Re: Roll bar for a 69 Dart questions
[Re: justinp61]
#2283977
04/07/17 03:19 PM
04/07/17 03:19 PM
Thumperdart
State of confusion
I used a S&W 6 point kit in my Dart and bought the pro street rear bars to go with it. It looks pretty much like lawndarts with the exception that my door bars are straight.. It's a nice kit, everything is cut long so it can be made to fit up nice and tight.
BTW no one rides in the back seat in my car. IMO back there the roll bar would be more dangerous than the crash. This is what I did years ago then had Rob Lindsey at R&J fabrication weld it in.............
[Re: 69 lawndart]
#2283980
04/07/17 03:26 PM
04/07/17 03:26 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a CE kit for the '72 Cuda in my shop and I like your side bars better than the swing out bars that we got in the kit. The Cuda is going to run a little this year and when we get tossed out for running under 11.49 we will install the kit.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 440mopar]
#2283984
04/07/17 03:27 PM
04/07/17 03:27 PM
Posts: 11,826 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you want to retain the full interior AND have a legal bar or cage that you can live with in a driver, have someone who knows what they are doing bend it up and install it. IF the car will not run quicker than 11.50, you may get away with a less than legal bar which will provide some degree of safety beyond having having nothing. Any kit you buy will be a basic deal made to pass tech, be cheap, be easy to install and nothing more. Yes, it will cost a little more than having someone slap a kit together. Don't forget the frame ties.
[Re: 440mopar]
#2283996
04/07/17 03:47 PM
04/07/17 03:47 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Also consider if you wish to keep the arm rest.When the door bar is in the right spot you will most likley have to loose the armrest. Greg just did his Duster.
[Re: 69 lawndart]
#2284235
04/08/17 12:25 AM
04/08/17 12:25 AM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
The reason we kicked the door bar down is to clear the arm rest. I wanted to keep the interior as close to stock as possible. Those door bars look great in the Dart! RT
[Re: RTSrunner]
#2284292
04/08/17 05:08 AM
04/08/17 05:08 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The reason we kicked the door bar down is to clear the arm rest. I wanted to keep the interior as close to stock as possible. Those door bars look great in the Dart! RT You have to be careful not to go to low on the door bars also as the rule says it needs to pass in between your shoulder and elbow when sitting in the drivers seat. If its to low it may not be legal. But many tracks dont check them that close. Mine is legal as its an S & W 6 point kit. But I cant go much lower or it would not be legal. I have raced in some NSS races and none of the tech guys look hard at my car as they have never questioned me about the bar. Ron ![](http://pic20.picturetrail.com/VOL1620/1011563/2193145/260314761.jpg)
[Re: 440mopar]
#2284385
04/08/17 01:29 PM
04/08/17 01:29 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I used a rhodes race car 8 point kit in my belvedere with the seat saver rear bars. Pretty happy with the fit. I'm tall and wanted to keep the door bars low, so I'm mounting my seat low. Other than the seat aver bars, you can't see the roll bar from the exterior since it's a post car.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: CMcAllister]
#2285090
04/09/17 11:43 PM
04/09/17 11:43 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
If you want to retain the full interior AND have a legal bar or cage that you can live with in a driver, have someone who knows what they are doing bend it up and install it. IF the car will not run quicker than 11.50, you may get away with a less than legal bar which will provide some degree of safety beyond having having nothing. Any kit you buy will be a basic deal made to pass tech, be cheap, be easy to install and nothing more. Yes, it will cost a little more than having someone slap a kit together. Don't forget the frame ties. That's what I'm doing with my street car, I'm having Chassisfab Performance in Tallmadge Ohio do a custom 6-point bar for me, the door bars will be bent like a pro-touring car to conform to the seat and still be able to keep the arm rest. I'm only planning on running 10.90's at best and will only race a couple times a year. And I know the door bars will have to start up high between me shoulder and elbow. I really like that door bar 69lawndart posted, with the added gusset type bar in his photo.
[Re: ProSport]
#2285094
04/10/17 12:07 AM
04/10/17 12:07 AM
Posts: 4,715 Wichita
GY3
Wichita
I was able to keep the rear seat AND the door armrests. Is it 100% to the letter of the rulebook? Probably not. Will it get me booted from the track. I really doubt it.
