Re: Steering coupler research help - FREE coupler clamp for info [Re: 135sohc] #2280175
04/01/17 09:57 AM
04/01/17 09:57 AM
moparx Online content
moparx  Online Content
here is a 74 imperial coupler. it's 3 1/2". the tape is deceiving, as i was trying to get the coupler in the shot and not show the torched off box shaft. there is a rag joint connecting the coupler shaft to the column.
beer
Re: Steering coupler research help - FREE coupler clamp for info [Re: 135sohc] #2280602
04/01/17 10:59 PM
04/01/17 10:59 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Originally Posted By 135sohc
79 B200 van, 3" coupler
85 B250 van also a 3" coupler.
Both were original 1 owner vehicles.
Wow. I woulda guessed the longer coupler.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Steering coupler research help - FREE coupler clamp for info [Re: moparx] #2280603
04/01/17 11:00 PM
04/01/17 11:00 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
beer
More confirmation that 74 & up vehicles had the longer coupler.
Re: Steering coupler research help - FREE coupler clamp for info [Re: 71TA] #2280608
04/01/17 11:04 PM
04/01/17 11:04 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Heres an odd one. From a friend in New Zealand with a US 75 Ramcharger. Neither the 3" or 3-1/2" but an odd looking coupler.
So cool to have Mopar friends all over the world.
Also from the Moparts Truck Forum....
"Don't forget spline diameter, trucks were typically larger since most used Saginaw boxes.
Trucks pre 80 or so tended to use Saginaw couplers vs the Mopar style."
Based on the info above that had a 3" coupler on a 79 truck, was the Saginaw coupler a 4WD thing or maybe pre 79 instead of pre 80?
Re: Steering coupler research help - FREE coupler clamp for info [Re: 71TA] #2280609
04/01/17 11:05 PM
04/01/17 11:05 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
74 challenger manual steering = 3 1/2
Re: Steering coupler research help - FREE coupler clamp for info [Re: flypaper] #2280615
04/01/17 11:14 PM
04/01/17 11:14 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks flypaper.
Nudder one. From an older Moparts coupler thread. 86 Ramcharger. Looks like a 3" coupler like the post aove that said a 79 truck and 85 van had 3" couplers.
Re: Steering coupler research help - FREE coupler clamp for info [Re: 71TA] #2280671
04/02/17 01:03 AM
04/02/17 01:03 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
73 Cuda 3 1/2 inches, late November, 1972 build (black Friday after Thanksgiving to be exact)
Craig
Re: Steering coupler research help - FREE coupler clamp for info [Re: 71TA] #2281390
04/03/17 09:28 AM
04/03/17 09:28 AM
i had a 74 power wagon with that type of coupler, [it's been gone since '83] and i thought it was an extra measure to insure the shaft didn't bind during any added flex when the cab and frame moved around during off road excursions ? i never had one of those apart however, to see what was inside. if you have a rag joint, the "common" type of coupler, and the one you show in your last pic, it should add quite a bit of movement before the steering shaft would bind up. does anyone happen to have a shot of the insides of one of those joints ?
beer
upon more reflection, that coupler might allow movement in and out to a certain degree ?
Re: Steering coupler research help - FREE coupler clamp for info [Re: 71TA] #2281850
04/03/17 09:31 PM
04/03/17 09:31 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
B vans are an oddity. A little bit of everything from all the parts bins. Just to add in, the vans also used the car steering box and not the saginaws found in most of the trucks.
Re: Steering coupler research help - FREE coupler clamp for info [Re: 71TA] #2282591
04/05/17 12:21 AM
04/05/17 12:21 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Maybe they standardized the coupler on all models & increased its length so there was enough room to slid the shaft down to replace the rubber coupling on the models equipped with it.
Re: Steering coupler research help - FREE coupler clamp for info [Re: 71TA] #2282763
04/05/17 12:10 PM
04/05/17 12:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 73 was built in October. I need to check it because other 73 owners have said theirs are 3". Now I'm wondering what mine has.
