Page 2 of 3 1 2 3
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2294836
04/27/17 02:33 AM
04/27/17 02:33 AM
California
slowfab Offline OP
slowfab  Offline OP
California
The fabrication of the turbo system was a large challenge in packaging. With OEM power steering, A/C and cutting of the car kept at a minimum. Only 2 large holes were cut in the car. That was where the tubes leave the inter coolers and run through the inner edge of the fenders and through the core support. The air leaves the turbos and exits down toward the ground and through the inlets to the intercoolers. All of that was not so bad. The exhaust and waste gate plumbing was the real issue.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2295334
04/27/17 11:08 PM
04/27/17 11:08 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Holy cow that looks neat. The way I love to see stuff. Great job, keep up the good work. The progress is moving quick on this one.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2295416
04/28/17 01:32 AM
04/28/17 01:32 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Here is plumbing in the waste gates.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2295421
04/28/17 01:36 AM
04/28/17 01:36 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Building the driver side exhaust was a challenge. Found some very tight stainless U-bends on ebay that worked great.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2295422
04/28/17 01:38 AM
04/28/17 01:38 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Connecting in the waste gate on the driver side.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2295426
04/28/17 01:42 AM
04/28/17 01:42 AM
California
slowfab Offline OP
slowfab  Offline OP
California
The waste gate and turbo outlet section pre and post jethot coated. Used their ultra high temp so I did not have to worry about "burning off" the standard coating while dialing in the tune. Also was trying to keep as much heat in the exhaust instead of cooking the fiberglass hood.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2295930
04/29/17 04:07 AM
04/29/17 04:07 AM
California
slowfab Offline OP
slowfab  Offline OP
California
With all the coated items back in. Running all the oil and cooling lines to the turbos done. Finishing up the heater hoses.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2295931
04/29/17 04:09 AM
04/29/17 04:09 AM
California
slowfab Offline OP
slowfab  Offline OP
California
In this picture it shows how little room there is with the fans in. The waste gates actually fit into the shroud in spots.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2298126
05/03/17 03:53 AM
05/03/17 03:53 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Mocking up the Throttle body ducting.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2305934
05/17/17 10:01 AM
05/17/17 10:01 AM
uk
TiMopar Offline
TiMopar  Offline
uk
Very nice build, look forward to seeing this finished! If you don't mind my saying so, the old radiator looks a little out of place now : )) Good luck!
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2313264
05/29/17 10:07 PM
05/29/17 10:07 PM
California
slowfab Offline OP
slowfab  Offline OP
California
Here is a pic with the done engine compartment. Yes, the stock radiator is not as flashy as the rest but I have had issues with aluminum ones in the past and this one works great.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2313435
05/30/17 10:21 AM
05/30/17 10:21 AM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
Looks like a beast with A/C !!
Looking for affordable 72-74 Cuda parts
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2314054
05/31/17 09:11 AM
05/31/17 09:11 AM
uk
TiMopar Offline
TiMopar  Offline
uk
Looks great, how does it go???
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315457
06/03/17 02:59 AM
06/03/17 02:59 AM
California
slowfab Offline OP
slowfab  Offline OP
California
It runs good. Running low boost as its a stock block, rods and crank. Had it chassis dyno'd and it has 516hp and 582ft lbs of torque at the wheels at 9psi boost.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315458
06/03/17 03:17 AM
06/03/17 03:17 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Here is the inside with the sound deadener installed. Raised the rear of the tunnel a little so it can sit a little lower and not have any issues hitting the yoke or driveshaft
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315459
06/03/17 03:19 AM
06/03/17 03:19 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Here is a view of the magnaflow exhaust from the rear.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315460
06/03/17 03:20 AM
06/03/17 03:20 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Front view.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315461
06/03/17 03:26 AM
06/03/17 03:26 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Here is a view of one inner fender. Above the intercoolers there is a air pump (smog) from a modern can re-purposed as crank case vac's. One each side connected to each valve cover. I have the PCM control them through a pulse width module. From 500rpm to 2000rpm they run at 30%. From there they ramp up to 100% by 3500rpm.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315462
06/03/17 03:28 AM
06/03/17 03:28 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Side view. I went with a satin finish where flat/semi gloss would normally be (hood,stripes,spoiler,tail panel) for a more modern touch.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315463
06/03/17 03:30 AM
06/03/17 03:30 AM
California
slowfab Offline OP
slowfab  Offline OP
California
rear
Page 2 of 3 1 2 3
