Re: How much money is saved building a motor your self?
[Re: Bill MeLater]
#228417
02/18/09 02:11 PM
02/18/09 02:11 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I'll do stock type rebuilds myself, well guess more like freshening up. Bearings, rings, gaskets, etc... when it comes time to build up, go with aftermarket parts(big money stuff) I let someone with alot more experience do it. Obviously you have to know what your doing, be able to read calipers and such, have all the equipment, etc...
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 84Stepside]
#228419
02/18/09 04:31 PM
02/18/09 04:31 PM
Posts: 9,894 MI, usa
dvw
MI, usa
This is an excellent type of build to learn on. No radical cam with valve train issues,no piston to head issues,no oil system issues. Read everything,ask questions when your stuck. You will need a torque wrench,dial indicator,and a degree wheel. Measure everything. You may not need to know every measurement,but you should learn how to make them. Find someone local who has done it before to guide you. Every one of us who has built a engine had a 1st time just like you. Where in Ontario are you? Doug
[Re: 84Stepside]
#228421
02/18/09 05:25 PM
02/18/09 05:25 PM
RapidRobert
You might get a digital camera & take(many) pics both for your reference & to post them here if you get in a jam. This has saved my bacon many times as I do not have the photographic memory that I would like to think that I do.
[Re: RapidRobert]
#228422
02/18/09 10:49 PM
02/18/09 10:49 PM
Posts: 2,449 nc
earthmover
nc
I think I would try it myself ..I paid a machine shop almost 3600 to do my motor..ran good but never ran right when I took it apart the timeing chain looked to be worn out got a new chain almost 90.00 more dollars looks the same so now I am going to either use a tens. or gear drive...now when I say 3600 here is what they did..clean and check block,bore block,alain hone,cam bearing,freeze plugs,val job on heads,flow head,new rings,new bearing,new cam,oiland filter,install 3 heli coil,and degree cam,oh new timing chain,disassemble 1 motor,press 8 pistons on new rods I supplied rods,,picked it up was told no warr. its yours I dont own a machine shop or anything like that but 3600..now I plan to build it myself this time...did a 6 in a ford van and a318 in the duster years ago felt so good to know I had my hands on it and it is still running today.... ![](/ubbthreads/images/graemlins/wrench.gif)
[Re: earthmover]
#228423
02/18/09 11:05 PM
02/18/09 11:05 PM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
My ![](/ubbthreads/images/graemlins/Twocents.gif) .... I would say if this is a stocker rebuild with a touch bigger camshaft and no file-fit piston rings ... just put it together yourself - not to worry. Now if you have to massage the pistons and cyl head combustion chambers ....THAT would be over most people's head here. And that includes me !
[Re: 84Stepside]
#228424
02/18/09 11:31 PM
02/18/09 11:31 PM
Posts: 2,588 missouri, USA
moparmojo
missouri, USA
I vote that you build it yourself. Here are some reasons 1.Great way to learn. Take your time, get some books, use resources like Moparts to ask questions. 2.Building your own motor gives you a sense of pride. Plus you'll have a better understanding of how your car works. This will allow you or give you confidence to do other work like maintanence, and eventually up the ladder to harder stuff like rearends and transmissions. 3.Fact is once, you do it yourself, you will know what it involves and if, in the future, you are willing to pay someone else to do it. Do it once in your life to know what to expect of yourself or others if you choose them to do it for you. (IE:what's it worth for someone else to do it). Hard to get ripped off when you have done it yourself and know what is involved. 4.There is probably a cost savings, maybe not so much on your first engine, but why not buy the tools and have them for life. Every guy likes hanging specialty tools on the pegboard..Its macho!. 5.You may make mistakes, but as long as you don't make the same mistakes over again, you will be fine. Life will always be another new "first" don't be intimidated. Sure there is a time and a place for you to farm out that big race motor or stroker motor. Sometimes there is good insurance in knowing a pro is building it. But plenty of guys here will say the pros do it right and just as many times we hear of silly "my machinist did this to me" stories. So it all is circular in the end.
[Re: moparmojo]
#228425
02/19/09 10:06 AM
02/19/09 10:06 AM
Posts: 508 Ontario, Canada
84Stepside
Ontario, Canada
I am gonna get some books off amazon today and start reading lot. I am gonna wait till the weather gets warmer to start disassembley so i am not fighting surface rust as much. I have a good camera so i will take alot of pics. I guess i wont know what it needs untill i open it up. I know i will most likely have cracked heads. I will most likely get EQ's if the stock ones are cracked. I am not looking to cut corners doing it myself but i think it would be alot better to do some of the work myself and take the labour cost savings to invest in tools needed for the job like you guys have said. I know this will not be the last motor i build if i enjoy it. I will also learn alot. I do have some car mechanic friends i could go to if i need help. Sounds like the first step is to take everything apart and send the heads to get checked and the block cleaned and checked and go from there.
[Re: 84Stepside]
#228426
02/19/09 10:38 AM
02/19/09 10:38 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
Go for it... Don't expect to save money Don't be put off by delays Don't get frustrated when you make a mistake Don't hesitate to call some machine shops/engine builders for advice You will come out of this process knowing exponentially more than you do right now. My ![](/ubbthreads/images/graemlins/Twocents.gif) Ken
[Re: 84Stepside]
#228428
02/19/09 05:22 PM
02/19/09 05:22 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I built my first 340 in the living room of the trailer I was living in during 1975. That engine took me to Montana and back in 1976 in my '72 Duster and it was still running strong when I sold the car in 1980. Building an engine is really easy. There's nothing magical about it. Just take your time, and make sure everything is clean. And, don't be afraid to ask questions. Plus, when you hear that engine light for the first time after building it yourself, it is a great feeling.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
