Re: 72-93 D200 front suspension questions
[Re: ruderunner]
#2284187
04/07/17 10:37 PM
04/07/17 10:37 PM
Posts: 10,651 Freeport IL USA
poorboy
Freeport IL USA
Wow! Lots and lots of misinformation here. Wylie, don't change anything yet or buy anything yet till we can figure out which of the 2 suspension ratings you currently on.
Lunch is ending, I'll have to post more later... If there is so much misinformation here, I would think you should be able to offer the correct info. I and others I'm sure, are waiting for your correct information. I will happily admit I'm wrong as soon as you (or anyone else) provide proof my info is incorrect. A 21 year period of time that happened 24 years ago can make a memory a bit fuzzy, especially when we are dealing with Dodge trucks. Gene
[Re: Wyle E Coyote]
#2284216
04/07/17 11:42 PM
04/07/17 11:42 PM
Posts: 5,958 ohio
ruderunner
ohio
Sorry Poorboy, some of us work for a living....
that said , after a 16 hour day im tooo beat to get into it now. Be up at 4 am for the scoop.
Its really simple with a couple minor twists, most of whats been stated might be true but fairly irrelevant.
Angry white pureblood male
[Re: ruderunner]
#2284226
04/08/17 12:09 AM
04/08/17 12:09 AM
poorboy
Freeport IL USA
Its really simple with a couple minor twists, most of whats been stated might be true but fairly irrelevant. You are assuming the rest of us don't work? I'm self employed, some days I have a few minutes during the day, some days I don't. 4-5 hours of sleep is my normal.
[Re: BIGGERED]
#2284298
04/08/17 07:38 AM
04/08/17 07:38 AM
Posts: 96 Nampa, Idaho
Wyle E Coyote
Nampa, Idaho
I'm not sure how clear this is?
Red Sorry, it's not that clear. But I really think that this is where we need to start. So could you please try that again? What I'm going to do is take those part numbers for the 72 and 73 and start looking forward. I hope to determine what years of A-Arms interchange. Also, I need to know what the numbers in the columns that are labeled 100, 200 and 300 actually mean. Thanks! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
25 Dodge Roadster 66 D100 440/727 (on 72 D100 chassis) 67 W200 360/727 72 IH TravelAll 1110 4x4 345/727/NP205 76 Scout 2 360/727/D20 '08 Dakota SLT Quad Cab 4wd 4.7L
[Re: Wyle E Coyote]
#2284309
04/08/17 09:30 AM
04/08/17 09:30 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Red Sorry, it's not that clear. But I really think that this is where we need to start. So could you please try that again? What I'm going to do is take those part numbers for the 72 and 73 and start looking forward. I hope to determine what years of A-Arms interchange. Also, I need to know what the numbers in the columns that are labeled 100, 200 and 300 actually mean. Thanks! The 100, 200 and 300 are for 1/2 ton, 3/4 ton and 1 ton. The numbers below are the number required on the vehicle. I can read most of the scans and there aren't as many part numbers as it appears. Make sure the 1st column has a D for 2wd truck. The B column is van parts.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Wyle E Coyote]
#2284322
04/08/17 10:55 AM
04/08/17 10:55 AM
Posts: 5,958 ohio
ruderunner
ohio
OK feeling much better after a good nights sleep. So now heres the rest of the story...
For 72-93 D trucks and 73 up B vans there are essentially 2 front suspensions designs, light duty and heavy duty. For the sake of reference I'm going to referr to the HD as 4000# front end since that's what Dodge called it. Also I mentioned B vans and while there is a fair bit of interchangablity, there's plenty that doesn't swap. Regardless, the pattern is the same for both chassis.
Among the 2 suspension designs, there are also early and late style, biggest difference was a redesign of the steering circa 1978.
To dispell some myths, the badge on the truck is pretty much irrelevant to which suspension the truck is equipped with. Exception is that all 100,150 trucks came with the light duty front end. No need to have an axle that can suport 4000# in a vehicle with a GVW of 4500# 200/250 and 300/350 were a mixed bag though the 4000# setup was more common on the 300/350, standard with dual wheels.
The GVW sticker in the door jamb is also fairly irrelevant, factors such as tires and frame rails can impact that number. Meaning a ld front end truck can have the same FAWR as a 4000# truck. The underhood sticker if present seems to be more accurate.
Engine choice is also mostly a non factor with the exception of the Cummins trucks, all factory Cummins trucks had the 4000# axle.
So, other than these cases, how does one tell which front end you have? Basically if it's 5 lug wheels its ld. The other tick is the tie rods, ld had fairly short inner and outter tie rods with a long sleeve. In fact the inner and outter tie rods can be swapped as an assembly. Techincally the factory speced l/h threads for the inner ad r/h for the outter but it's common to find them the other way.
The 4000# axle has long inner tie rods, short outters and short sleeves, they can't be swapped end for end and on vans the inners are different drivers vs passenger side. All 4000# are 8 lug wheels, BUT not all 8 lugs are 4000#
There are some parts that can be swapped between ld and 4000#, but not much. Pitman arm and idler arms are about it, possibly strut rod bushings. Even the shocks are different lengths. That said, as complete* assemblies they can be swapped. *Complete would include the engine/suspension crossmember though most who swap from ld to 4000# simply drill out the holes for the lower control arm bushings, it's ahrder to go the other way.
I mentioned lug patterns, the ld has 3 availible: 5x4.5, 5x5.5, and 8x6.5 and most are one piece hub and rotor. The 4000# has a separte hub and rotor. As for swapability of the ld rotors, well that gets extremely murky as bearings are different and the catalogs aren't much help in discerning which is which. Bet the 8 lug ld rotors take a different spindle.
So whats this all mean to Wylie? well based on the info he's given I'm going to say he definitely has the ld front end with currently 5x4.5 lug pattern wheels. Yes the oddball disc brakes, likely car sourced (C body?) bet they're pin type calipers. That said, I wouldn't automatically call them inferior since they're car based, plenty of C bodies had GVW that rivaled pickups. That said, parts availiblity for his current setup is going to be tough and a swap to newer stuff would certainly be worthwhile. BTW the 3/4 ton rotors aren't that much bigger than the half ton parts at least in the 73 up trucks. I'd have to look them up but I believe the calipers swap between half and 3/4 and yes 74-78 C bodies. So even the 3/4 ton brakes are car based...
So for Wylie to get 8 lug rotors without a complete front end replacement he'd have to find a ld 8 lug truck and grab everything from the ball joints out. Ideally a pre 78 truck to match the steering design but he could likely just swap the steering arms to keep things happy.
A note on ball joints: the 4000# setup used the same ball joints throughout the run. The 4000# joints have larger studs. The ld used the same ball joints throughout their run with the exception of some early trucks that may have used a threaded in lower ball joint vs a pressed in. Threaded vs pressed i believe used the same size stud however.
Not yet asked but upgrading to 8 lug rears will net a huge increase in brake size, 12x2.5 or 12x3 vs his current 10" (most likely) The most practical way to upgrade the rear brakes is with a complete axle swap.
As an aside, Wylie, just how big a camper do you intend to tow? 8000-10000 pounds would be something in the 24-30 foot range. Not many vintage campers in that size range.
[Re: BIGGERED]
#2285173
04/10/17 05:52 AM
04/10/17 05:52 AM
Wyle E Coyote
Nampa, Idaho
AAAHH! Much better! Thanks!
[Re: ruderunner]
#2285174
04/10/17 06:14 AM
04/10/17 06:14 AM
Wyle E Coyote
Nampa, Idaho
As an aside, Wylie, just how big a camper do you intend to tow? 8000-10000 pounds would be something in the 24-30 foot range. Not many vintage campers in that size range. Now we're getting somewhere! To answer your aside question first, I threw that number out there for reference. Mainly to show that I'm not always playing with light stuff. For example, I have access to a stout 7 1/2 x 18' flatbed trailer that I can haul anything I want on it, including cars. Dry empty weight on this is 3500# alone! Throw a full size pickup on there and 8K isn't so unrealistic. I know that the vintage trailers don't weight that much, but I want to be prepared for most anything, within reason. If it gets about 10K, I have access to bigger equipment that will have no trouble moving it. So as far as the rear end goes, swapping to an 8 lug rear is exactly what I'd planned. I'm frankly tired of going through axle bearings, or wondering if they're stout enough to handle what I'm doing at the time. Thanks again for all of this great info. Lots to study. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: BIGGERED]
#2285175
04/10/17 06:20 AM
04/10/17 06:20 AM
Wyle E Coyote
Nampa, Idaho
Wyle E.
The numbers in the columns are QTY required per truck.
Since your chassis is a 1/2 Ton Conventional Cab Truck the Model designation is D. Model designation for vans is B.
From parts manuals I BELIEVE the following....
1972-83 (Probably beyond 83) D series 100, 200 and 300 shared the same Upper Control Arms 3492122-3
1972-83 (Probably beyond 83) D series 100 and 200 (Up through 3600# front axle) shared the same Lower Control Arms 3492860-1. Note the lowers can change in a 200 with a HD pkg.
It also appears that 72-77 100-200 (maybe some 300) Vans shared the same lowers and 72-77 100-300 Vans appear to share the same uppers. Both B200 and D200 received 300 series lowers in the HD packages.
Let me know what else you need.
Anyone who notices any incorrect info please point it out to me, I will verify and amend my posts.
Thank you
Red Thanks Red! ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif) It was mentioned in another post about how in 1979 there were steering geometry changes. Any thoughts on that?
[Re: Wyle E Coyote]
#2285416
04/10/17 07:23 PM
04/10/17 07:23 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Thanks Red! ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif) It was mentioned in another post about how in 1979 there were steering geometry changes. Any thoughts on that? [/quote] There are differences in the Arm-steering- knuckles between at least 73 -78 along with 79-81 1973 3634920-1 1974-77 3634924-5 1978 3634924-5 79-81 4088048-9 Red
[Re: BIGGERED]
#2286270
04/12/17 08:06 AM
04/12/17 08:06 AM
Wyle E Coyote
Nampa, Idaho
Wyle E.
It also appears that 72-77 100-200 (maybe some 300) Vans shared the same lowers and 72-77 100-300 Vans appear to share the same uppers. Both B200 and D200 receieved 300 series lowers in the HD packages.
Thank you
Red Ok, so after studying what Red and RudeRunner have posted, this is what I have determined: I'm going to look for the complete suspesnion from a Pre-83 truck. Since the A-arms are the same part number, they should bolt up. And since I don't want to change the crossmember, I should stick with those years. Plan B is if I stumble upon a complete chassis that I roll it on the trailer complete, or at least the front clip. Then I turn my Pickup bed trailer back into a regular truck with a frame graft. Thanks again! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Wyle E Coyote]
#2286304
04/12/17 10:54 AM
04/12/17 10:54 AM
Posts: 5,958 ohio
ruderunner
ohio
Wylie, I don't think you need to worry about a frame graft or even swapping control armsUnless you want to upgrade to the full on 4000# front end.
Most 3/4 ton pickups use the LD front end and most if not all are 8 lug. From what I know, you should be able to find one and just grab the knuckles/spindles and brakes and swap them right to your truck. I'd stick to a pre 78 donor just because I'm not sure of what/why the steering was changed then. Just pop the ball joint studs and tie rod studs and grab what falls on your toes.
Red, do you know if any of those steering arm numbers are supercessions of previous ones? Or do your catalogs not have that info?
[Re: ruderunner]
#2287082
04/13/17 03:18 PM
04/13/17 03:18 PM
Wyle E Coyote
Nampa, Idaho
I'm not concerned about whether I have the 4000# front end or not, but I'll be sure to verify that before I get my tools out. There still seems to be plenty of older iron around me that I don't think it will be too hard to find. Especially since I can get these from a van also. Thanks again everyone for the good discussion! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: ruderunner]
#2287316
04/13/17 10:42 PM
04/13/17 10:42 PM
BIGGERED
Reasonable Title
Reasonable Title
North East USA
The only supercessions in the books are handwritten in. I was trying to get a friend who's a FCA parts guy to look further but they are buried at work. I'm not even sure if dealers have this info any more? I was expecting googling the appropriate part numbers to get superseded info but I did not find a lot of discussion / reference myself. Red
[Re: Wyle E Coyote]
#2288073
04/15/17 07:56 AM
04/15/17 07:56 AM
Posts: 5,958 ohio
ruderunner
ohio
I'm not concerned about whether I have the 4000# front end or not, but I'll be sure to verify that before I get my tools out. There still seems to be plenty of older iron around me that I don't think it will be too hard to find. Especially since I can get these from a van also. Thanks again everyone for the good discussion! I agree that for your intended use you don't need the 4000# front end setup, but you do need to make sure the donor truck is a non 4000# setup. Otherwise you are looking at swapping arms and at least modifying the crossmember. Yes van spindles work, but double check the steering arm numbers. Note, finding a pickup donor is better as you can grab the rear axle too. Van axles don't swap straight in, the spring spacing is different and iirc the whole thing is wider.
[Re: ruderunner]
#2289898
04/18/17 07:11 AM
04/18/17 07:11 AM
Wyle E Coyote
Nampa, Idaho
I'm not concerned about whether I have the 4000# front end or not, but I'll be sure to verify that before I get my tools out. There still seems to be plenty of older iron around me that I don't think it will be too hard to find. Especially since I can get these from a van also. Thanks again everyone for the good discussion! I agree that for your intended use you don't need the 4000# front end setup, but you do need to make sure the donor truck is a non 4000# setup. Otherwise you are looking at swapping arms and at least modifying the crossmember. Yes van spindles work, but double check the steering arm numbers. Note, finding a pickup donor is better as you can grab the rear axle too. Van axles don't swap straight in, the spring spacing is different and iirc the whole thing is wider. Yeah, I will double check. The online used part locators all seem to list a 3300# and a 3800# axle, of which I'm obviously going with the lighter one. I have considered the van set-up because I know that the lower control arms have a pocket in them for the coil spring. And that was a low buck way to drop the front end down on these trucks, before anyone made new spindles. But I'll have to be careful because it seems that there's not as many vans in the yards near me, as there are old class C motorhomes. And I'd suspect that even the shortest of those would be the stronger axle. If my memory serves, the van rear axles are not just the wrong spring perch spacing, but I believe they're slightly offset to the right. But there is at least one place locally that seems to have everything on one truck. I might have to just go look at it and see if I can get the rolling chassis for about the same price.
