Re: The Borgeson box *&$*$%# Continued!
[Re: redmist]
#2298546
05/03/17 10:46 PM
05/03/17 10:46 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Well this is Moparts where guys can't seem to bolt in stock parts without some level of problems...now if you happen to take your car to someone and bolting in a Borgeson box in is outside their comfort zone you might want to look for a new place to get work done....by some miracle there likely 1000's of these on the road in classic Mopars at this point.
I have purchased from Peter at Bergman Auto before and had no problem getting ahold of him by phone or email to discuss any concerns.
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#2298549
05/03/17 10:54 PM
05/03/17 10:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
And there are millions of factory boxes that bolted up with ZERO problems. The problem isn't the installer, it's a manufacturing defect.
[Re: Supercuda]
#2298568
05/03/17 11:19 PM
05/03/17 11:19 PM
Posts: 190 NJ
JH23
NJ
I guess after this thread the E body Borgeson box will be discontinued.
[Re: Supercuda]
#2298579
05/03/17 11:37 PM
05/03/17 11:37 PM
67autocross
Manitoba Canada
And there are millions of factory boxes that bolted up with ZERO problems. The problem isn't the installer, it's a manufacturing defect. Well this is Moparts where guys can't seem to bolt in stock parts without some level of problems...now if you happen to take your car to someone and bolting in a Borgeson box in is outside their comfort zone you might want to look for a new place to get work done....by some miracle there likely 1000's of these on the road in classic Mopars at this point.
And there are millions of factory boxes that bolted up with ZERO problems. The problem isn't the installer, it's a manufacturing defect. Who cares how many cars came from the factory with factory boxes... most likely all of them did.
[Re: JH23]
#2298580
05/03/17 11:38 PM
05/03/17 11:38 PM
67autocross
Manitoba Canada
I guess after this thread the E body Borgeson box will be discontinued. I'm sure they will stop....
[Re: JH23]
#2298586
05/03/17 11:44 PM
05/03/17 11:44 PM
Supercuda
About to go away
About to go away
up yours
I guess after this thread the E body Borgeson box will be discontinued. There is no "E body box", nor will it be discontinued, nor will the known issues be addressed.
[Re: Supercuda]
#2298593
05/03/17 11:50 PM
05/03/17 11:50 PM
67autocross
Manitoba Canada
I guess after this thread the E body Borgeson box will be discontinued. There is no "E body box", nor will it be discontinued, nor will the known issues be addressed. You should contact Borgeson and let them know...
[Re: Supercuda]
#2298598
05/03/17 11:54 PM
05/03/17 11:54 PM
67autocross
Manitoba Canada
Anyone willing to pay Borgeson's price for a POS that doesn't fit right is not too smart. A bit of tweaking is jets, a 1/2" offset in the steering box is a design flaw. Not sure I want to learn the hard way what else they half @ssed designing this. Why do you keep posting in this thread? Do you have something to add or are you just trying to save the rest of us from making a huge mistake?...should I run out to the garage and start pulling these boxes off my cars now that you have told me they don't fit....
[Re: 67autocross]
#2298779
05/04/17 11:20 AM
05/04/17 11:20 AM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
We did, numerous times for different reasons. Its been documented on this forum as an informative install post so that folks could see what the problems were an how to fix it.
