Re: Tube Chassis cars, what to look for?
[Re: GTS340]
#2284021
04/07/17 04:41 PM
04/07/17 04:41 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
8.50 Cert that I changed to 6.0 Cert What spec is that? I see 2x3 main rails, those are only good to 7.50, or did you add redundant chromoly rails? All chromoly in cage area, even double frame railed.
[Re: GTS340]
#2284071
04/07/17 06:00 PM
04/07/17 06:00 PM
Biginchmopar
Carson City, Nevada
So you replaced the 2x3 rails? I just added the two frame rail bars along with the 2 x 3. I would have had to completely redo the car to to remove the 2 x 3 and that was out of the question.
