Re: How can I get my 440 to wake up!!?? Something's wrong.
[Re: Mopar1970440]
#2287263
04/13/17 09:04 PM
04/13/17 09:04 PM
Posts: 6,572 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Ive found out the 284 and 292 mopar cams need alot of stall and low gears for sure to get out of the hole. There was an article in a mopar mag a few years back of a 70 roadrunner that had the 284 mopar cam and was a dog, they swapped in a XE comp cam and it came alive and picked up HP. That doesn't come as a big surprise given Comp is a big advertiser there. Kevin
[Re: fast68plymouth]
#2287656
04/14/17 01:42 PM
04/14/17 01:42 PM
Posts: 2,540 God's Country Maryland
GODSCOUNTRY340
Sooooooooo............
Car shreds tires.......change converter......... car is a mutt.........now it needs a different carb??
That must be an interesting trouble shooting chart. My thoughts exactly. If all you did was change the convertor and now it's a dog, get rid of that convertor.
[Re: mopower440]
#2287683
04/14/17 02:32 PM
04/14/17 02:32 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
I have damn near the same setup except I DO have the TRW six pack pistons which give more compression and I have the 284 installed 4 degrees advanced and a Mopar performance 2500 stall convertor. I have 323 gears. stock 452 heads and stock intake with a modified TQ. This is in my 1972 dart. It will burn the tires off until I let out of it!! My only complaint is that it quits pulling after 5500 rpm. I need more flow at high rpm! I want some better heads! The advanced cam timing is taking away the top end, change that first.
[Re: Twostick]
#2287697
04/14/17 03:03 PM
04/14/17 03:03 PM
Posts: 781 usa
Mopar1970440
usa
Ive found out the 284 and 292 mopar cams need alot of stall and low gears for sure to get out of the hole. There was an article in a mopar mag a few years back of a 70 roadrunner that had the 284 mopar cam and was a dog, they swapped in a XE comp cam and it came alive and picked up HP. That doesn't come as a big surprise given Comp is a big advertiser there. Kevin well my personal experience I went from the mopar 292 cam to a XE294 in a low compression 440 and my ET dropped and the drivability improved and I get no check or funds from Comp cams for saying this statement.
[Re: Mopar1970440]
#2287729
04/14/17 03:59 PM
04/14/17 03:59 PM
Twostick
Still wishing...
Still wishing...
Ive found out the 284 and 292 mopar cams need alot of stall and low gears for sure to get out of the hole. There was an article in a mopar mag a few years back of a 70 roadrunner that had the 284 mopar cam and was a dog, they swapped in a XE comp cam and it came alive and picked up HP. That doesn't come as a big surprise given Comp is a big advertiser there. Kevin well my personal experience I went from the mopar 292 cam to a XE294 in a low compression 440 and my ET dropped and the drivability improved and I get no check or funds from Comp cams for saying this statement. As is the case with the magazine reference, without seeing the rest of the cam specs/ICL we could speculate all day on why that happened. If the MP cam in the magazine was installed say 4 deg retarded either deliberately or because whoever just lined up the dots and the Comp was dialed in properly and installed 4 deg advanced, it should come as no surprise that "it came alive" especially if it was a low compression engine and the cam specs are similar ie same lift and duration @.050, overlap LSA etc. Kevin
[Re: Twostick]
#2287732
04/14/17 04:10 PM
04/14/17 04:10 PM
Posts: 781 usa
Mopar1970440
usa
Ive found out the 284 and 292 mopar cams need alot of stall and low gears for sure to get out of the hole. There was an article in a mopar mag a few years back of a 70 roadrunner that had the 284 mopar cam and was a dog, they swapped in a XE comp cam and it came alive and picked up HP. That doesn't come as a big surprise given Comp is a big advertiser there. Kevin well my personal experience I went from the mopar 292 cam to a XE294 in a low compression 440 and my ET dropped and the drivability improved and I get no check or funds from Comp cams for saying this statement. As is the case with the magazine reference, without seeing the rest of the cam specs/ICL we could speculate all day on why that happened. If the MP cam in the magazine was installed say 4 deg retarded either deliberately or because whoever just lined up the dots and the Comp was dialed in properly and installed 4 deg advanced, it should come as no surprise that "it came alive" especially if it was a low compression engine and the cam specs are similar ie same lift and duration @.050, overlap LSA etc. Kevin True... that's why I threw my real world experience in there on the 292 cam to xe294 cam. We could speculate all day on comp being an advertiser there and what really happened as you said.
[Re: A727Tflite]
#2287780
04/14/17 05:47 PM
04/14/17 05:47 PM
Posts: 10,783 North Dakota
6PakBee
North Dakota
...How about you check and see how high you can get the engine against the converter ? Warm it up thoroughly then mash the brakes and then see how high the engine will go in first gear. A real 340 converter in your package should get you around 2600 to 2800 stall. If not then likely your stator overrunning clutch is failed in the converter. Or it's not a real 340 converter. A failed stator ORC will run down the road fine but make the car lazy off the line.... I'm waiting for the results of the stall test.
[Re: NANKET]
#2287867
04/14/17 09:00 PM
04/14/17 09:00 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I have damn near the same setup except I DO have the TRW six pack pistons which give more compression and I have the 284 installed 4 degrees advanced and a Mopar performance 2500 stall convertor. I have 323 gears. stock 452 heads and stock intake with a modified TQ. This is in my 1972 dart. It will burn the tires off until I let out of it!! My only complaint is that it quits pulling after 5500 rpm. I need more flow at high rpm! I want some better heads! The advanced cam timing is taking away the top end, change that first. Maybe.... Don't most stock iron heads drop off after 5500 rpms anyway? Maybe not a cam problem in his case.
[Re: VITC_GTX]
#2287914
04/14/17 10:43 PM
04/14/17 10:43 PM
Posts: 8,388 fredericksburg,va
cudaman1969
fredericksburg,va
I have had the stock 906s pull good to 6500, solid and roller cams. I had a stock 77 440 with the 509 cam go dead at 5000, same cam in a 383 pull to 6500, degree the same, cam, lifters, chain, rockers, springs changed from one to the other.
