 PM
Parts unknown
Parts unknown
Just thought I would toss this out , When we get it right she is going to scream. Even not running right I'm having a blast!!
https://www.facebook.com/photo.php?fbid=...4793&type=3
Re: Project Zoom Me [Re: 590 Challenger] #2306339
05/17/17 10:08 PM
05/17/17 10:08 PM
Parts unknown
Parts unknown
Crap, that didn't work.....try try again
Re: Project Zoom Me [Re: 590 Challenger] #2306341
05/17/17 10:09 PM
05/17/17 10:09 PM
Parts unknown
Parts unknown
I give, no video today
Re: Project Zoom Me [Re: 590 Challenger] #2306342
05/17/17 10:10 PM
05/17/17 10:10 PM
Parts unknown
Parts unknown
Re: Project Zoom Me [Re: 590 Challenger] #2308359
05/21/17 08:38 AM
05/21/17 08:38 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice work again Jeff, unfortunately I couldn't make it out Friday to see. As you said, it will really fly, just keep on your pace. Good to see you are making progress. Impressive!
Re: Project Zoom Me [Re: 590 Challenger] #2432317
01/10/18 05:18 PM
01/10/18 05:18 PM
Parts unknown
Parts unknown
I'm pretty pumped, I went to SSI and picked up a blower last night. This one should put out 40-45 PSI with a much cooler charge. I'm down sizing from 590 cubes to 528 on the Hemi......I can't wait to try it out, come on spring!!!!
https://imgur.com/InueUvB
https://imgur.com/8RGveBK
Re: Project Zoom Me [Re: 590 Challenger] #2432651
01/11/18 03:01 AM
01/11/18 03:01 AM
Superfreak
Superfreak
You will definitely make a lot more power.
Re: Project Zoom Me [Re: 590 Challenger] #2432661
01/11/18 03:56 AM
01/11/18 03:56 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The blower pics on facebook are sexy
Re: Project Zoom Me [Re: 590 Challenger] #2432737
01/11/18 10:45 AM
01/11/18 10:45 AM
Parts unknown
Parts unknown
Yeah thanks, I couldn't get the imgur oic thing working right yesterday
