Re: What converters you guys using in 10 sec street/strip cars [Re: D-50] #2287866
04/14/17 08:57 PM
04/14/17 08:57 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
My street 69 GTX is very similar to your RR. 493 with 11.4 compression. Pump gas set up. Eddy performers ported by Modern (325 cfm @ 600 lift) custom solid roller 620 lift and 260 duration. (car has power brakes that work perfect)MSD ignition, Street Dominator with a 4150 holley 1000 cfm carb.
3.73 gears, caltrack springs, bars and shocks on stock front and rear suspension. 3960 lbs with driver.275/50/15 Hoosier drag radial
Car has gone 1.49 60 ft and 10.84 at 123.50.
I broke a 10 inch Turbo Action twice! I talked to Paul and he recommended the tightest 8 inch because it had all the heavy duty internals. (remember we have HEAVY cars) It has been in the car since about 2004 with about 15,000 street miles and well over a thousand passes. Very easy to drive on the street. I launch off idle at around 1100 RPM. Nice street/strip converter.
Oh yeah, this thing makes 494 RWHP
Re: What converters you guys using in 10 sec street/strip cars [Re: mercman1] #2287880
04/14/17 09:36 PM
04/14/17 09:36 PM
Temperance, MI
68 HEMI GTS Offline OP
Temperance, MI
Wow, extremely similar car/combo. That's good to know an 8" works in your car. That's the info I was hoping to find. Thanks!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2287938
04/14/17 11:17 PM
04/14/17 11:17 PM
Temperance, MI
Temperance, MI
Lots of great info guys!! Thanks for the replies. I have some good info to base a decision on.
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2287968
04/14/17 11:59 PM
04/14/17 11:59 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
My tight 8 inch TA converter will flash to maybe 34-3500. car would be faster with more stall. then more gear, then less weight, then???? Not a street car any more in my eyes.
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2288003
04/15/17 01:07 AM
04/15/17 01:07 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I probably have the only GER Thunderbolt 3500 stall converter that GER got right! For a 904, no less. I did crack a pump drive, which I got replaced with a chrome-moly one, but my lowly GER has went 30K+ street miles and at least 400 low 11 second motor passes, plus a handfull of 10.60 at 130 - 1.42/60' passes on a 100 shot. 360LA engine, low gear set 904, 3.89 gears, 3150 race weight. I think they called it a 3500 stall 9 3/4" - I can usually hold it to about 3800-3900 on the line. I've tried 2 other "name brand" 9 1/2" 3500 stall converters, and both were tighter at idle and slowed the car down about 3 tenths. I know the next pass may be it's last, but it was the best $269 I ever spent on race car parts. We bought 2 more of them after I bought mine and GUTTED them in 12.50 cars!
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: What converters you guys using in 10 sec street/strip cars [Re: nss guy] #2288044
04/15/17 02:36 AM
04/15/17 02:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By nss guy
ATI 8" Treemaster
Do you drive it on the street with the 8" ATI converter ? Ron
Re: What converters you guys using in 10 sec street/strip cars [Re: 383man] #2288103
04/15/17 10:18 AM
04/15/17 10:18 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I used to drive my car on the street with 8" ATI. It's possible but probably would not do it again. I'm much happier with a 9 1/2" that flashes to 4,500 for street use.
Re: What converters you guys using in 10 sec street/strip cars [Re: Tempest] #2288110
04/15/17 10:37 AM
04/15/17 10:37 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
I'm reading this post with a lot of interest. Only issue I see with the answers is we need a better description of street driven. I have a 3300 stall ati behind my hemi dart clone ( what they recommended) and it seems tight to me BUT my street driving is 20 miles of highway to get to car shows etc. I cruise at 3200 rpm at 60 mph and my concern is slippage then. Around town I would just stay out of high gear to keep the rpms up. Thoughts please!
can 13
Re: What converters you guys using in 10 sec street/strip cars [Re: D-50] #2288112
04/15/17 10:52 AM
04/15/17 10:52 AM
moparx Offline
moparx  Offline
does a lighter car [2000-2500, 500-550hp, 4.88 gear,33" tall tire] need a tighter or looser converter to be comfortable on the street compared to an all out track car ? i realize this is a stupid question, as there are no real concrete results to compare to, but a long, long time ago, i remember something about the weight coming into play as an important ingredient in determining stall for a light weight car. insights into this thought, and help for my stupidity ?
beer
Re: What converters you guys using in 10 sec street/strip cars [Re: moparx] #2288143
04/15/17 11:57 AM
04/15/17 11:57 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Lenny at Ultimate, I have three of them done by him
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2288175
04/15/17 12:52 PM
04/15/17 12:52 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Another vote for the 9 1/2 ATI. I picked up a solid 0.30 in E.T. over the custom Gary Gonzales converter.
Re: What converters you guys using in 10 sec street/strip cars [Re: sixpackgut] #2288234
04/15/17 02:41 PM
04/15/17 02:41 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Originally Posted By sixpackgut
That cracks me up. ATI flat out refused to build me an 8" for my BB 493 because I street drive my car.
That's weird, they built my 8" converter for 25% street use, although it's been several years now.
I always used 8" converters in my 9 second big block street cars.
My current car is 95% street and I'm hoping to squeak into a 10.99 with a 9.5" Dynamic converter.
Re: What converters you guys using in 10 sec street/strip cars [Re: 3ddart] #2288236
04/15/17 02:44 PM
04/15/17 02:44 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
What size case is your 3300 stall? I think you'll be fine, my 9.5" Dynamic is kinda loose and I drive it around town with 3.23 gears, on the highway I'm around 2450 RPM's at 60mph.
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2288241
04/15/17 02:49 PM
04/15/17 02:49 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I drove this car quite a bit on the street with an 8" ATI custom Treemaster and 4.30 gears.
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2288257
04/15/17 03:09 PM
04/15/17 03:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Ultimate Converter built me a tight 9" converter that is great on the street, but will flash stall to about 5,000 rpm.
For the track it is likely too tight to really hit hard (foot brake racing), but I wanted it tight so it drive nice on the street, which it does.
Re: What converters you guys using in 10 sec street/strip cars [Re: 383man] #2288409
04/15/17 08:45 PM
04/15/17 08:45 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
ATI 8" Treemaster
yes I drive it on the street, not too much anymore. My street tires, 30x13 ET streets are about shot. The car drives very good with the 8", not much different driving in town than my 10" tci from years ago. The big difference is when you really launch it, yea it flashes to about 5400.The 10" just doesn't flash as high. No heat problems with a good cooler.
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2288413
04/15/17 08:55 PM
04/15/17 08:55 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Though you disavow Dynamic/Lupo that is what i have run for 7 (?) Years or so . Daily driver / bracket racer . It is a 5100 stall , i think 9 1/2" maybe 9
Has gone from low 11s behind a 440 to mid 10s behind current 505
I do around 6-8000 street/highway miles per year, and race monthly . Longest 1 way trip was 12 hours straight , race and then back .
I wish there was more racing here .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What converters you guys using in 10 sec street/strip cars [Re: 68 HEMI GTS] #2288427
04/15/17 09:23 PM
04/15/17 09:23 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i live in pa not too far from GER and Dynamic. had a GER and don't know if they are still around. i have the dynamic in for a while now in a low 10sec duster with a 440. it flashes around 5200 to 5400. no issues and i just had it updated after it was about 6 years old. only thing i can compare it to is the GER and well i'm sure the ger would slow my car down but i neverbroke it. and i call it old faithfull.
Re: What converters you guys using in 10 sec street/strip cars [Re: dmking] #2288722
04/16/17 12:26 PM
04/16/17 12:26 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Been using 10" Turbo Action and 9.5 PTC convertors. No problems with either.
The only Carbs I care about are under the hood!
Re: What converters you guys using in 10 sec street/strip cars [Re: nss guy] #2288744
04/16/17 12:46 PM
04/16/17 12:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
ATI 8" Treemaster
Thanks. wave Ron
