Re: How much money is saved building a motor your self?
[Re: 84Stepside]
#228399
02/18/09 01:40 AM
02/18/09 01:40 AM
Sure you can save money but it's the experience that you can't put a price on... I personally take great pride in doing the work myself. If you're just doing a stock rebuild, and you have a guide to follow, then feel confident that you can do a good job. You can rebuild a stock engine with the most basic tools. It's about as hard as rebuilding a lawnmower... It's so easy...
[Re: 84Stepside]
#228400
02/18/09 01:49 AM
02/18/09 01:49 AM
RapidRobert
$60-$80 an hour/a whole lot of pride/meticuolous attention to detail. Work something out with a skilled Mopar head to come over & guide/help you with the problem areas & is available for you to call with issues that can be handled over the phone.
[Re: 64Post]
#228401
02/18/09 01:55 AM
02/18/09 01:55 AM
Posts: 6,445 Abilene, Texas
fastmark
Abilene, Texas
You may make some mistakes on your first build, but this board can help your through it. I wish I had something like this when I first started. To me building your own motor serves several purposes. First, it is a blast to do. I have as much fun building motors as anything I do. Buy all the books and get advise from a good high performance machine shop. Secondly, I do a better job than all but the best shops. I take pride in my work. On stock rebuilds you will only save a minimum of $$ because they are not really hard to do for most shops. The last two motors I have taken apart, had several mistakes made by professional shops. Lastly, it is something that you can be proud of. If you have the capability to build an engine and it runs great, then you can take pride in the fact that not everyone is capable of doing that task. One of the most challenging motor programs I have ever been evolved in was my kids jr dragster engines. It may not sound like much, but to take a lawn mower engine producing 5 hp and make it into a big bore stroker with a .600 lift cam that has to be clearanced in more places than most motors have places. And then make it turn 8500 rpm and run a 7.90 @ 84 mph every pass, that takes more than you would think. So building the motors is more fun than a cost savings to me. Jump into with both feet. If something does not feel right going together, then ask the board. We'd be glad to help.
[Re: fastmark]
#228403
02/18/09 03:29 AM
02/18/09 03:29 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
the first engine I ever built is the one in my dakota--383 stroked to almost 440, 500 hp, 535 tq. 3,000 miles so far and other than a cracked cylinder wall after the first 200 miles, it's been trouble free. the cracked cylinder wall would have happened even if a pro-shop built the engine. it's a 30 year old casting thats bored to the max.
I paid a machine shop to do the following things:
hot tank, clean, inspect the block mill the decks and cylinders check the alignment of the mains install cam bearings mock up crank/rod/piston, degree in the cam, check P to V clearance, and balance the whole thing.
I spec'ed out the stroker, rod length and compression height of the piston for the CR that I wanted, picked the cam picked the heads, intake and carb
assembled and shimmed the rocker gear with adjustable rockers, trimmed the bearings to fit, put it all together, took it back to the dyno to try and break it
I feel as if I built the motor myself and I'm happy about how it turned out, and I had a blast putting it together.
but, if you really think about it--I farmed out all the hard/tedious work. I didn't measure my clearances because I lack the precision tools and experience to use them properly. I didn't weigh anything for the balance job for the same reasons.
so, maybe I paid the shop to do it all and I just took care of final cleaning and assembly. The shop told me final assembly would have cost another $700, so I guess I saved $700 by doing it myself.
Plus whatever I saved by ordering the parts myself instead of through the shop to avoid the markup they put on parts they sell
**Photobucket sucks**
[Re: 70Cuda383]
#228405
02/18/09 08:44 AM
02/18/09 08:44 AM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
What fun is any hobby if you are paying someone else to do everything? You might as well buy a finished car! I have some things done, but only if I don't have the tools or equiptment. I assemble my own engines, some were taken to machine shops (with various results) and some were not. I can say good and bad of both methods, I still have all 6 of the engines I did, and they all still run great after 20 years. Currently, I am rebuilding a '70 model 383 for my Super Bee. It was a good running engine, with little wear, a good base to start with. Everything is measuring up well so far, and this one is only getting re-ringed and new bearings. I bought a ridge reamer and learned not to get your knuckles in the way when coming around with the wrench! So I have made mistakes. Well yeah! I just started doing my own valve jobs, I bought an old Sioux valve seat grinder, and it has been really fun. Do what you think you can do right, but a good machinist is worth his weight in gold. As is a good bodyman...........apholsterer............you get my drift? If you want to try it, get books and read up and ask questions here, you will do fine, and most importantly you will enjoy it! That's the idea!
[Re: 84Stepside]
#228407
02/18/09 09:30 AM
02/18/09 09:30 AM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
I do EVERYTHING on my 64 Polara myself, partly for the satisfaction and partly cause I don't won't to be one of those guys that just trailers his car around to get it built. I noticed you haven't really gotten any prices on builds yet, so I'll give you one. I have a 413 bored to 426 cubes,and with all the machine work and parts, I have about $2500 in my motor, but that includes NEW headers, aluminum intake, 750 Holley, Lunati cam, Crane springs and retainers, misc. The only stock/used parts were the block, pistons, rods, and heads. I very much enjoyed building it, though. I'm sure it would have cost at least twice that much to buy it built, but I don't know about having someone else put it together.
Jeff Adams
64 426 Polara
[Re: Neil]
#228412
02/18/09 11:20 AM
02/18/09 11:20 AM
Ledman_70
Central Ohio
If you're only going to build 1 motor EVER,I'd say have it done, but if you're going to do more motors later on (like most of us), buy the tools and do it yourself...at least you'll have the tools for the next motor and the cost will be much lower. Not to mention, maybe you can recover some of the tool costs buy assemblying motors for other people.
Jeff Adams
64 426 Polara
[Re: Ledman_70]
#228413
02/18/09 12:38 PM
02/18/09 12:38 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I think cost savings is a factor of who would have charged you to assemble, and if you can do it right so it doesnt need to come apart again. Somewhere int eh middle is your savings. I wouldnt pay Indy, or 98% of the shops I know in CT to assemble, because I know of issues with all but two of them. You have to realize, by assembling yourself, your take all responsibility for it. If the parts arent machined rigth and you didnt measure, it's your fault you didnt catch it. No shop warranties parts or labor when you assemble yourself. So get it right, or pay again. I do get paid by others to assemble, and in the past it's cost me more than twice what I charge because I missed something. It's the builders responsibility to catch other issues before things get bad. Ruined cams, broken rockers, bent pushrods, leaks, overheating, are all common place issues that crop up with do-it yourselfers. I am not tryign to discourage. I'm trying to show both sides of the coin. Yes, you feel better about it, I especially dislike checkbook racers who are egocentric about their car. Anyone can go fast with enough cash thrown at it. However, if and when soemthign goes wrong (I cite the camshafts issue, and the blaming of cam companies especially here) it is also YOUR fault. Not the parts'. There is a reason a good shop gets paid well. It's for the tools and the experience, in addition to the assumption of liability.
[Re: 69Cuda340S]
#228415
02/18/09 01:31 PM
02/18/09 01:31 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
I used to do my own.Now I have my shop do them.My machinist is a guy that has to have perfection.That and the last short block he did was 1200 for labor total.That was decking line hone bore clean install all the soft plugs balance blueprint open up for 1/2 inch pickup fit rings redo the rods turn flywheel do my heads and put the lower end all together.Cost me about an extra 2oo bucks to have him do what I couldnt do at home.After I work on cars for 8 hours at work the last thing I want to do is do more at home.I do all the rest of the work myself.If you have a great machine shop like I have its worth the few extra bucks.Lets face it most here dont build engines everyday as a living.My machinist does.Thats the key a good shop.Rocky
Chrysler Firepower
