Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292171
04/22/17 04:21 PM
04/22/17 04:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The deck isn't figured into the fill volume, but certainly has to be figured into the compression ratio calculations.
The pistons stick out of the bore .025(6.5cc) and you guys aren't accounting for that.
The cr is 14.69 based on the info in the original post.
It's not really debatable.......... It's just simple math.
If it was zero deck, you'd get rid of the -6.5 for the deck height and you'd have 1299.5/94.5 = 13.75
Re: help calculate my comp using 1/2"downfill method [Re: fast68plymouth] #2292174
04/22/17 04:33 PM
04/22/17 04:33 PM
California USA
LowDeck451 Offline
LowDeck451  Offline
California USA
OK, not meaning to debate really, just trying to understand.
Thanks!
Re: help calculate my comp using 1/2"downfill method [Re: B1MAXX] #2292177
04/22/17 04:39 PM
04/22/17 04:39 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Originally Posted By B1MAXX
When measuring actual down fill you cannot factor the deck height into the equation...
assume you have 4.00 bore, no valve pocket, no dish or dome for simplicity sake.
2x2x3.14=12.56x.500=6.28x16.387=102.9cc down fill.
we measure at .500 and get 110cc
110-102.9=7.1 cc extra vol. this mean/shows the piston is below deck .035 (2x2x3.14x.035=7.2cc)
believe me its in there. a number less than 102.9cc when actually measured would be would be above deck.
Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292190
04/22/17 04:59 PM
04/22/17 04:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
To my way of thinking, the fill down is used to determine the dome/dish volume...... Period.
I don't move the piston a given distance from tdc to determine the fill down distance(well, at least I've never done it this way), it's the distance from the top of the block.
A .500 fill down is done at .500 from the top of the block.
I suppose it could be done by moving the piston a specific distance from tdc, but which method of doing it would need to be clarified.
.500 from tdc, or .500 from the top of the block.
One way takes into account the deck clearance, one way doesn't.
I guess we'd need the OP to clarify which way it was done to know if it's 13.7 or 14.7.
My calculations are based on the fill volume being measured with the piston .500 from the top of the block.
Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292210
04/22/17 05:26 PM
04/22/17 05:26 PM
California USA
LowDeck451 Offline
LowDeck451  Offline
California USA
The way I understand it is, .500 down from TDC takes the dome (above deck), valve notches (below deck) into account, and that the amount more than, or less than the perfect .500 volume (130cc in this case) indicates 'more', or 'less' chamber volume.
Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292234
04/22/17 05:57 PM
04/22/17 05:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
The "problem" with this example is...... The pistons stick out .025".
If you move the piston .500" from that position it's only down .475" from the top of the block.
So, you're going to seal up the piston to the bore, put your piece of plexiglass on top of the block and fill it up.
The OP said they observed 129cc of volume to fill it up.
The piston isn't .500" from the top of the block, it's only .475" from the top of the block(if it's .500" from tdc).
The area for the 4.5" x .475" bore is 123.8...... Not 130.3.
So if you observe 129cc fill volume, you have 5.2cc(+)worth of valve pocket, not 1.3cc(-)worth of dome volume.
You've poured 129cc of liquid into what should only be a 123.8cc hole.
That would give you the 1299.5/94.5 = 13.75 result.
1205 - swept
76 - gasket
19.8 - gasket
5.2 - dish vol
-6.5 - deck
1299.5
94.5 total minus swept
13.75(1299.5/94.5)
In this case, whether the .500" dimension is from tdc or from the top of the block changes the results by almost 1 point.
It looks like this is a case where a slight difference in how some terminology is interpreted makes a difference in the bottom line.
I use the fill down volume to determine the piston dish/dome volume by itself.
The OP would have to clarify how they did it to know what the cr actually is.
Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292284
04/22/17 07:19 PM
04/22/17 07:19 PM
California USA
LowDeck451 Offline
LowDeck451  Offline
California USA
The 5.2cc valve notches increase chamber volume, the +.025 deck height= 6.5cc- decreases chamber volume, the difference-1.3cc is the effective 'dome' above deck, and is subtracted from chamber volume. Also, if you moved a domed piston down from the top of the block, where would you measure from, the top of the dome, the edge of the piston? Still wouldn't tell you how much volume is above deck. I believe the only way to account for an odd shaped domed piston top (dome above deck, notches below deck) is to move the piston down from TDC, pour and compare to an ideal cylinder volume. I agree, the OP should describe how he got his 129cc.
Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292291
04/22/17 07:32 PM
04/22/17 07:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
The bottom line is, the difference in this case is 6.5cc, depending on how you measured it, which is the .025 of deck.
To your point about the irregular piston shape affecting the value.....
The 4.50 x .025 area is 6.5cc.
If the fill down was done at .500 below tdc, the piston dish is 5.2cc.
If the fill down was done at .500 below the top of the block, there is a dome volume of -1.3cc.
The difference between the +5.2 and the -1.3 is still 6.5cc.
Think of it this way.......
Assuming this irregular shaped piston in a 4.50 bore is completely below the deck at tdc by .100(an arbitrary number).
Now slice .025 off the top of the block so the piston is .075 down the hole.
How much did you reduce the volume?
How much did the irregular shaped piston affect it?
Re: help calculate my comp using 1/2"downfill method [Re: fast68plymouth] #2292302
04/22/17 08:06 PM
04/22/17 08:06 PM
K
KOS Offline OP
KOS  Offline OP
K
yes Dwayne correct.....i put the piston few inches in the hole greased it up and moved it up the bore till it was .500 down not taking into account its .025 out of the hole thats why i specified its .025 out of the hole.your math is correct its 14.6.now with .010 or so block growth(alum)14.5ish true.
Re: help calculate my comp using 1/2"downfill method [Re: fast68plymouth] #2292337
04/22/17 08:50 PM
04/22/17 08:50 PM
California USA
LowDeck451 Offline
LowDeck451  Offline
California USA
6.5cc
0cc
Hmmmm........
Now just gotta visualize it in my head. Thanks for your time Dwayne!
Re: help calculate my comp using 1/2"downfill method [Re: LowDeck451] #2292609
04/23/17 11:05 AM
04/23/17 11:05 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
.500 down is from TDC not deck.... we are figuring bdc and tdc volumes. why would you use the deck to measure from?
The first thing I do is bring the piston up ...0 the indicator...and drop it .500.... the piston could be above or below deck. the difference in this number from the deck(the perfect number vol.) is exactly what your measuring.
Re: help calculate my comp using 1/2"downfill method [Re: B1MAXX] #2292619
04/23/17 11:27 AM
04/23/17 11:27 AM
K
KOS Offline OP
KOS  Offline OP
K
[quote=B1MAXX].500 down is from TDC not deck.... we are figuring bdc and tdc volumes. why would you use the deck to measure from? [/quote
i guess i coulda measured it .475 down but to me it was easier to account for the postive deck after.ive never had to use this method before i usually have piston specs so im alittle green on the topic but i get what your saying.i guess i get where all the confusion was coming from ......
Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292626
04/23/17 11:43 AM
04/23/17 11:43 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
the down fill is for when a piston has any part of itself above deck. dome or the whole thing or both, so that we can measure it. To add the deck height back in to the equation would be double dippin.
Re: help calculate my comp using 1/2"downfill method [Re: B1MAXX] #2292633
04/23/17 11:49 AM
04/23/17 11:49 AM
K
KOS Offline OP
KOS  Offline OP
K
10/4 smile
Re: help calculate my comp using 1/2"downfill method [Re: B1MAXX] #2292661
04/23/17 12:50 PM
04/23/17 12:50 PM
So. Burlington, Vt.
So. Burlington, Vt.
Just to be clear, not everyone does it this way.
I, for one, don't.
I use the fill down method for determining dome volume only.
This is what the OP did as well.
Once I have that value, I can plug it in to the calculation and see where I'm at, and then easily make adjustments to chamber volume, deck clearance, etc if I need to change the cr to meet a target.
Re: help calculate my comp using 1/2"downfill method [Re: B1MAXX] #2292663
04/23/17 12:53 PM
04/23/17 12:53 PM
California USA
LowDeck451 Offline
LowDeck451  Offline
California USA
Yeah. I keep coming back to the 'From TDC' method.
Re: help calculate my comp using 1/2"downfill method [Re: fast68plymouth] #2292698
04/23/17 01:36 PM
04/23/17 01:36 PM
K
KOS Offline OP
KOS  Offline OP
K
[quote=B1MAXX]the down fill is for when a piston has any part of itself above deck. dome or the whole thing or both, so that we can measure it. To add the deck height back in to the equation would be double dippin.
I, for one, don't.
Once I have that value, I can plug it in to the calculation and see where I'm at, and then easily make adjustments to chamber volume, deck clearance, etc if I need to change the cr to meet a target. [/quot
good to know im not the only one thinking the same way.....thx Dwayne for clarifying that.
Re: help calculate my comp using 1/2"downfill method [Re: KOS] #2292707
04/23/17 01:51 PM
04/23/17 01:51 PM
So. Burlington, Vt.
So. Burlington, Vt.
The "tdc method" does not solve for dish/dome volume. It combines the dish/dome volume with the deck clearance.
Using previously mentioned perfectly flat 4.00 piston.......
The fill down for 4.00 x .500 is 103cc.
If you measured the .500 from tdc, and observed a fill volume of 98.9cc, what would you call the dish/dome volume?
The piston itself has zero volume.......the fact that it's sitting above the deck .020 is where the reduction of 4.1cc's comes from.
Which way you do the math won't change what the actual cr is, it just makes more sense to me to use the actual dome volumes and deck volumes instead of combining them.
Either way will work, just make sure if you're comparing notes with someone else that everyone is on the same page.
As this thread has shown, when you're not.........the results can be way off.
Re: help calculate my comp using 1/2"downfill method [Re: fast68plymouth] #2296573
04/30/17 03:15 PM
04/30/17 03:15 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Dwayne thanks for your patience and willingness to help/teach us.
Don
