Re: Recipe for 700hp six pack 440 or bigger-
[Re: jbc426]
#2286679
04/12/17 10:40 PM
04/12/17 10:40 PM
BradH
I'm going to installing a set of 3 modified 2300 series mechanical secondary carbs (the old Direct Connection Mechanical secondary Race carbs) that flow more than they did stock. Just how much more I won't know for a few weeks. The center 350cfm carb is being replaced with a 500CFM outboard mechanical carb, which didn't have idle circuits in them stock. This is being addressed so it can be used as a center carb. The boosters and barrels are being removed and the carbs are being converted to aerosol booster style by C&S Specialties. They build a lot of race two barrels for the roundy round guys.
Better keep a set of stock carbs on hand in case that experiment doesn't work out.
[Re: 72demon416]
#2286711
04/12/17 11:28 PM
04/12/17 11:28 PM
fast68plymouth
So. Burlington, Vt.
Better keep a set of stock carbs on hand in case that experiment doesn't work out. No way would I be firing up my fresh new build with some unknown carbs. There would be an m1 with an 850 on it for me. After the thing had some miles on it, rings properly seated, etc......then the aerosol carbs can get installed and tried.
[Re: fast68plymouth]
#2287383
04/14/17 12:14 AM
04/14/17 12:14 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Better keep a set of stock carbs on hand in case that experiment doesn't work out. No way would I be firing up my fresh new build with some unknown carbs. There would be an m1 with an 850 on it for me. After the thing had some miles on it, rings properly seated, etc......then the aerosol carbs can get installed and tried. I do have a second stock set that was dialed in nicely on the motor before we did the mods I will use to get it broken in. Thanks, Dwayne.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: ppmracing]
#2287810
04/14/17 06:40 PM
04/14/17 06:40 PM
Posts: 610 long time lurker, short time p...
PorkyPig
440cu .055 over FT piston 80cc chambers Edelbrock NHRA heads 201cc runners 2.08x1,74 valves, custome billet sheet metal intake ( fit under Cuda shaker hood) stock vaccum six pack carbs and roller cam,,,,,,750hp plus horsepower... Impressive. How fast is the car, and what does it weigh?
[Re: ppmracing]
#2287812
04/14/17 06:42 PM
04/14/17 06:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
440cu .055 over FT piston 80cc chambers Edelbrock NHRA heads 201cc runners 2.08x1,74 valves, custome billet sheet metal intake ( fit under Cuda shaker hood) stock vaccum six pack carbs and roller cam,,,,,,750hp plus horsepower... At what rpm are you turning it to get that power and what does that custom intake look like.
