Re: Thank you QC Coatings [Re: MR_P_BODY] #2293111
04/24/17 09:40 AM
04/24/17 09:40 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I see the timing for 34* and the dominator fine on my small block. I may send it to Dom to check it out. Maybe he can run it on his 472.
Re: Thank you QC Coatings [Re: mopar dave] #2293187
04/24/17 12:59 PM
04/24/17 12:59 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
TTI coatings are junk.
The ceramic has some surface rust showing...the car gets caught in the rain every now and then, but is never put away wet.
Also had a chromed set that were not supposed to rust...well, they rusted out nearly...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Thank you QC Coatings [Re: mopar dave] #2293420
04/24/17 08:41 PM
04/24/17 08:41 PM
Detroit, MI
CCPcoatings.com Offline
Detroit, MI
Regardless of who coats your headers, you NEVER want to break in an engine, or dyno an engine with a with a set of polished ceramic headers. Polished ceramic is only rated at 1000F - 1100F metal temp which translates to around 1200F -1400F EGT. Improper fuel or timing will dull out a set of polished headers in literally a minute or two. Once they get hot enough to dull, the pores open on the surface of the coating and the headers will begin to get rust spotting shortly after. The headers below had a 2000F thermal barrier on the ID and still dulled in a few minutes due to a lean start scenario....
If they're coated with a high temp ceramic, i.e. 1800F - 2000F this isn't generally a problem.
Re: Thank you QC Coatings [Re: CCPcoatings.com] #2294125
04/25/17 09:55 PM
04/25/17 09:55 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
aka order them black or unpolished if you plan on driving it!
Re: Thank you QC Coatings [Re: CCPcoatings.com] #2294149
04/25/17 10:39 PM
04/25/17 10:39 PM
Mt Morris Michigan
Mt Morris Michigan
ok, that's not a real problem for me. I thought they are too shinny anyways. I have no other choice. only set of headers I have.
