Your 512 RB runs great!
Will you be doing a build thread for the low deck motor?
Current thoughts for heads going on this?
I started a thread on the 400/512 somewhere...Parts were delay'd because we went with the light weight crank option. Just got them Tuesday...Looks awesome, and the block was already prepped and ready almost a month ago. So I should be able to add to that thread if I can find it. I have some new pictures and info, just not the time.
There is more in the 440/512, as we do not beat on it real bad with high rpm. We also switched it over to a Dominator this year. Unfortunately, the Dominator on it I borrowed off my Hemi and it is probably a smidge bigger than the engine will want, but until I have the money for a 1050, I will try it with my 1250 and see what it goes. Season open 4/22 weather permitting.
