Re: Mopar Big Block Purple Cam 509 $ [Re: ZIPPY] #2291571
04/21/17 02:17 PM
04/21/17 02:17 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
When I bought my 509 16ish yrs ago I think it was $118 for cam and lifter kit. And it was more expensive than Comp and a few others then too. I bought it because I guess I fell for the "built by Mopar for a Mopar" advertising they had back then.
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291577
04/21/17 02:24 PM
04/21/17 02:24 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you're not wanting to mess with pushrod length the lifters would be the 822's.
Re: Mopar Big Block Purple Cam 509 $ [Re: fast68plymouth] #2291604
04/21/17 03:13 PM
04/21/17 03:13 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Thanx!!
I really don't want to worry about the push rod length.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291615
04/21/17 03:26 PM
04/21/17 03:26 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I ran the 108 .509 cam in a 440 with Rhoads lifters and Crane gold roller rockers and loved the cam. I still have the set up and plan on slapping together a low budget build and just having fun with it.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291965
04/22/17 03:38 AM
04/22/17 03:38 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Maybe it's one of those things where people think it's better and will buy it if it's overpriced, where before no one would touch it for $189.00.
68 Roadrunner. 383 4-spd. Beat up.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2292048
04/22/17 12:44 PM
04/22/17 12:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
I just figured they decided they didn't want to sell them anymore.
Cuz for $450+ they're going to sell waaaaaaaay fewer of them.
Would make for a fun(?) dyno shootout.
The $450+ hyd cam vs a couple of similar grinds that are 1/2 price(or less).
Some possible candidates:
Comp PP292H
Comp 296H-8
Isky Mega-Cam 292-108
Howard's 722251-09
Lunati Street Master 295-108
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2292631
04/23/17 11:47 AM
04/23/17 11:47 AM
scratchnfotraction Offline
Is that texas383 yellow?
I would call Hughes Engines and get something from them. Just MHO.
read to many failures on comp cams.
love my 440 whiplash cam. I am sure they got something as close or better for your 383.
102*/108*
230*/245* @ .050
.518/.518-1.5 ratio
stock PR/rockers/retainers
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2292634
04/23/17 11:55 AM
04/23/17 11:55 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
The Racer Brown SSH-44 would be pretty close.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2293220
04/24/17 02:04 PM
04/24/17 02:04 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
... can I safely assume if I buy the cam/lifter kit in any of the cams recommended that I can use stock length push rods?
I pulled the lifters and cam yesterday. WOW!!! 8 of the 16 lobes were ground way down and the lifters ranged from severely cupped to having the lobe worn way down into the lifter as if it never rotated at all. The other 8 oddly looked as if there was none to extremely little wear on them. All the lobes and lifter with crazy amounts of wear were in the middle of the cam with both ends looking new still.
What the heck would cause that!?!? The cam was in for 16 yrs with 10-20K miles on it since I don't drive it daily. I'm not sure when this happened with the cam. The last time I drove it had great power then made rattling/knocking noise lost power and died.
1969 Y2 Super Bee
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2293232
04/24/17 02:20 PM
04/24/17 02:20 PM
dogdays Offline
dogdays  Offline
When's the last time you changed the oil? You say it's not a daily driver. How long does it sit? Did it sit for a long time after the last time you changed the oil?
My guess is that you changed the oil and put in whatever was on the shelf at Walmart. This oil was one of the SN or slightly older oils with lower levels of antiwear chemicals (zinc). Then the engine sat for several weeks so the next time it started pretty dry. It doesn't take that long for the cam and lifters to commit suicide.
The bad news is that all the material ground off the cam lobes and lifter bottoms made its way into the oiling system and now you need to clean everything.
R.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2293235
04/24/17 02:25 PM
04/24/17 02:25 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Uh oh...I think this just went from a cam discussion to a pull the engine and clean and freshen discussion... wrench
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Mopar Big Block Purple Cam 509 $ [Re: dogdays] #2293263
04/24/17 03:18 PM
04/24/17 03:18 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
It did sit for a long time.... between moving to a new house and having transmission failure.
Hopefully the new cam will not have to sit and the car will be driven more often as it will be more of a semi daily driver now that I've moved
1969 Y2 Super Bee
