Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: MuuMuu101]
#2330729
07/03/17 02:40 PM
07/03/17 02:40 PM
Posts: 4,064 Boca Raton, Florida
jpilone
Boca Raton, Florida
I think my brain just melted from all that wheel and suspension math!
-Jarrod Pilone '70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit) My Project Thread
[Re: MuuMuu101]
#2338338
07/17/17 12:26 PM
07/17/17 12:26 PM
jpilone
Boca Raton, Florida
It's never done! I've got a small trans leak myself, but not that bad.. Think mine is from a switch on the passenger side of the trans.
[Re: MuuMuu101]
#2367774
09/09/17 04:21 AM
09/09/17 04:21 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I picked up the car today. It drives a lot better now with the larger T-bars and offset shackles installed. The car never had a trans leak, it was just engine blow-by, so I need to look into that now.
I drove the car from the shop to my work and then to my gf's house (about 30 miles all on streets) and it seemed to do fine. Later on in the day, my gf and I went on a little joy ride and the Dart was great. My gf was ecstatic and loved it. It was really fun.
Well, a couple hours later I had to take on the 30 mile journey home (mostly freeway). When I started the car, I kind of had a feeling there was a problem. I could sort of hear a little clunking noise from the car as it was idling and every time I pushed the clutch pedal it went away, but I wasn't sure. I put the car in reverse and backed out and as I shifted into 1st and was moving forward, it sounded like a mystery bolt came loose and clunked around for a second, dropped out of the car, then the car stopped and shut off. Keep in mind, the car was still a little cold (135-150F water temp) and has shut off on me when trying to move the car in 1st if it's not too warm (I rushed the warm up a little as I was trying to get home as it was late). I immediately started the car back up again and the noise was gone. I didn't want to scare my gf, so I drove away, planning on pulling over in a nearby neighborhood in case something happened as I didn't want her to worry (I know, not the smartest idea).
Well, as I was driving, the car felt fine, until I got on the freeway. It could just be me since I haven't driven the car in 2 months, but it felt like the car was fighting itself to stay at speed (70-80 mph). My frame of reference could be out of wack because I just got a new daily driver last week and have been driving that a lot. But I also noticed that when I hit the exhaust drone RPM band and tried cruising at that speed that the vibration was a lot more than usual, but would smooth out significantly after I raised the engine speed outside of drone RPM. Lastly, what I thought was kind of weird, and I don't remember it doing this before, was that sometimes when I'd try to accelerate to pass a car (let's just say I'm at 2500 RPM in 5th gear) the RPM would rise to about 3000 (still in 5th) for a second or two, but the car would stay at the same speed, then the RPM would drop to about 2700 RPM and it would increase speed by a small amount. This also did sometimes occur when shifting from 5th to 6th and vice versa. It may have done it before, but who knows, my memory could be off.
Anyways, I ended up getting home safe, but now I'm all freaked out that I have a transmission problem and I'm tired of spending money on this car. I swear this car hates me. I'm pretty frustrated with it at this point and if this ends up being something big, I'm parking the car until next June (when I finish my masters) because I don't have the time, patience, or money anymore to work on it. But who knows, this could all just be me and my tiredness.
[Re: MuuMuu101]
#2368977
09/11/17 06:35 PM
09/11/17 06:35 PM
Posts: 2,758 Gilbertsville, PA 19525
Pntastar69
I'm tired of sending the car to a shop and spending the money. Seems you spent a ton already at the shop and things aren't quite right. Maybe you picked the wrong shop!!!
[Re: GoodysGotaCuda]
#2369157
09/12/17 12:07 AM
09/12/17 12:07 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Have you had anyone else drive your car? Someone with a lot of experience can very very quickly pickup on quirks and signs that can easily be misconstrued for other things. If not, find someone you can trust, someone that has some additional experience that may help you get going in the right direction sooner than you think. I have not, I don't really know anyone with that kind of experience near me.
[Re: MuuMuu101]
#2385963
10/11/17 10:21 PM
10/11/17 10:21 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Well, the clutch is fried. Yikes, flywheel likely needs resurfaced too. Do you drive with your foot on the clutch pedal at all? Unless the clutch is not up to the horsepower, it should have lasted quite awhile.
#2385983
10/11/17 10:44 PM
10/11/17 10:44 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Well, the clutch is fried. Yikes, flywheel likely needs resurfaced too. Do you drive with your foot on the clutch pedal at all? Unless the clutch is not up to the horsepower, it should have lasted quite awhile. I thought about if I was riding the clutch, and I don't think I do. Generally I don't when I drive my daily, but the Darts pedal assembly is different. I mean, I've daily driven manual cars since I first got my license almost 10 years ago and I've never replaced a clutch. A lot of my commute is in traffic too. The trans shop thinks it could be the spacers between the bellhousing not being sufficient causing the throwout bearing to ride on the pressure plate, but Hotchkis doesn't think so. Regardless, Hotchkis wanted to check it out to "make it right" if they did something wrong, so we towed it over there today. We'll see what comes out of that.
[Re: MuuMuu101]
#2387375
10/14/17 02:48 PM
10/14/17 02:48 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Well, the clutch is fried. Yikes, flywheel likely needs resurfaced too. Do you drive with your foot on the clutch pedal at all? Unless the clutch is not up to the horsepower, it should have lasted quite awhile. I thought about if I was riding the clutch, and I don't think I do. Generally I don't when I drive my daily, but the Darts pedal assembly is different. I mean, I've daily driven manual cars since I first got my license almost 10 years ago and I've never replaced a clutch. A lot of my commute is in traffic too. The trans shop thinks it could be the spacers between the bellhousing not being sufficient causing the throwout bearing to ride on the pressure plate, but Hotchkis doesn't think so. Regardless, Hotchkis wanted to check it out to "make it right" if they did something wrong, so we towed it over there today. We'll see what comes out of that. My T56 Magnum TOB is supposed to ride on the pressure plate, by design. The CSC is designed to be compressed by more than 1⁄2” by the pressure plate fingers when at rest. There is, however, a proper way to shim it. Your TOB style may vary, but it can be assembled improperly. Clutch slippage will result if the CSC bottoms out and is partially depressing the pressure plate fingers at rest Start on page 8 https://shiftsst.com/media/wysiwyg/pdfs/2017June/MAG-00402_GM_Hydraulic_Manual_RevF.pdf
