Re: Can a 4" stroke SB crank be turned to?
[Re: TRENDZ]
#2285708
04/11/17 08:29 AM
04/11/17 08:29 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Brett, no doubt you can build a great engine, and are an absolute master with cylinder heads, but you can't math. Oh man, you are really going to upset 1967dartgt now!
[Re: GTS340]
#2285710
04/11/17 08:32 AM
04/11/17 08:32 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Brett, no doubt you can build a great engine, and are an absolute master with cylinder heads, but you can't math. Oh man, you are really going to upset 1967dartgt now! Ok man, please explain how you will pull the piston down further but not push it up further in the cylinder.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: rt66jim]
#2285712
04/11/17 08:38 AM
04/11/17 08:38 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The first part of the equation is to determine DIAMETER. The part that is being ignored is RADIUS.
[Re: 1967dartgt]
#2285715
04/11/17 08:42 AM
04/11/17 08:42 AM
GTS340
Romulus, MI
Brett, no doubt you can build a great engine, and are an absolute master with cylinder heads, but you can't math. Oh man, you are really going to upset 1967dartgt now! Ok man, please explain how you will pull the piston down further but not push it up further in the cylinder. Did you even read any of the posts before you jumped on board with Brett's point of view? See attachment! Here is something for ya, I'll send you guys a cheap cast eagle 4.000 stroke SB crank, if you can regrind it to 1.850 journals and 4.500 stroke (without welding) I'll give you 10 grand, if you can't I get your 67 Dart? Let me know if you're in and I'll have a law firm draft up the contact.
[Re: rt66jim]
#2285719
04/11/17 08:47 AM
04/11/17 08:47 AM
1967dartgt
Hilltown Pa
I stand corrected.
[Re: W5DART66]
#2285721
04/11/17 08:49 AM
04/11/17 08:49 AM
GTS340
Romulus, MI
Dude you should check your facts....
Will not argue with you I offset cranks all the time. You double What you offset period Doubling the offset is the max that stroke can be increased, this is unarguably 100% correct! However, there is a difference between change in journal diameter and offset. 2.125"? Or 2.100"? So 2.125" down to 1.850" = .275" you can not get it all but .250" should clean up back to round. So your stroke gain would be .500". 4.500" stroke but 1.85 on 4" crank will have no Journal overlap. Anything you offset will be 2 times the stroke gain. So .050" offset will give you .100" gain in stroke.
[Re: 1967dartgt]
#2285722
04/11/17 08:51 AM
04/11/17 08:51 AM
GTS340
Romulus, MI
Please read article and then reexplain your theory. Pretty sure the diagram I made and posted shows exactly how it works, and It's not my theory but actually bound by the laws of mathematics. But sure I'll take a read on your posted article. Taken directly from the second paragraph in that artice: "In theory, going from a 2.10 to a 2.00 journal should allow a 0.100-inch stroke increase if the throw is reground with the max possible offset (relocating its centerline by 0.050 inch)"What can you not wrap your head around?
[Re: 1967dartgt]
#2285784
04/11/17 12:19 PM
04/11/17 12:19 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
[quote=1967dartgt
Man lots of bad info in this thread. You have a engine builder correct you and you tell him he is wrong, wow. Wonder why so many people stopped posting in here. [/quote]
I don't know if all the bad info reduces post counts, but bad info like some in this post is the reason I spec and build my own engines.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#2285806
04/11/17 01:28 PM
04/11/17 01:28 PM
GTS340
Romulus, MI
Man lots of bad info in this thread. You have a engine builder correct you and you tell him he is wrong, wow. Wonder why so many people stopped posting in here. I don't know if all the bad info reduces post counts, but bad info like some in this post is the reason I spec and build my own engines. Here is the problem with bad info on the internet. Certain types of people: Fan boys Nutswingers Followers or people who refuse to think for themselves have the view that certain individuals that they look up to are not capable of being wrong from time to time, so they jump on board with whatever they have say and go forward repeating the bad info as if it were the gospel. If someone stops posting here because they cannot accept their views being challenged, well I guess that makes them weak. I encourage independent thinking and for everyone to form their own view and accept that EVERYONE is wrong on occasion.
[Re: Porter67]
#2285836
04/11/17 02:24 PM
04/11/17 02:24 PM
Posts: 43,355 Bend,OR USA
Cab_Burge
Better yet, why do so many fall for the "dyno only" parts thinking they are not abused. Years ago one of the brothers, Gary, from ABS and Speedomotive CO family shared some information he got when he was invited to attend Daytona Speed week and given several tours of the better NASCAR teams shops, this was over twenty years ago so keep that in mind for the rest of this post. One of those teams had seven different engine dynos, three Super Flows, three DTS and one Studka hybrid, running 24 Hrs. a day seven days a week on engine development That had the software to replicate the entire race at Wadkins Glenn or the other road course they use to race at in New England Straight ways, all the corners, acceleration and deaccelleration (CRS ) My point is some dyno parts are tested and ran a lot longer than some raced parts are to find the actual time limit under simulated race conditions before failure If your going to use race parts for racing buy them new
[Re: rt66jim]
#2285885
04/11/17 04:22 PM
04/11/17 04:22 PM
dogdays
I don't believe we have to go through this every two years.
On any crankshaft the stroke is the distance from the CENTERLINE of the main journal to the CENTERLINE of the rod journal, times 2. When we decrease the diameter of the crankpin b offset grinding, we move the centerline of the crankpin or rod journal by 1/2 the change in diameter. That's because the centerline only moves half of the distance the innermost part of the journal does. Then we multiply it by 2,as in my initial equation.
So the maximum perfect world increase in stroke is equal to the change in crankpin diameter.
It isn't a perfect world and to get a perfectly round journal using real tooling, the outermost bit of the rod journal has to be ground if only a little. So on Earth, anyway, the increase in stroke will always be slightly less than the change in diameters.
IMHO the steel that goes in a NASCAR rod is at the top end of 4340 quality. So even if it has run 500 miles, and is down to its 57% fatigue limit, if it magnafluxes OK and if the journal and pin bores are round, I won't be able to break it at 5500rpm.
R.
