Re: Which thermostat on 400? [Re: paddel] #2278255
03/29/17 11:55 AM
03/29/17 11:55 AM
Sac, CA
mopowers Online confused
mopowers  Online Confused
Sac, CA
What temp thermostat came stock?
Re: Which thermostat on 400? [Re: mopowers] #2278474
03/29/17 07:14 PM
03/29/17 07:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
195
Rich H.
Esse Quam Videri
Re: Which thermostat on 400? [Re: paddel] #2278478
03/29/17 07:30 PM
03/29/17 07:30 PM
Two things to check before swapping the thermostat is the actual temperature of the coolant coming out of the thermostat housing when reading hot scope
The other is verifying what the actual temperatures are compared to what your stock gauge reads, I've had expensive brand mechanical analog race gauges read 40 F + off when warm puke
Never trust what you don't know to be facts, I use a Infra red hand held temperature gauge to verify now thumbs
Re: Which thermostat on 400? [Re: paddel] #2278527
03/29/17 09:42 PM
03/29/17 09:42 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Except that an IR thermometer can be even further off. The albedo (roughness) of the surface being measured can make a huge difference in the reading... not only that, the surface temp is not necessarily the same as the fluid or gas temp inside the object being measured!
So you also have to calibrate your IR gun to the particular t-stat housing you are measuring. I recommend a glass lab thermometer (remember those from high school and college classes?). They stay accurate unless broken. twocents
It's like the old saying, a man with one watch always knows what time it is. A man with two watches is never quite sure...
Re: Which thermostat on 400? [Re: Supercuda] #2278613
03/29/17 11:47 PM
03/29/17 11:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By Supercuda
Any9one ever look at the math that calculate heat transfer efficiency?
NO
Of all the variables in that calculation TIME is not one of them.
The primary variable is heat differential.
The higher the difference the better the transfer. So please stop with the time in the block/radiator wives tale.
As for thermostat temps, that is the floor, not the ceiling. Running an engine cool is not a good thing for anything other than a dedicated race car.
This I agree with. Its like I cant tell you how many times I have had someone tell me the eng will run hotter without the thermostat because the coolant dont stay in the rad long enough. I have run engines over the years without the thermostat when diagnosing overheat problems and I have never seen an eng run hotter without a thermostat. It takes much longer to heat up and has never run hotter with the thermostat out. Ron
Re: Which thermostat on 400? [Re: paddel] #2278624
03/29/17 11:56 PM
03/29/17 11:56 PM
Sac, CA
Sac, CA
Why did big blocks come stock with 195* thermostats? Didn't small block come with 180*? I know my 68 FSM says 180* for a '68 340.
