Re: Duplicating Factory Spot Welds - Recommended? [Re: 6pkaar] #227957
02/19/09 05:51 PM
02/19/09 05:51 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
Here's the harbor freight $29.99 spot welder. I might get it just to see what it'll do....like I said, maybe it would work to "reweld" the plug welds that were done with a mig to make them look like factory spot www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98759....
ahh, it's an attachment for an arc welder
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: Duplicating Factory Spot Welds - Recommended? [Re: smac77] #227958
02/19/09 06:14 PM
02/19/09 06:14 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Oops....I guess I should have mentioned that.... But still, for 29 bucks I gotta see what it'll do. There's Harbor Freight about 1/2 mile from my office.
Re: Duplicating Factory Spot Welds - Recommended? [Re: 6pkaar] #227959
02/20/09 01:03 AM
02/20/09 01:03 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
An oxy-acetylene torch can also be used, result is much the same as TIG. This is how it turned out for me after a little practice on some scrap metal.
Re: Duplicating Factory Spot Welds - Recommended? [Re: 69ragtop] #227960
02/21/09 06:49 PM
02/21/09 06:49 PM
REH Offline
REH  Offline
I used a steel rod from the hardware store (as a punch) that matched the size of the original spot welds. Much better duplication then tig weld marks.
Re: Duplicating Factory Spot Welds - Recommended? [Re: 6pkaar] #227961
02/26/09 09:08 PM
02/26/09 09:08 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Give your $29 to the first stew bum you see and save the gas.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
