Page 3 of 3 1 2 3
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: hudsonhornet7x] #2291782
04/21/17 09:16 PM
04/21/17 09:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By hudsonhornet7x
Mr. P Body, What do you use to measure back pressure? I would love to learn this.
I had a great tool at the Dodge dealer when I worked there. We had a lab Scope adapter setup for the DRBIII and part of it was an adapter/transducer that screwed in where the 02 sensor went. Then as long as the DRBIII had the Pep module on it it had a spot where you could read pressure and it worked great. It also had a transducer to read fuel pressure and an Inclinometer. But basically the transducer to read pressure screwed right into the 02 sensor bung. Ron
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: Pale_Roader] #2291788
04/21/17 09:30 PM
04/21/17 09:30 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I tried that with an X-pipe but it was way loud inside the car... also MO requires tailpipes to exit from underneath the body.
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: 383man] #2291806
04/21/17 10:15 PM
04/21/17 10:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah we did the same thing but just on exhaust..
the tap works well and very simple.. we did a lot
of pressure testing in exhaust and ran hundreds of
taps on the systems.. I normally had about 50 pressure
taps on each car
EDIT
pressure taps were easy and we ran a ton of temp
readings per car.. about 200 readings per car was
normal... but took up to about 500 readings per cars
wave
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: Spaceman Spiff] #2291813
04/21/17 10:32 PM
04/21/17 10:32 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Originally Posted By Spaceman Spiff
FAST class cars are required to run 2 1/2.....
And look how much power they make. Some run 130+mph
Excuse me sir, some of them run 140+mph. (Shameless plug for Mr. Dudek who broke the 140mph barrier last year). up
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: MR_P_BODY] #2291830
04/21/17 11:04 PM
04/21/17 11:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By MR_P_BODY
Again.. I will ask what is your back pressure...
we still dont know crap yet.. if you can say
what your REAL back pressure is we would have
a clue to what the flow of the system is.. everyone
wants to throw out HP numbers but if system X is
this much back pressure and system Y is this much
it will say A LOT.. I measure mine so I do have a
clue to what it is.. a simple gauge hook up will
tell you
EDIT
And state at what RPM
wave
Never measured and my math on my dart has been bigger heads, cams comp etc, like a bigger exhaust but it would be interesting to test some time but still would change it unless it WAS a restriction............ beer
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: Thumperdart] #2291855
04/21/17 11:44 PM
04/21/17 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
tell you
EDIT
wave
With out a back pressure reading you have NO
clue what your exhaust is doing.. try taking a
reading and see where your at
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: Pale_Roader] #2291891
04/22/17 01:02 AM
04/22/17 01:02 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
4" inch on my 2 litre turbo car... With turbo, its basically as big as you can fit on the car...
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: Pale_Roader] #2292055
04/22/17 12:55 PM
04/22/17 12:55 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I pick up 0.1 in the 1/4 on my 3"/H-pipe TTI system when I open the dumps on my iron head 493"
The weight is the same, and this is back to back, EFI keeps the AFR consistent.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: At what point (CID/HP) do you need a 3" exhaust? [Re: OUTLAWD] #2292144
04/22/17 03:37 PM
04/22/17 03:37 PM
Real world results up bow
Page 3 of 3 1 2 3
